    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 124.8k Views 31 Watching
    • srxS
      srx
      Thank you! ๐Ÿ‘
      www.saurus.rs
      • samuel_tS
        samuel_t
        @lelam11234 said:
        Good plugin. But I have the suggestions.
        1. Tab Number: It has an extra cell so we can name it
        2. Tab Draw *** : It has an extra cell to Hide/Unhide
          Thanks.
        Thanks for your suggestions.
        • T
          turbodizayn
          Is there some manual? Sounds GRATE! If it is good I will donate)))
          • samuel_tS
            samuel_t
            Help will be available from next version.
            • jenujacobJ
              jenujacob
              hi Samuel,
              Great plugin! i really hope this grows into something like GH for Rhino.
              now, I am no coder, and I have absolutely no idea how this thing works under the hood. But, would be it possible to click in the SU window to enter values for points instead of typing in the x.y.z coordinates?
              thanks!
              • P
                pinoy
                This is good! Thank you
                • samuel_tS
                  samuel_t
                  @jenujacob said:
                  hi Samuel,
                  thanks!
                  Hi Jacob, Thanks! I'm thinking about a "Parametric Modeling > Extract Point From Construction Point" entry in context menu when a construction point is selected in SketchUp window. This would be a shortcut to add a "Point" node.
                  • samuel_tS
                    samuel_t
                    What's new in 0.0.3 version?
                    • Node adding process was enhanced: one can place new nodes quicker!
                    • One can extract vectors and points from active model via context menu.
                    • In "Calculate" nodes, one can use rand function to get random numbers.
                    • As soon a material or a layer is added or removed: Nodes Editor reloads.
                    • A door is available in examples schemas. Thanks Simon Joubert for this.
                    • Although it's not recommended, one can read/edit .schema files easier.
                    Download latest Parametric Modeling plugin from the SketchUcation PluginStore.
                    • Didier BurD
                      Didier Bur
                      Hi Samuel,
                      First thank you for this stunning plugin ๐Ÿ˜ฎ
                      Just downloaded and installed v0.0.2 (v0.0.1 was working OK, apart from several Bug Splats) but this time the dialog is blank. Any idea ? (maybe I must uninstall v0.0.1 prior to installing v0.0.2 ?)
                      DB
                      • Didier BurD
                        Didier Bur
                        @samuel,
                        ๐Ÿ˜ ๐Ÿ‘ it works now ! Thanks for the tip
                        DB
                        • samuel_tS
                          samuel_t
                          Hi Didier,
                          Try to remove it manually then install its 0.0.3 version (released today). Tell me if problem persists.
                          • samuel_tS
                            samuel_t
                            Great! You're welcome ๐Ÿ˜‰
                              Robin Morritt
                              Samuel:
                              I don't understand this plugin, but I've just downloaded it and donated ยฃ5 because it looks like an amazing development. I saw your thread on the SketchUp Community Forum - and I spotted the word Eneroth in the description. It has all the hallmarks of Trimble royalty.
                              A couple of suggestions, if I may. 1) Place plenty of strategic links to the relevant Sketchucation Forum for those of us who struggle with this site's navigation. 2) Provide users with more options to contribute. I find SubscribeStar user friendly and non-intrusive, for example. Getting ยฃ5 out of me is like getting blood out of a stone, but it is something I quite like to do, and appreciate it when people overcome their natural shyness of pointing out that free stuff isn't entirely free and give me options.
                              I'm just some old bloke who talks too much. Apologies for that.
                              Congratulations and best wishes for the success of your gamechanging plugin.
                              Robin.
                              • samuel_tS
                                samuel_t
                                @robin morritt said:
                                Samuel:
                                Robin.
                                Hello Robin,
                                Even if I develop this plugin because it's a fun challenge, donations of any amount are always welcome ๐Ÿ˜‰ So thanks!
                                • L
                                  lelam11234
                                  Hi Samuel
                                  I have a couple of suggestions.
                                  1. When we choose a wire, it is brighter to make it easy discriminate from.
                                  2. We need a node to Hide/unhide block (such as Box, Cylinder,...).
                                  3. We need a node like Number node but it is List style
                                    Robin Morritt
                                    I am trying to create a universal nut and bolt modeller using the amazing Parametric Modeling.
                                    I've been trying to "Subtract" threads from a cylinder.
                                    If I route the group "Move" -> "Subtract solids", as screenshot, then the first prism is subtracted.
                                    If I route the group "Move" -> "Make group" -> "Subtract solids", the "XYZ" group is ungrouped.
                                    If I route the group "Move" -> "Select" -> "Subtract solids", then various interesting things happen.
                                    I really haven't got the foggiest idea how to use "Select".
                                    Is there somewhere I can get a bit of background on how to use it?
                                    Parametric Model F.skp
                                    • samuel_tS
                                      samuel_t
                                      [attachment=0:tvug2vb0]<!-- ia0 -->Screenshot 2021-03-30 012046.png<!-- ia0 -->[/attachment:tvug2vb0]
                                      Interesting project ๐Ÿ˜„ Only place I know where you can find some infos about "Select" is documentation.
                                        Robin Morritt
                                        Many thanks for the quick response.
                                          Robin Morritt
                                          Hi Samuel: ๐Ÿ˜„
                                          I'm pressing on with my universal metric thread modeller.
                                          Should I report issues using Github Issues?
                                          Or would you prefer us to use this forum?
                                          Thanks,
                                          Robin. ๐Ÿ‘
                                          12 segment M6 x 1. Work in progress.
                                          • samuel_tS
                                            samuel_t
                                            Hi Samuel: ๐Ÿ˜„
                                            Thanks,
                                            Robin. ๐Ÿ‘
                                            Hi Robin ๐Ÿ˜„
                                            GitHub has my preference.
                                            • 2 / 5
