    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 124.8k Views 31 Watching
    • K
      kenancakir
      Thank you.. ๐Ÿ˜
      • K
        Kruegen
        This is amazing!!!! Thank you so much for doing this. You have no idea how much time this will save me. Thank you!!!
        • C
          cloo
          Looks really cool, and a lot of work ahead.
          Since you GPL it, do you have plans to move development to github or so and let other cool folks contribute to the progress?
          • samuel_tS
            samuel_t
            Yes. I will publish to GitHub the source code of this plugin in a near future.
            • N
              numerobis
              Very cool!
              It would be great, if this could be made non-destructive / as modifier. But i suppose it's not possible with SketchUp to store the operations in the model/component. Maybe this could change in the future with LiveComponents...
              • L
                lelam11234
                Good plugin. But I have the suggestions.
                1. Tab Number: It has an extra cell so we can name it
                2. Tab Draw *** : It has an extra cell to Hide/Unhide
                  Thanks.
                • srxS
                  srx
                  Thank you! ๐Ÿ‘
                  www.saurus.rs
                  • samuel_tS
                    samuel_t
                      Thanks.
                    Thanks for your suggestions.
                    • T
                      turbodizayn
                      Is there some manual? Sounds GRATE! If it is good I will donate)))
                      • samuel_tS
                        samuel_t
                        Help will be available from next version.
                        • jenujacobJ
                          jenujacob
                          hi Samuel,
                          Great plugin! i really hope this grows into something like GH for Rhino.
                          now, I am no coder, and I have absolutely no idea how this thing works under the hood. But, would be it possible to click in the SU window to enter values for points instead of typing in the x.y.z coordinates?
                          thanks!
                          • P
                            pinoy
                            This is good! Thank you
                            • samuel_tS
                              samuel_t
                              @jenujacob said:
                              hi Samuel,
                              thanks!
                              Hi Jacob, Thanks! I'm thinking about a "Parametric Modeling > Extract Point From Construction Point" entry in context menu when a construction point is selected in SketchUp window. This would be a shortcut to add a "Point" node.
                              • samuel_tS
                                samuel_t
                                What's new in 0.0.3 version?
                                • Node adding process was enhanced: one can place new nodes quicker!
                                • One can extract vectors and points from active model via context menu.
                                • In "Calculate" nodes, one can use rand function to get random numbers.
                                • As soon a material or a layer is added or removed: Nodes Editor reloads.
                                • A door is available in examples schemas. Thanks Simon Joubert for this.
                                • Although it's not recommended, one can read/edit .schema files easier.
                                Download latest Parametric Modeling plugin from the SketchUcation PluginStore.
                                • Didier BurD
                                  Didier Bur
                                  Hi Samuel,
                                  First thank you for this stunning plugin ๐Ÿ˜ฎ
                                  Just downloaded and installed v0.0.2 (v0.0.1 was working OK, apart from several Bug Splats) but this time the dialog is blank. Any idea ? (maybe I must uninstall v0.0.1 prior to installing v0.0.2 ?)
                                  DB
                                  • Didier BurD
                                    Didier Bur
                                    @samuel,
                                    ๐Ÿ˜ ๐Ÿ‘ it works now ! Thanks for the tip
                                    DB
                                    • samuel_tS
                                      samuel_t
                                      Hi Didier,
                                      Try to remove it manually then install its 0.0.3 version (released today). Tell me if problem persists.
                                      • samuel_tS
                                        samuel_t
                                        Great! You're welcome ๐Ÿ˜‰
                                          Robin Morritt
                                          Samuel:
                                          I don't understand this plugin, but I've just downloaded it and donated ยฃ5 because it looks like an amazing development. I saw your thread on the SketchUp Community Forum - and I spotted the word Eneroth in the description. It has all the hallmarks of Trimble royalty.
                                          A couple of suggestions, if I may. 1) Place plenty of strategic links to the relevant Sketchucation Forum for those of us who struggle with this site's navigation. 2) Provide users with more options to contribute. I find SubscribeStar user friendly and non-intrusive, for example. Getting ยฃ5 out of me is like getting blood out of a stone, but it is something I quite like to do, and appreciate it when people overcome their natural shyness of pointing out that free stuff isn't entirely free and give me options.
                                          I'm just some old bloke who talks too much. Apologies for that.
                                          Congratulations and best wishes for the success of your gamechanging plugin.
                                          Robin.
                                          • samuel_tS
                                            samuel_t
                                            @robin morritt said:
                                            Samuel:
                                            Robin.
                                            Hello Robin,
                                            Even if I develop this plugin because it's a fun challenge, donations of any amount are always welcome ๐Ÿ˜‰ So thanks!
                                            • 1 / 5
