    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 121.4k Views 31 Watching
    • samuel_tS Offline
      samuel_t
      What's new in 0.0.3 version?
      • Node adding process was enhanced: one can place new nodes quicker!
      • One can extract vectors and points from active model via context menu.
      • In "Calculate" nodes, one can use rand function to get random numbers.
      • As soon a material or a layer is added or removed: Nodes Editor reloads.
      • A door is available in examples schemas. Thanks Simon Joubert for this.
      • Although it's not recommended, one can read/edit .schema files easier.
      Download latest Parametric Modeling plugin from the SketchUcation PluginStore.
      • Didier BurD Offline
        Didier Bur
        Hi Samuel,
        First thank you for this stunning plugin ๐Ÿ˜ฎ
        Just downloaded and installed v0.0.2 (v0.0.1 was working OK, apart from several Bug Splats) but this time the dialog is blank. Any idea ? (maybe I must uninstall v0.0.1 prior to installing v0.0.2 ?)
        DB
          Didier Bur
          @samuel,
          ๐Ÿ˜ ๐Ÿ‘ it works now ! Thanks for the tip
          DB
          • samuel_tS Offline
            samuel_t
            Hi Didier,
            Try to remove it manually then install its 0.0.3 version (released today). Tell me if problem persists.
            • samuel_tS Offline
              samuel_t
              Great! You're welcome ๐Ÿ˜‰
                Robin Morritt
                Samuel:
                I don't understand this plugin, but I've just downloaded it and donated ยฃ5 because it looks like an amazing development. I saw your thread on the SketchUp Community Forum - and I spotted the word Eneroth in the description. It has all the hallmarks of Trimble royalty.
                A couple of suggestions, if I may. 1) Place plenty of strategic links to the relevant Sketchucation Forum for those of us who struggle with this site's navigation. 2) Provide users with more options to contribute. I find SubscribeStar user friendly and non-intrusive, for example. Getting ยฃ5 out of me is like getting blood out of a stone, but it is something I quite like to do, and appreciate it when people overcome their natural shyness of pointing out that free stuff isn't entirely free and give me options.
                I'm just some old bloke who talks too much. Apologies for that.
                Congratulations and best wishes for the success of your gamechanging plugin.
                Robin.
                • samuel_tS Offline
                  samuel_t
                  @robin morritt said:
                  Samuel:
                  Robin.
                  Hello Robin,
                  Even if I develop this plugin because it's a fun challenge, donations of any amount are always welcome ๐Ÿ˜‰ So thanks!
                    lelam11234
                    Hi Samuel
                    I have a couple of suggestions.
                    1. When we choose a wire, it is brighter to make it easy discriminate from.
                    2. We need a node to Hide/unhide block (such as Box, Cylinder,...).
                    3. We need a node like Number node but it is List style
                      Robin Morritt
                      I am trying to create a universal nut and bolt modeller using the amazing Parametric Modeling.
                      I've been trying to "Subtract" threads from a cylinder.
                      If I route the group "Move" -> "Subtract solids", as screenshot, then the first prism is subtracted.
                      If I route the group "Move" -> "Make group" -> "Subtract solids", the "XYZ" group is ungrouped.
                      If I route the group "Move" -> "Select" -> "Subtract solids", then various interesting things happen.
                      I really haven't got the foggiest idea how to use "Select".
                      Is there somewhere I can get a bit of background on how to use it?
                      Parametric Model F.skp
                      • samuel_tS Offline
                        samuel_t
                        [attachment=0:tvug2vb0]<!-- ia0 -->Screenshot 2021-03-30 012046.png<!-- ia0 -->[/attachment:tvug2vb0]
                        Interesting project ๐Ÿ˜„ Only place I know where you can find some infos about "Select" is documentation.
                          Robin Morritt
                          Many thanks for the quick response.
                            Robin Morritt
                            Hi Samuel: ๐Ÿ˜„
                            I'm pressing on with my universal metric thread modeller.
                            Should I report issues using Github Issues?
                            Or would you prefer us to use this forum?
                            Thanks,
                            Robin. ๐Ÿ‘
                            12 segment M6 x 1. Work in progress.
                            • samuel_tS Offline
                              samuel_t
                              Hi Samuel: ๐Ÿ˜„
                              Thanks,
                              Robin. ๐Ÿ‘
                              Hi Robin ๐Ÿ˜„
                              GitHub has my preference.
                                ltchest
                                This is a great idea - the tool looks really intuitive ! Keep up the good work ๐Ÿ˜„
                                Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                                RTX2070 + GTX1080, Driver 472.12
                                  sgouross
                                  Honestly my dear friend, i have no words to describe your amazing work, great tool , that I belive that can do magic with a few additions, a huge RESPECT. Please add some more functions like Flip, mirror, offset, follow me, again BRAVO fro your amazing talent and effort
                                  • samuel_tS Offline
                                    samuel_t
                                    0.0.4 version is available on the SketchUcation PluginStore! I'll publish changelog as soon as possible.
                                      Robin Morritt
                                      V0.0.4 is a great advance.
                                      Looks like I'm going to have to go back to the drawing board with my universal parametric thread modeller. ๐Ÿ˜ข ๐Ÿคฃ The Extract Shape and Concatenate features are major enhancements, and just what I needed.
                                      Brilliant. Thanks! ๐Ÿ‘
                                      • samuel_tS Offline
                                        samuel_t
                                        What's new in 0.0.4 version?
                                        • One can create more complex parametric models with less efforts thanks to a new feature: Shape extraction. To do so: right-click on a group or a component in SketchUp window then select "Parametric Modeling > Extract Shape From Group/Component" entry in context menu. See new example schema: "Curved Shelf" created by Jack Tenrev.
                                        https://i.ibb.co/4Z7x6Ts/Parametric-Modeling-Sketch-Up-Plugin-Curved-Shelf-Demo.png
                                        • More nodes types are available: "Draw tube", "Tag", "Erase" and "Concatenate". If you combine "Erase", "Concatenate" and "Select" nodes: you can get variations of model. See updated example schema: "Decking On Pedestals".
                                        https://i.ibb.co/xmpmSk5/Parametric-Modeling-Sketch-Up-Plugin-Decking-On-Pedestals-Demo.gif
                                        • Plugin is more strict with numbers. If you input a decimal number where an integer is expected: an error is thrown and node becomes red. Another change: If you pass only integers to rand function: it will return an integer.
                                        • One can use random, name, material, tag and layer variables in "Query" input field inside "Select" node.
                                        • To save a few nodes, "Select" node outputs and "Draw ..." node inputs evolved.
                                        • Shapes generated with this plugin and shapes generated with SU Shapes plugin are consistent. See issue #1.
                                        • Ghost groups were eradicated?! "Add" and "Subtract" nodes were fixed again.
                                          tenrev
                                          thanks Samuel
                                          well done for this very interesting plugin and this update
                                          some examples that I realized
                                          table with chairs that are distributed according to the length of the table
                                          http://biblio3d.fr/fichiers/forum/table01.gif
                                          double-sided shelf this time
                                          http://biblio3d.fr/fichiers/forum/courbe_df.gif
                                          http://biblio3d.fr/fichiers/forum/buffet.gif
                                          http://biblio3d.fr/fichiers/forum/buffet01.gif
                                          a draft with curves in one direction then with a condition, the curve goes in another direction, interesting for making waves in the shape for shelves or benches for example
                                          http://biblio3d.fr/fichiers/forum/courbe(2).gif
                                          biblio3d forum sketchup - artlantis - piranesi
                                          http://www.biblio3d.com
                                            Robin Morritt
                                            Excellent. I look forward to seeing how I can make use of these new features in my universal thread modeller, which I can't quite get to do what I want yet. So much to do, so little time. ๐Ÿ˜„
                                            Is there any support for a Sticky Note type Node, I wonder? I think I would find it handy to be able to add comments in the Nodes Editor - yeah, the older I get, the more stuff I forget. ๐Ÿคฃ
                                            Thanks, Samuel. ๐Ÿ‘
                                            • 2 / 5
