    Interactive 3D model viewing options
    8 Posts 3 Posters 2.1k Views 3 Watching
    • grizzlerG Offline
      grizzler
      Hello fine folks of the forum. Can anyone point me in the direction of a way to allow clients to view rendered ineractive 3D versions of product models please? I regularly use panoramas to present landscaping projects, but this time I've been asked for something that would work for smaller models such as furniture, and I'd like the model to rotate around a fixed point in space so they can view any side of it and they won't get lost when viewing.
      Thanks in advance.
        Glenn at home
        Try this....
        https://boxshot.com/koru/
        • grizzlerG Offline
          grizzler
          @glenn at home said:
          Try this....
          If I can figure this out then it might just be absolutely perfect! Thank you very much indeed. πŸ’š
          • ntxdaveN Offline
            ntxdave
            Interesting. Thanks for sharing the box shot link.
            You might also want to check out sketchfab and Shapespark.
            Press F1...thank me later
            • grizzlerG Offline
              grizzler
              Sketchfab is another great one! You chaps are brilliant.
              • ntxdaveN Offline
                ntxdave
                Couple of curiosities:
                1. Does Koru work with SketchUp (.skp) files?
                2. Do you know anything about Boxshot (the company)? So far, I have not been successful in finding out anything about them.
                  Glenn at home
                  Hey Dave, I've used it before but I can't recall what file type I used. I still have it installed so I'll check.
                    Glenn at home
                    Seems to work well with DAE files from SU πŸ˜‰
                    https://i.ibb.co/HHdjG5Q/koru-arch.jpg
                    https://i.ibb.co/kmTrXDm/arch-koru-render.jpg
