    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 121.4k Views 31 Watching
    • jenujacobJ Offline
      jenujacob
      is this going to be the grasshopper for sketchup in the future??? ๐Ÿ˜ฎ ๐Ÿ‘
      • samuel_tS Offline
        samuel_t
        Let's hope ๐Ÿ˜„
          Bravo! โ˜€
          Works fine! 2017 Make for me! ๐Ÿ˜„
          https://images2.imgbox.com/de/ed/pw2wldjZ_o.gif
            tenrev
            well done Samuel
            you are the best, I installed and I will do some tests
            tenrev
            biblio3d forum sketchup - artlantis - piranesi
            http://www.biblio3d.com
              jenujacob
              A cool tutorial from tutorials Up!
                kenancakir
                Thank you.. ๐Ÿ˜
                  Kruegen
                  This is amazing!!!! Thank you so much for doing this. You have no idea how much time this will save me. Thank you!!!
                    cloo
                    Looks really cool, and a lot of work ahead.
                    Since you GPL it, do you have plans to move development to github or so and let other cool folks contribute to the progress?
                    • samuel_tS Offline
                      samuel_t
                      Yes. I will publish to GitHub the source code of this plugin in a near future.
                      • N Offline
                        numerobis
                        Very cool!
                        It would be great, if this could be made non-destructive / as modifier. But i suppose it's not possible with SketchUp to store the operations in the model/component. Maybe this could change in the future with LiveComponents...
                          lelam11234
                          Good plugin. But I have the suggestions.
                          1. Tab Number: It has an extra cell so we can name it
                          2. Tab Draw *** : It has an extra cell to Hide/Unhide
                            Thanks.
                          • srxS Offline
                            srx
                            Thank you! ๐Ÿ‘
                            www.saurus.rs
                            • samuel_tS Offline
                              samuel_t
                                Thanks.
                              Thanks for your suggestions.
                                turbodizayn
                                Is there some manual? Sounds GRATE! If it is good I will donate)))
                                • samuel_tS Offline
                                  samuel_t
                                  Help will be available from next version.
                                    jenujacob
                                    hi Samuel,
                                    Great plugin! i really hope this grows into something like GH for Rhino.
                                    now, I am no coder, and I have absolutely no idea how this thing works under the hood. But, would be it possible to click in the SU window to enter values for points instead of typing in the x.y.z coordinates?
                                    thanks!
                                      pinoy
                                      This is good! Thank you
                                      • samuel_tS Offline
                                        samuel_t
                                        @jenujacob said:
                                        hi Samuel,
                                        thanks!
                                        Hi Jacob, Thanks! I'm thinking about a "Parametric Modeling > Extract Point From Construction Point" entry in context menu when a construction point is selected in SketchUp window. This would be a shortcut to add a "Point" node.
                                        • samuel_tS Offline
                                          samuel_t
                                          What's new in 0.0.3 version?
                                          • Node adding process was enhanced: one can place new nodes quicker!
                                          • One can extract vectors and points from active model via context menu.
                                          • In "Calculate" nodes, one can use rand function to get random numbers.
                                          • As soon a material or a layer is added or removed: Nodes Editor reloads.
                                          • A door is available in examples schemas. Thanks Simon Joubert for this.
                                          • Although it's not recommended, one can read/edit .schema files easier.
                                          Download latest Parametric Modeling plugin from the SketchUcation PluginStore.
                                          • Didier BurD Offline
                                            Didier Bur
                                            Hi Samuel,
                                            First thank you for this stunning plugin ๐Ÿ˜ฎ
                                            Just downloaded and installed v0.0.2 (v0.0.1 was working OK, apart from several Bug Splats) but this time the dialog is blank. Any idea ? (maybe I must uninstall v0.0.1 prior to installing v0.0.2 ?)
                                            DB
                                            • 1 / 5
