    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 1.8.9 - 02.22.2021
      • Added a "Cedar Siding" built-in material (vertical) into the material library.
      http://design.medeek.com/resources/wallplugin/images/wall_su483_800.jpg
      http://design.medeek.com/resources/wallplugin/images/wall_su484_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.9.0 - 02.24.2021
        • Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
        design.medeek.com
        • medeekM
          medeek
          mdkBIM Introduction (Japanese - 日本語)
          A brief introduction of the mdkBIM bundle in Japanese.
          mdkBIMバンドルの日本語での簡単な紹介です。
          design.medeek.com
          • medeekM
            medeek
            Version 1.9.1 - 02.27.2021
            • Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
            http://design.medeek.com/resources/wallplugin/images/wall_su486_800.jpg
            This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
            design.medeek.com
            • medeekM
              medeek
              First look at the new Custom Beam Library. This will allow the user to create custom sized lumber, SCL or Timber beams:
              https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/0/10c6b11a1d350603d484b733907e154087f1f649_2_690x485.jpeg
              design.medeek.com
              • medeekM
                medeek
                Version 1.9.2 - 03.01.2021
                • Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
                • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
                This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
                Since glulam beams use a different sizing system I did not enable custom sizes for that beam type. Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update. If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
                design.medeek.com
                • jujuJ
                  juju
                  :: OFF TOPIC ::
                  Happy cake day Nathaniel.
                  • medeekM
                    medeek
                    Yup, I'm 49 today, my kids say I'm oooold. I'll probably still be working on this plugin when I'm 60 at the rate I'm going. 😄
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.9.2b - 03.02.2021
                      • Fixed the framing bug with the top plates of rectangular walls so that they are not cut out when a tee intersection is created with non-rectangular walls.
                      http://design.medeek.com/resources/wallplugin/images/wall_su488_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.9.2c - 03.02.2021
                        • Fixed a bug with tee intersection blocking for gable, shed and hip walls.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.9.3 - 03.03.2021
                          • Added the ability to set the lower and upper wall heights of a shed wall within the edit menu.
                          http://design.medeek.com/resources/wallplugin/images/wall_su489_800.jpg
                          Note that the relation between the upper and lower wall heights is a function of the wall length. Therefore if you adjust the wall length the menu will adjust the upper wall height while maintaining the lower wall height.
                          Adjusting the lower wall height will cause the upper wall height to be calculated, based on the current length.
                          Adjusting the upper wall height will cause the lower wall height to be calculated, based on the current length.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.9.4 - 03.05.2021
                            • Minor adjustment to the tee intersection algorithm (tee blocking and top plate cut outs) for all wall types.
                            This update addresses some issues with tee intersections and walls of differing heights. I think this latest update is an improvement over the previous algorithm however I am still open to further tuning and refinement if there is further call for it.
                            As always I appreciate the constant feedback and testing being performed by the passionate and invested user base, without this valuable feedback the plugin(s) would certainly not have advanced as far as they have.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.9.5 - 03.07.2021
                              • Added an option for "Geometry Guides" at the start and end of all wall types.
                              • Added the "Start / End Marker" parameter to the General tab of the Global Settings.
                              http://design.medeek.com/resources/wallplugin/images/wall_su490_800.jpg
                              http://design.medeek.com/resources/wallplugin/images/wall_su491_800.jpg
                              http://design.medeek.com/resources/wallplugin/images/wall_su492_800.jpg
                              The reason for this "Geometric Guide" feature is to help people understand how wall corners connect to each other (or don't connect). You can turn this on in the global settings and it will help you understand how to connect your wall panels at the ends/corners. I've had a lot of questions on wall corners lately so I hope this will help answer some of those questions.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.9.6 - 03.09.2021
                                • Added a layer for "symbols" to the miscellaneous layer/tag options (Layer tab of the Global Settings).
                                • Fixed a minor bug in the shed wall edit menu.
                                This update moves the symbols for windows, doors, garage doors, shearwalls, in-wall columns and holdowns to the "wall_symbol" layer/tag.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.9.7 - 03.12.2021
                                  • Fixed a bug involving gable, shed and hips walls that are created adjacent to rectangular walls.
                                  • Fixed a minor bug involving regeneration of dissimilar wall types at the same type.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.9.8 - 03.13.2021
                                    • Added an extra (Trim Top Plate) parameter to the "Start" and "End" configurations of rectangular walls.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su494_800.jpg
                                    **** CAUTION ****
                                    This update adds two new parameters to the rectangular walls and will require the user to delete and recreate any rectangular wall presets. This upgrade does not affect gable wall or any other presets (ie. windows, door, garage, gable wall, shed wall, hip wall).
                                    This parameter (for the start and end of the wall) should normally be assigned to a value of "YES", this is also its default behavior. However, in certain cases (such as a corner with a shed or gable wall) it may be useful to configure its value as "NO", as shown in the image above.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I’ve had some recent interest in a log siding/cladding similar to the shiplap cladding I enabled recently:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/8/8/8848f4df76b98d11aa7ecb6c0b5050cd0db5b92e.jpeg
                                      Thoughts?
                                      design.medeek.com
                                      • pbacotP
                                        Fond memories of my parents' little old cabin in Arizona (no picture handy-- no street view--still there and little changed). Is the tongue in the ship lap that thin? Maybe so. About half an inch?
                                        • medeekM
                                          medeek
                                          The example shown is not dimensional correct per se, just representative at this moment.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.9.9 - 03.20.2021
                                            • Added the ability to create custom "Log" wall cladding materials within the Material Library.
                                            • Enabled "3D" Log wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su497_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images/wall_su495_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images/wall_su496_800.jpg
                                            View model here:
                                            3D Warehouse
                                            (3dwarehouse.sketchup.com)
                                            design.medeek.com
