    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 429.9k Views 80 Watching
      jwhida
      Confirmed it works on SU 2020, though I do note that the Sketchup warehouse version of the required AMS Library is not the most recent (it is currently v3.5.2, whereas Sketchucation version is v3.6.oh)
      So make sure you use the Sketchucation files until the warehouse is also updated.
      Great work this is very useful for client presentations
      @anton_s said:
      @pipinek said:
      Greetings,
      Any chance to get an update for Su 2020?
      Thank you
      Hi! This plugin should work with SU2020 just as fine, provided you have the latest versions of the AMS Library and the Windows Settings plugins installed.
      • shake1S Offline
        shake1
        Not work in SU 2021, please check this.
        I have been using it for a very long time, i need it!
        • F Offline
          fdreise
          I recently changed my permanent license (pro 2018) into a subscription license and with the reinstall of the plugins I got the same error as Shake1. It seems to need a file from a directory which isn't created. I hope this can be fixed as it would be a terrible shame not to have this in su21.
          Thanks in advance for any help.
            pipinek
            [attachment=0:atotgh3w]<!-- ia0 -->Su 21.jpg<!-- ia0 -->[/attachment:atotgh3w]
            Greetings,
            I have been using this splendid plugin with SU 2020.
            Till now - there is a certain interference with the new RPC Archvision AVAIl Browser Utilities.
            Models from the AVAIL (RPC) browser are not permitted to be placed/dragged onto the SU Window.
            Once disabling the AMS Window Setting Plugin all works fine.
            Could it be possible to fix the issue.
            Sadly had to remove the plugin. Hope for not long time.
            Regards
              Menzip
              IT doesn't work at 2021ver. could you check it ?
              • shake1S Offline
                shake1
                Антон, хоть пару слов, - ждать совместимость с 2021?
                  Anton_S
                  Yes, sorry, update in progress. You can expect this within this month.
                    pipinek
                    Thank you very much.
                    Splendid.
                    Could you please drop a line here once its done?
                    There is a conflict between your plugin and AVAIL RPC Browser and SU plugin.
                    Once your plugin activated one cannot use the AVAIL Archvision feature.
                    Anything can be done to make them work together?
                      Anton_S
                      Splendid.
                      Hey,
                      Could you elaborate on the conflict? What is AVAIL RPC Browser?
                      Edit: I see your message above regarding the AVAIL RPC Brower drag and drop functionality. Let me know if this is fixed once I update this.
                      Thanks,
                      Anton
                        pipinek
                        @anton_s said:
                        Splendid.
                        Hey,
                        Thanks,
                        Anton
                        AVAIL Browser and SU AVAIL plugin replace the previous Archvision RPC Dashboard and SU plugin.
                        This is bank of a special kind of 3d models used within several pieces of software, Rhino, 3ds max, Sketchup, Rhino, Autocad.
                        Placing model within the program is made by drop and drag a model/proxy from the AVIL browser into the SU window.
                        Whilst your plugin is active placing a model from the AVAIL browser or SU plugin window is blocked.
                        Once removed the AVAIL works well.
                        There is undoubtedly the serious conflict between them.
                        Avail button test - ArchVision®
                        Activate Avail Account
                        ArchVision® (archvision.com)
                        PS
                        Once updated I will check it will check it with both SU 2020 and 2021.
                        I would be marvellous if there is no conflict between them.
                          Anton_S
                          Hi all,
                          Announcing version 5! Includes new UI based on React and Material UI, no longer requires AMS Library, and should be compatible with SU2021.
                          See https://sketchucation.com/forums/viewtopic.php?f=323&t=42926&p=382150#p382150
                          Best,
                          Anton
                            pipinek
                            @anton_s said:
                            Hi all,
                            Best,
                            Anton
                            Thank you for your marvellous work.
                            Alas the newest version stops as well AVAIL RPC functionality.
                            Same as before.
                            Within both Su 2020 and 2021.
                              Anton_S
                              Same as before.
                              I think I know what's going on. Can you check if the attached version works? Thanks!
                              ams_WindowSettings_v5.0.1.rbz
                              Google Docs (drive.google.com)
                                pipinek
                                Same as before.
                                Hullo,
                                It DOES work. With the newest version there is no conflict between the plugin and AVAIL RPC browser.
                                Many thanks again.
                                PS
                                As in previous version I have an issue with the toolboxes placed on the SU working space (not docked. Most of the time they are frozen. Cannot activate any icon or move them on the screen. This is very annoying.
                                With the previous version opening and close a Menu-Toolbat dialog windows or deactivate/activate an item of your plugin via the Menu resolved the problem.
                                At present several times I could make alive the toolbar only by restarting SU 2021 (samein 2020 one).
                                Sometimes it works, sometimes not.
                                One more thing - it seems whilst the plugin activated the screen toolbar tips are not showing,
                                • shake1S Offline
                                  shake1
                                  Антон, спасибо, все работает!
                                    Anton_S
                                    Does this frozen toolbars issue happen with just the FullScreen plugin installed or does it happen even without the plugin installed?
                                    Can you elaborate by active? Do you mean when the user interface window is open or when you have certain certain features hidden, e.g when hiding menu bar?
                                    I do not seem to experience either of the above, so help me understand this.
                                    By the way, glad the previous issue is resolved!
                                    • TutorialsUpT Offline
                                      TutorialsUp
                                      😍 Thank you so much for this awesome update 😮
                                      I'm facing one little problem in SketchUp 2021 it's showing in the Extension menu not windows and the is not an option for Reset I also find in Shortcut.
                                      and one request 😛
                                      can you turn on the dark mode or just invert colors for the whole sketchup including all toolbars, trays, dialogs, and menus
                                      by doing this you can save millions of eyes 😎 😍
                                      Thanks again
                                        pipinek
                                        By the way, glad the previous issue is resolved![/quote]
                                        Greetings,
                                        Only when FullScreen plugin is active/unable there is often the problem with floating toolbars and tooltips.
                                        Same occurred with the orevious version of the plugin.
                                        If this happens the icons on the floating toolbars are frozen. They do not react on clicking, the toolbar as cannot be moved aa well.
                                        The only thing that can cure it is to restart Sketchup. Often it works.
                                        This happens only when FullSreen plugin is unable.
                                        Perhaps as a brand new Sketchup element installed and its very unique quality and function Sketchup has same time to warmly and fully accept it.
                                          Anton_S
                                          @tutorialsup said:
                                          and one request 😛
                                          Dark theme is not an easy problem to solve. Besides changing the colors of the frames, you must also change many of the icons, e.g. icons that contain black edges must be changed to white or another light outline color, otherwise, it will look ugly. Besides that, trays will also need to be updated... The fonts should be changed from dark to light. Doing this would not be practical (maybe even possible) from my end. This is something that SketchUp has to do from their end. I know WinForms framework supports dark theme. If SketchUp is based on WinForms, then it shouldn't be a hard problem for them.
                                            Anton_S
                                            I moved the controls to Extensions menu intentionally. The Reset option is replaced with Apply Saved. Toggle the Apply Saved option to retain (apply saved settings) or reset (revert to original settings). The purpose for having one menu option is so that you could assign the same shortcut key to toggle between retaining and resetting.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
