    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
    • K
      khaeid
      It stopped working on Sketchup 2019, I get the following error:
      Error Loading File ams_WindowSettings.rb
      Error: #<IOError: The required, staged c extension file, "C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.5/ams_lib.so", is missing!>
      C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:199:in block in require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in each'
      C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/main.rb:129:in <top (required)>'
      C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
      C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_WindowSettings.rb:16:in `<top (required)>'
        Anton_S
        @khaeid Update to the latest version of AMS Library to rid of the error.
        • K
          khaeid
          I am already using the last version of the library 3.5.2, and I uninstalled both Library and Windows settings now and installed them again, and still have the same error
            Anton_S
            Latest version is 3.6.0: https://sketchucation.com/pluginstore?pln=ams_Lib.rbz
            • K
              khaeid
              Ah ok, Thank you, it works now, the version in Extension Warehouse was still the old one, I was downloading the library from there
              • E
                egomez121
                Thanks for this plug in! It works great on my Win7 PC! One request for me would be to have the ability to turn off the header for all the floating toolbars. I have a bunch on my secondary screen and the name headers take up a ton of room that I could utilize to better organize those floaters. Thanks again!
                • zooenZ
                  zooen
                  Hello everyone,
                  Well! it's been years that I use SU and I did not know it great plugin.
                  Thank you Anton, Bravo! ☀
                  It was while researching the procedure to follow to buy a license of Clothworks that I discovered it.
                  Zooen
                  • P
                    pipinek
                    @anton_s said:
                    updated february 10th, 2012
                    Now works on windows 7 too!!! Well, read the 1st post for an info. 😉
                    Thankyou, for your replies and comments!!! They really improved the plugin plus my English. 😄
                    Somehow, therefore, I don't strugle at the english essays anymore... ❗ :berserk: 😍
                    Greetings,
                    Any chance to get an update for Su 2020?
                    Thank you
                      Anton_S
                      @pipinek said:
                      Greetings,
                      Thank you
                      Hi! This plugin should work with SU2020 just as fine, provided you have the latest versions of the AMS Library and the Windows Settings plugins installed.
                      • P
                        pipinek
                        @anton_s said:
                        @pipinek said:
                        Greetings,
                        Thank you
                        Oh, splendid.
                        Than you.
                        Alas I have noticed one issue with the plugin.
                        Once active whilst I open/activate a toolbar it is completely frozen. As if it does exist on the screen except its visual presence there.
                        The only way to touch it with the effect is to disable/unable an option Setting-Toolbar Containers. But in that case some docked icon are slightly displaced. Have to replace them.
                        I will appreciate any piece of advice.
                        Thank you in advance.
                          Anton_S
                          @pipinek said:
                          Oh, splendid.
                          Than you.
                          Could you elaborate what's going on, perhaps with a screenshot? I am not able to quite make out what's going on.
                          • P
                            pipinek
                            @anton_s said:
                            @pipinek said:
                            Oh, splendid.
                            Than you.
                            Hello,
                            There is nothing to be illustrated. Just opened toolbar. I cannot move it (a cursor becomes white while moving it on it) no button (tools) can be clicked.
                            When I uncheck the option Toolbar Containers (via menu, as above) docked toolbars disappear and then I can move the previously dead toolbar. After checking the Toolbar Containers (menu) all seems be back to normal. Except the docked toolbars which are displaced slightly, vertically.
                            Hope it is more clear, or less confusing.
                            Thank you.
                            PS
                            The same symptoms are present on different computers with SU 2020 Pro.
                            Also after SU opened there tool tooltips are not available.
                            Switching on/of Toolbar Containetrs (menu-widows-setting) make them appeared back.
                              Anton_S
                              When you say, "toolbar", do you the Window Settings UI or any SketchUp toolbar, such as the Principal/Edit?
                              This could be due to the fact that you have the "Retain on Start" option checked, which applies your saved settings when you open SketchUp. And your save settings have the toolbar container marked as hidden. To fix this, either disable the "Retain on Start" option or "Save" the desired layout, which you would want applied when you restart Sketchup.
                              As a side note, I do realize the Window Settings UI is a little old and could use some improvements and reduction in size. I am looking forward to updating this plugin. Thanks.
                                jwhida
                                Confirmed it works on SU 2020, though I do note that the Sketchup warehouse version of the required AMS Library is not the most recent (it is currently v3.5.2, whereas Sketchucation version is v3.6.oh)
                                So make sure you use the Sketchucation files until the warehouse is also updated.
                                Great work this is very useful for client presentations
                                @anton_s said:
                                @pipinek said:
                                Greetings,
                                Thank you
                                • shake1S
                                  shake1
                                  Not work in SU 2021, please check this.
                                  I have been using it for a very long time, i need it!
                                  • F
                                    fdreise
                                    I recently changed my permanent license (pro 2018) into a subscription license and with the reinstall of the plugins I got the same error as Shake1. It seems to need a file from a directory which isn't created. I hope this can be fixed as it would be a terrible shame not to have this in su21.
                                    Thanks in advance for any help.
                                    • P
                                      pipinek
                                      [attachment=0:atotgh3w]<!-- ia0 -->Su 21.jpg<!-- ia0 -->[/attachment:atotgh3w]
                                      Greetings,
                                      I have been using this splendid plugin with SU 2020.
                                      Till now - there is a certain interference with the new RPC Archvision AVAIl Browser Utilities.
                                      Models from the AVAIL (RPC) browser are not permitted to be placed/dragged onto the SU Window.
                                      Once disabling the AMS Window Setting Plugin all works fine.
                                      Could it be possible to fix the issue.
                                      Sadly had to remove the plugin. Hope for not long time.
                                      Regards
                                        Menzip
                                        IT doesn't work at 2021ver. could you check it ?
                                        • shake1S
                                          shake1
                                          Антон, хоть пару слов, - ждать совместимость с 2021?
                                            Anton_S
                                            Yes, sorry, update in progress. You can expect this within this month.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
