    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 444.7k Views 80 Watching
    • zooenZ Online
      zooen
      Hello everyone,
      Well! it's been years that I use SU and I did not know it great plugin.
      Thank you Anton, Bravo! ☀
      It was while researching the procedure to follow to buy a license of Clothworks that I discovered it.
      Zooen
        pipinek
        @anton_s said:
        updated february 10th, 2012
        Now works on windows 7 too!!! Well, read the 1st post for an info. 😉
        Thankyou, for your replies and comments!!! They really improved the plugin plus my English. 😄
        Somehow, therefore, I don't strugle at the english essays anymore... ❗ :berserk: 😍
        Greetings,
        Any chance to get an update for Su 2020?
        Thank you
          Anton_S
          @pipinek said:
          Greetings,
          Thank you
          Hi! This plugin should work with SU2020 just as fine, provided you have the latest versions of the AMS Library and the Windows Settings plugins installed.
            pipinek
            @anton_s said:
            @pipinek said:
            Greetings,
            Thank you
            Oh, splendid.
            Than you.
            Alas I have noticed one issue with the plugin.
            Once active whilst I open/activate a toolbar it is completely frozen. As if it does exist on the screen except its visual presence there.
            The only way to touch it with the effect is to disable/unable an option Setting-Toolbar Containers. But in that case some docked icon are slightly displaced. Have to replace them.
            I will appreciate any piece of advice.
            Thank you in advance.
              Anton_S
              @pipinek said:
              Oh, splendid.
              Than you.
              Could you elaborate what's going on, perhaps with a screenshot? I am not able to quite make out what's going on.
                pipinek
                @anton_s said:
                @pipinek said:
                Oh, splendid.
                Than you.
                Hello,
                There is nothing to be illustrated. Just opened toolbar. I cannot move it (a cursor becomes white while moving it on it) no button (tools) can be clicked.
                When I uncheck the option Toolbar Containers (via menu, as above) docked toolbars disappear and then I can move the previously dead toolbar. After checking the Toolbar Containers (menu) all seems be back to normal. Except the docked toolbars which are displaced slightly, vertically.
                Hope it is more clear, or less confusing.
                Thank you.
                PS
                The same symptoms are present on different computers with SU 2020 Pro.
                Also after SU opened there tool tooltips are not available.
                Switching on/of Toolbar Containetrs (menu-widows-setting) make them appeared back.
                  Anton_S
                  When you say, "toolbar", do you the Window Settings UI or any SketchUp toolbar, such as the Principal/Edit?
                  This could be due to the fact that you have the "Retain on Start" option checked, which applies your saved settings when you open SketchUp. And your save settings have the toolbar container marked as hidden. To fix this, either disable the "Retain on Start" option or "Save" the desired layout, which you would want applied when you restart Sketchup.
                  As a side note, I do realize the Window Settings UI is a little old and could use some improvements and reduction in size. I am looking forward to updating this plugin. Thanks.
                    jwhida
                    Confirmed it works on SU 2020, though I do note that the Sketchup warehouse version of the required AMS Library is not the most recent (it is currently v3.5.2, whereas Sketchucation version is v3.6.oh)
                    So make sure you use the Sketchucation files until the warehouse is also updated.
                    Great work this is very useful for client presentations
                    @anton_s said:
                    @pipinek said:
                    Greetings,
                    Thank you
                    • shake1S Offline
                      shake1
                      Not work in SU 2021, please check this.
                      I have been using it for a very long time, i need it!
                      • F Offline
                        fdreise
                        I recently changed my permanent license (pro 2018) into a subscription license and with the reinstall of the plugins I got the same error as Shake1. It seems to need a file from a directory which isn't created. I hope this can be fixed as it would be a terrible shame not to have this in su21.
                        Thanks in advance for any help.
                          pipinek
                          [attachment=0:atotgh3w]<!-- ia0 -->Su 21.jpg<!-- ia0 -->[/attachment:atotgh3w]
                          Greetings,
                          I have been using this splendid plugin with SU 2020.
                          Till now - there is a certain interference with the new RPC Archvision AVAIl Browser Utilities.
                          Models from the AVAIL (RPC) browser are not permitted to be placed/dragged onto the SU Window.
                          Once disabling the AMS Window Setting Plugin all works fine.
                          Could it be possible to fix the issue.
                          Sadly had to remove the plugin. Hope for not long time.
                          Regards
                            Menzip
                            IT doesn't work at 2021ver. could you check it ?
                            • shake1S Offline
                              shake1
                              Антон, хоть пару слов, - ждать совместимость с 2021?
                                Anton_S
                                Yes, sorry, update in progress. You can expect this within this month.
                                  pipinek
                                  Thank you very much.
                                  Splendid.
                                  Could you please drop a line here once its done?
                                  There is a conflict between your plugin and AVAIL RPC Browser and SU plugin.
                                  Once your plugin activated one cannot use the AVAIL Archvision feature.
                                  Anything can be done to make them work together?
                                    Anton_S
                                    Splendid.
                                    Hey,
                                    Could you elaborate on the conflict? What is AVAIL RPC Browser?
                                    Edit: I see your message above regarding the AVAIL RPC Brower drag and drop functionality. Let me know if this is fixed once I update this.
                                    Thanks,
                                    Anton
                                      pipinek
                                      @anton_s said:
                                      Splendid.
                                      Hey,
                                      Thanks,
                                      Anton
                                      AVAIL Browser and SU AVAIL plugin replace the previous Archvision RPC Dashboard and SU plugin.
                                      This is bank of a special kind of 3d models used within several pieces of software, Rhino, 3ds max, Sketchup, Rhino, Autocad.
                                      Placing model within the program is made by drop and drag a model/proxy from the AVIL browser into the SU window.
                                      Whilst your plugin is active placing a model from the AVAIL browser or SU plugin window is blocked.
                                      Once removed the AVAIL works well.
                                      There is undoubtedly the serious conflict between them.
                                      https://archvision.com/avail/
                                      PS
                                      Once updated I will check it will check it with both SU 2020 and 2021.
                                      I would be marvellous if there is no conflict between them.
                                        Anton_S
                                        Hi all,
                                        Announcing version 5! Includes new UI based on React and Material UI, no longer requires AMS Library, and should be compatible with SU2021.
                                        See https://sketchucation.com/forums/viewtopic.php?f=323&t=42926&p=382150#p382150
                                        Best,
                                        Anton
                                          pipinek
                                          @anton_s said:
                                          Hi all,
                                          Best,
                                          Anton
                                          Thank you for your marvellous work.
                                          Alas the newest version stops as well AVAIL RPC functionality.
                                          Same as before.
                                          Within both Su 2020 and 2021.
                                            Anton_S
                                            Same as before.
                                            I think I know what's going on. Can you check if the attached version works? Thanks!
                                            https://drive.google.com/file/d/1mIXriTPQ0HOUOaBV9rww-fn10kGCSGoP/view?usp=sharing
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
