    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
    • shake1S
      shake1
      Антон, хоть пару слов, - ждать совместимость с 2021?
        Anton_S
        Yes, sorry, update in progress. You can expect this within this month.
        • P
          pipinek
          Thank you very much.
          Splendid.
          Could you please drop a line here once its done?
          There is a conflict between your plugin and AVAIL RPC Browser and SU plugin.
          Once your plugin activated one cannot use the AVAIL Archvision feature.
          Anything can be done to make them work together?
            Anton_S
            Splendid.
            Hey,
            Could you elaborate on the conflict? What is AVAIL RPC Browser?
            Edit: I see your message above regarding the AVAIL RPC Brower drag and drop functionality. Let me know if this is fixed once I update this.
            Thanks,
            Anton
            • P
              pipinek
              @anton_s said:
              Splendid.
              Hey,
              Thanks,
              Anton
              AVAIL Browser and SU AVAIL plugin replace the previous Archvision RPC Dashboard and SU plugin.
              This is bank of a special kind of 3d models used within several pieces of software, Rhino, 3ds max, Sketchup, Rhino, Autocad.
              Placing model within the program is made by drop and drag a model/proxy from the AVIL browser into the SU window.
              Whilst your plugin is active placing a model from the AVAIL browser or SU plugin window is blocked.
              Once removed the AVAIL works well.
              There is undoubtedly the serious conflict between them.
              Avail button test - ArchVision®
              Activate Avail Account
              ArchVision® (archvision.com)
              PS
              Once updated I will check it will check it with both SU 2020 and 2021.
              I would be marvellous if there is no conflict between them.
                Anton_S
                Hi all,
                Announcing version 5! Includes new UI based on React and Material UI, no longer requires AMS Library, and should be compatible with SU2021.
                See https://sketchucation.com/forums/viewtopic.php?f=323&t=42926&p=382150#p382150
                Best,
                Anton
                • P
                  pipinek
                  @anton_s said:
                  Hi all,
                  Best,
                  Anton
                  Thank you for your marvellous work.
                  Alas the newest version stops as well AVAIL RPC functionality.
                  Same as before.
                  Within both Su 2020 and 2021.
                    Anton_S
                    Same as before.
                    I think I know what's going on. Can you check if the attached version works? Thanks!
                    ams_WindowSettings_v5.0.1.rbz
                    Google Docs (drive.google.com)
                    • P
                      pipinek
                      Same as before.
                      Hullo,
                      It DOES work. With the newest version there is no conflict between the plugin and AVAIL RPC browser.
                      Many thanks again.
                      PS
                      As in previous version I have an issue with the toolboxes placed on the SU working space (not docked. Most of the time they are frozen. Cannot activate any icon or move them on the screen. This is very annoying.
                      With the previous version opening and close a Menu-Toolbat dialog windows or deactivate/activate an item of your plugin via the Menu resolved the problem.
                      At present several times I could make alive the toolbar only by restarting SU 2021 (samein 2020 one).
                      Sometimes it works, sometimes not.
                      One more thing - it seems whilst the plugin activated the screen toolbar tips are not showing,
                      • shake1S
                        shake1
                        Антон, спасибо, все работает!
                          Anton_S
                          Does this frozen toolbars issue happen with just the FullScreen plugin installed or does it happen even without the plugin installed?
                          Can you elaborate by active? Do you mean when the user interface window is open or when you have certain certain features hidden, e.g when hiding menu bar?
                          I do not seem to experience either of the above, so help me understand this.
                          By the way, glad the previous issue is resolved!
                          • TutorialsUpT
                            TutorialsUp
                            😍 Thank you so much for this awesome update 😮
                            I'm facing one little problem in SketchUp 2021 it's showing in the Extension menu not windows and the is not an option for Reset I also find in Shortcut.
                            and one request 😛
                            can you turn on the dark mode or just invert colors for the whole sketchup including all toolbars, trays, dialogs, and menus
                            by doing this you can save millions of eyes 😎 😍
                            Thanks again
                            • P
                              pipinek
                              By the way, glad the previous issue is resolved![/quote]
                              Greetings,
                              Only when FullScreen plugin is active/unable there is often the problem with floating toolbars and tooltips.
                              Same occurred with the orevious version of the plugin.
                              If this happens the icons on the floating toolbars are frozen. They do not react on clicking, the toolbar as cannot be moved aa well.
                              The only thing that can cure it is to restart Sketchup. Often it works.
                              This happens only when FullSreen plugin is unable.
                              Perhaps as a brand new Sketchup element installed and its very unique quality and function Sketchup has same time to warmly and fully accept it.
                                Anton_S
                                @tutorialsup said:
                                and one request 😛
                                Dark theme is not an easy problem to solve. Besides changing the colors of the frames, you must also change many of the icons, e.g. icons that contain black edges must be changed to white or another light outline color, otherwise, it will look ugly. Besides that, trays will also need to be updated... The fonts should be changed from dark to light. Doing this would not be practical (maybe even possible) from my end. This is something that SketchUp has to do from their end. I know WinForms framework supports dark theme. If SketchUp is based on WinForms, then it shouldn't be a hard problem for them.
                                  Anton_S
                                  I moved the controls to Extensions menu intentionally. The Reset option is replaced with Apply Saved. Toggle the Apply Saved option to retain (apply saved settings) or reset (revert to original settings). The purpose for having one menu option is so that you could assign the same shortcut key to toggle between retaining and resetting.
                                    Anton_S
                                    Would it be possible for you to test the FullScreen plugin without AVAIL RPC installed? It can be the case that there is an additional conflict between two of these plugins.
                                    No, that is not the case. SketchUp does not work like an immune system.
                                    • simjoubertS
                                      simjoubert
                                      Hello and thank you for this plugin which will facilitate and improve the transition from modeling to customer presentation!
                                      The number of plugins in my toolbar has grown without my being able to get rid of a single one! Can you imagine saving different toolbar configurations to switch from one working environment to another depending on the state of play of the model. Modeling, texturing, Animation, Render, ...
                                      thanks again
                                      Bonjour et merci pour ce plugin qui va faciliter et améliorer le passage modélisation à la présentation client !
                                      Le nombre de plugins dans ma barre d'outils grossi sans que je puisse me défaire d'un seul ! Pouvez vous imaginer l'enregistrement de différente configurations de barre outils pour passer d'un environnement de travail à un autres selon l'atat d'avancement du modèle. Modélisation, texturing, Animation, Render,...
                                      Merci encore
                                        DanBie
                                        Great. Good job! 😄
                                          RoCas777
                                          I have installed the plugin on SketchUp but I can't find the toolbar or the settings on Extensions menu or anywhere else 😞 😞 anyboydy had the same trouble and know how to fix it???
                                          Cheers!
                                            Read the first post in this thread. It clearly states it does not work on Mac.
                                            It also indicates that in the Extension Store entry.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
