    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 1.8.1c - 01.20.2021
      • Enabled "animated" opening and closing of single and double man doors.
      • Enabled "animated" opening and closing of garage doors.
      https://aws1.discourse-cdn.com/sketchup/original/3X/6/e/6e1fe89dabe5b006e85d8c11c49f02ef90c3b857.gif
      https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/81d3a1a430666e5ced03c7bab0be11f1364c5c8f.gif
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Tutorial 18 - Gable Walls (18:05 min.)
        design.medeek.com
        • medeekM Offline
          medeek
          I will work on adding in a second sheathing layer and organizing the draw and edit menus a bit better:
          https://aws1.discourse-cdn.com/sketchup/original/3X/9/9/990b325c62b4ea95550bd8f28ce44a962c3ba9c9.jpeg
          https://aws1.discourse-cdn.com/sketchup/original/3X/4/a/4ac12942ad422aa7b9dc8954349d34714150d7c5.jpeg
          design.medeek.com
          • medeekM Offline
            medeek
            First look at an exterior wall with the second layer of sheathing material installed. In this case I have chosen foam insulation as the material:
            https://aws1.discourse-cdn.com/sketchup/original/3X/2/3/23e4bb05750b5882a22d31233c45c40fc78b77e1.jpeg
            design.medeek.com
            • medeekM Offline
              medeek
              Either layer can be any of the typical sheathing materials as well as custom materials from the Material Library.
              You can use Zip Sheathing on Layer 2 and insulation on Layer 1 as shown:
              https://aws1.discourse-cdn.com/sketchup/optimized/3X/3/4/3469e57538be0133d5964ff97bdf28895eede197_2_656x500.jpeg
              *Cladding layer turned off for visibility.
              ** Each sheathing layer is set to "LAP" at the corners.
              design.medeek.com
              • medeekM Offline
                medeek
                A couple more possible permutations:
                https://aws1.discourse-cdn.com/sketchup/original/3X/3/a/3a9fe6adb59c0464bdc9eb2ee4f87df16c9149e4.jpeg
                https://aws1.discourse-cdn.com/sketchup/original/3X/c/8/c8856adeb6ba43ee82e855cc15364c6b7d84db4b.jpeg
                If you turn off layer 1 of the sheathing the 2nd layer will be installed as if the first layer existed which allows one to introduce an air gap (equal to the thickness of layer 1) between the sheathing and framing.
                The second example shows an air gap between the framing and sheathing and an air gap between the sheathing and cladding (via the cladding air gap parameter).
                Now I just need to do a whole ton of error checking to make sure all of the other routines for placing doors, windows, trim, quoins, and annotations all work seamlessly when this second layer of sheathing is invoked. It will be another 2-3 days of tedious checking and testing, at a minimum.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.8.2 - 01.26.2021
                  • Enabled a second layer of sheathing for exterior rectangular walls.
                  • Added four additional parameters to the Sheathing tab of the Global Settings.
                  !!! CAUTION !!!
                  Upgrading from all previous versions of the wall plugin to this version (1.8.2) will require that all rectangular wall presets be deleted and recreated. Please do not upgrade to this latest version until you understand the implications of this upgrade. Also note that the 2nd layer of sheathing has not been implemented for gable, shed or hip wall types, only for rectangular walls.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    As I was wrapping things up today with the new release (Version 1.8.2) I got yet another email requesting steel studs be incorporated into the plugin.
                    With a bit of clever manipulations of some basic materials applied to certain faces you can create a fairly realistic looking steel stud (also one face is hidden):
                    https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/813cb19032b5147f251f57a0c3ce45250fa2613e.jpeg
                    View model here:
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    The problem I see with this is that the stud lengths are really not the correct lengths that the steel studs would be. The other major issue is that the around openings the configuration of steel studs with steel headers is a bit more complex than a standard wood framed wall.
                    So barring major changes to the code the best I can probably do right now is a "cosmetic" steel framed wall. To do this properly would require entirely new algorithms for bottom and top channels, steel headers and the proper configuration of the king stud to header connections.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.8.2b - 01.27.2021
                      • Enabled a second layer of sheathing for exterior gable walls.
                      http://design.medeek.com/resources/wallplugin/images/wall_su472_800.jpg
                      I only have the hip and shed walls left to update.
                      !!! CAUTION !!!
                      Installing this update will require that you delete and recreate any GABLE wall presets that you have previously configured. This update will not affect any rectangular, shed or hip wall presets.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.8.2c - 01.28.2021
                        • Enabled a second layer of sheathing for exterior shed and hip walls.
                        http://design.medeek.com/resources/wallplugin/images/wall_su473_800.jpg
                        !!! CAUTION !!!
                        Installing this update will require that you delete and recreate any HIP or SHED wall presets that you have previously configured. This update will not affect any rectangular or gable wall presets.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          This completes all of the upgrades necessary to enable the 2nd sheathing layer for all wall types. A tedious but necessary process, over 30 files where updated in the code but only four actual parameters added to the wall types.
                          Some minor cosmetic updates to the draw and edit menus of all the wall types. Hopefully the advanced options section is a bit easier on the eyes now and a bit more organized. All of these parameters can get a bit overwhelming at times even for myself, however each one is necessary so we can’t just wash our hands of them.
                          I may take a bit of a break today from the code but at the same time I’m chomping at the bit to at least get some sort of “Wall Dropper” tool up and running since I don’t think it would be that hard to implement and I do think it would be very useful.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.8.3 - 01.31.2021
                            • Added pocket doors to the door module.
                            http://design.medeek.com/resources/wallplugin/images/PKT1.gif
                            http://design.medeek.com/resources/wallplugin/images/wall_su474_800.jpg
                            The pocket door algorithm is based on the 1500 series Johnson Hardware Pocket Door Frames:
                            Pocket Door Hardware | Johnsonhardware.com | Sliding | Folding | Pocket Door Hardware
                            Johnson Hardware Pocket Door Hardware
                            (johnsonhardware.com)
                            I am not modeling all of the details of the door assembly such as the steel studs or the track and jamb brackets, however I am modeling the prefabricated (wood) frame header assembly.
                            View model here:
                            3D Warehouse
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at a 4 Panel Bifold (closet) Door:
                              https://aws1.discourse-cdn.com/sketchup/optimized/3X/4/d/4d8702a0145ba9f841dc28c9d4cb304e373ce229_2_688x500.jpeg
                              View model here:
                              3D Warehouse
                              I still need to come up with the 2D symbol at the base of the door and even a more interesting problem is the opening algorithm for this door type.
                              The two outer panels are simple, they are merely a rotation just like a standard swing door. The inner panels on the other hand not only rotate but they also translate in relation to the outer panels since a hinge constrains them at that point. I like these kinds of "hard" problems.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at a 4 panel bifold door being opened and closed:
                                http://design.medeek.com/resources/wallplugin/images/BF4.gif
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.8.4 - 02.02.2021
                                  • Added bifold (4 panel - solid) doors to the door module.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su476_800.jpg
                                  You can also add a threshold if used as an exterior door however I don't have a lot of options yet for exterior applications (ie. full glass). For now these are primarily for closet doors.
                                  You can also switch which side the doors face by choosing LH INT or LH EXT. For the four panel bifold it doesn't matter whether you choose LH or RH, it essentially ignores the handedness of the parameter.
                                  I still need to add in the 2 panel variant and then I think we will have most of the basics covered as far as doors are concerned, at least for now. Really exotic stuff will be up to the user to add into a framed opening (which I can provide).
                                  The door opening algorithm was a bit more challenging than everything encountered thus far but after a couple of hours tinkering it finally came together.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.8.4b - 02.03.2021
                                    • Added bifold (2 panel - solid) doors to the door module.
                                    http://design.medeek.com/resources/wallplugin/images/BF2.gif
                                    There are four possibilities for a 2 panel bifold door:
                                    LH OUT, LH IN, RH OUT, RH IN
                                    Whereas there is only two possibilities for a 4 panel bifold door: OUT or IN
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      I think I'm going to the call the "eyedropper" tool the "Copy Wall" tool. One additional icon will be added to the "Medeek Wall Tools" toolbar:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/761d77044005bf7e5bc8ffd5ab0c833ada679c3f.jpeg
                                      I know, I will hear it from everyone about the proliferation of more icons. However, there is an extension out there that allows you to customize the actual toolbars if you feel the need to:
                                      SketchUp Extension Warehouse
                                      Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                      (extensions.sketchup.com)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.8.5 - 02.07.2021
                                        • Enabled the "Wall Copy" tool within the Medeek Wall Tools toolbar.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su477_800.jpg
                                        Note I've only enabled this tool for rectangular walls. After I am fully confident that it is working well and I've addressed any bugs or issues I will set it up for all the other (gable,shed and hip) wall types.
                                        Please try out this new tool and provide any feedback or comments directly to nathan@medeek.com
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I think the new Copy Wall tool will prove to be quite useful. As I am thinking about it this morning I realized that a similar tool for Doors and Windows would also be quite useful.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.8.5b - 02.08.2021
                                            • Fixed a bug with the top plate cut out algorithm when walls meet in a "cross" configuration.
                                            http://design.medeek.com/resources/wallplugin/images/CROSS_WALL.gif
                                            Each wall teeing into the primary wall has had its corner offset set to 1/2 the thickness of the primary wall.
                                            design.medeek.com
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 74
                                            • 75
                                            • 57 / 75
