    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.4m Views 28 Watching
    • medeekM Offline
      medeek
      I've been meaning to add the sliding glass door type for a while but it always seems to get pushed back due to some other priority. So tonight I hammered out the final details and I will work on adding it as an additional door type.
      I am using Andersen's 100 series (no flange) sliding glass door as the template. This should provide a fairly universal option for a sliding glass door. More exotic options can always be inserted by the user.
      Initially I will disable sidelites and transoms for this door type however I will probably add those options in at a later date as they are requested.
      My quick and dirty diagram outlining the dimensions for this door type:
      https://aws1.discourse-cdn.com/sketchup/optimized/3X/c/e/cea119c40efc2c6f710ed79ae66a427e94205560_2_386x500.jpeg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        First look at a sliding glass door:
        https://aws1.discourse-cdn.com/sketchup/original/3X/5/2/522d8c5c8c6d0c293b65a3172ad80db25b4515af.gif
        Note that sliding glass doors are quite a bit different from regular swing doors, obviously they slide when opened (not rotate). However, there are also other parameters in the draw and edit menu that are not applicable.
        The SLD can be specified as a left or right hand door.
        I have not yet enabled sidelites or transoms for this door type. Additionally, only rectangular door geometry is allowed for this door type.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.8.1 - 01.18.2021
          • Added sliding glass doors to the door module.
          http://design.medeek.com/resources/wallplugin/images/wall_su458_800.jpg
          http://design.medeek.com/resources/wallplugin/images/wall_su459_800.jpg
          This item has been on the todo list for far too long. I'm excited to finally get it out the door, no pun intended.
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.8.1b - 01.19.2021
            • Added an "Animation" parameter to the General tab of the Global Settings.
            • Enabled "animated" opening and closing of sliding glass doors.
            http://design.medeek.com/resources/wallplugin/images/wall_su460_800.jpg
            https://aws1.discourse-cdn.com/sketchup/original/3X/7/0/706eeaf4523499586f125b8e0e19b44bb08e0c5b.gif
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.8.1c - 01.20.2021
              • Enabled "animated" opening and closing of single and double man doors.
              • Enabled "animated" opening and closing of garage doors.
              https://aws1.discourse-cdn.com/sketchup/original/3X/6/e/6e1fe89dabe5b006e85d8c11c49f02ef90c3b857.gif
              https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/81d3a1a430666e5ced03c7bab0be11f1364c5c8f.gif
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 18 - Gable Walls (18:05 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  I will work on adding in a second sheathing layer and organizing the draw and edit menus a bit better:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/9/9/990b325c62b4ea95550bd8f28ce44a962c3ba9c9.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/4/a/4ac12942ad422aa7b9dc8954349d34714150d7c5.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at an exterior wall with the second layer of sheathing material installed. In this case I have chosen foam insulation as the material:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/2/3/23e4bb05750b5882a22d31233c45c40fc78b77e1.jpeg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Either layer can be any of the typical sheathing materials as well as custom materials from the Material Library.
                      You can use Zip Sheathing on Layer 2 and insulation on Layer 1 as shown:
                      https://aws1.discourse-cdn.com/sketchup/optimized/3X/3/4/3469e57538be0133d5964ff97bdf28895eede197_2_656x500.jpeg
                      *Cladding layer turned off for visibility.
                      ** Each sheathing layer is set to "LAP" at the corners.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        A couple more possible permutations:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/3/a/3a9fe6adb59c0464bdc9eb2ee4f87df16c9149e4.jpeg
                        https://aws1.discourse-cdn.com/sketchup/original/3X/c/8/c8856adeb6ba43ee82e855cc15364c6b7d84db4b.jpeg
                        If you turn off layer 1 of the sheathing the 2nd layer will be installed as if the first layer existed which allows one to introduce an air gap (equal to the thickness of layer 1) between the sheathing and framing.
                        The second example shows an air gap between the framing and sheathing and an air gap between the sheathing and cladding (via the cladding air gap parameter).
                        Now I just need to do a whole ton of error checking to make sure all of the other routines for placing doors, windows, trim, quoins, and annotations all work seamlessly when this second layer of sheathing is invoked. It will be another 2-3 days of tedious checking and testing, at a minimum.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.8.2 - 01.26.2021
                          • Enabled a second layer of sheathing for exterior rectangular walls.
                          • Added four additional parameters to the Sheathing tab of the Global Settings.
                          !!! CAUTION !!!
                          Upgrading from all previous versions of the wall plugin to this version (1.8.2) will require that all rectangular wall presets be deleted and recreated. Please do not upgrade to this latest version until you understand the implications of this upgrade. Also note that the 2nd layer of sheathing has not been implemented for gable, shed or hip wall types, only for rectangular walls.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            As I was wrapping things up today with the new release (Version 1.8.2) I got yet another email requesting steel studs be incorporated into the plugin.
                            With a bit of clever manipulations of some basic materials applied to certain faces you can create a fairly realistic looking steel stud (also one face is hidden):
                            https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/813cb19032b5147f251f57a0c3ce45250fa2613e.jpeg
                            View model here:
                            3D Warehouse
                            The problem I see with this is that the stud lengths are really not the correct lengths that the steel studs would be. The other major issue is that the around openings the configuration of steel studs with steel headers is a bit more complex than a standard wood framed wall.
                            So barring major changes to the code the best I can probably do right now is a "cosmetic" steel framed wall. To do this properly would require entirely new algorithms for bottom and top channels, steel headers and the proper configuration of the king stud to header connections.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.8.2b - 01.27.2021
                              • Enabled a second layer of sheathing for exterior gable walls.
                              http://design.medeek.com/resources/wallplugin/images/wall_su472_800.jpg
                              I only have the hip and shed walls left to update.
                              !!! CAUTION !!!
                              Installing this update will require that you delete and recreate any GABLE wall presets that you have previously configured. This update will not affect any rectangular, shed or hip wall presets.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.8.2c - 01.28.2021
                                • Enabled a second layer of sheathing for exterior shed and hip walls.
                                http://design.medeek.com/resources/wallplugin/images/wall_su473_800.jpg
                                !!! CAUTION !!!
                                Installing this update will require that you delete and recreate any HIP or SHED wall presets that you have previously configured. This update will not affect any rectangular or gable wall presets.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  This completes all of the upgrades necessary to enable the 2nd sheathing layer for all wall types. A tedious but necessary process, over 30 files where updated in the code but only four actual parameters added to the wall types.
                                  Some minor cosmetic updates to the draw and edit menus of all the wall types. Hopefully the advanced options section is a bit easier on the eyes now and a bit more organized. All of these parameters can get a bit overwhelming at times even for myself, however each one is necessary so we can’t just wash our hands of them.
                                  I may take a bit of a break today from the code but at the same time I’m chomping at the bit to at least get some sort of “Wall Dropper” tool up and running since I don’t think it would be that hard to implement and I do think it would be very useful.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.8.3 - 01.31.2021
                                    • Added pocket doors to the door module.
                                    http://design.medeek.com/resources/wallplugin/images/PKT1.gif
                                    http://design.medeek.com/resources/wallplugin/images/wall_su474_800.jpg
                                    The pocket door algorithm is based on the 1500 series Johnson Hardware Pocket Door Frames:
                                    Pocket Door Hardware | Johnsonhardware.com | Sliding | Folding | Pocket Door Hardware
                                    Johnson Hardware Pocket Door Hardware
                                    (johnsonhardware.com)
                                    I am not modeling all of the details of the door assembly such as the steel studs or the track and jamb brackets, however I am modeling the prefabricated (wood) frame header assembly.
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      First look at a 4 Panel Bifold (closet) Door:
                                      https://aws1.discourse-cdn.com/sketchup/optimized/3X/4/d/4d8702a0145ba9f841dc28c9d4cb304e373ce229_2_688x500.jpeg
                                      View model here:
                                      3D Warehouse
                                      I still need to come up with the 2D symbol at the base of the door and even a more interesting problem is the opening algorithm for this door type.
                                      The two outer panels are simple, they are merely a rotation just like a standard swing door. The inner panels on the other hand not only rotate but they also translate in relation to the outer panels since a hinge constrains them at that point. I like these kinds of "hard" problems.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at a 4 panel bifold door being opened and closed:
                                        http://design.medeek.com/resources/wallplugin/images/BF4.gif
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.8.4 - 02.02.2021
                                          • Added bifold (4 panel - solid) doors to the door module.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su476_800.jpg
                                          You can also add a threshold if used as an exterior door however I don't have a lot of options yet for exterior applications (ie. full glass). For now these are primarily for closet doors.
                                          You can also switch which side the doors face by choosing LH INT or LH EXT. For the four panel bifold it doesn't matter whether you choose LH or RH, it essentially ignores the handedness of the parameter.
                                          I still need to add in the 2 panel variant and then I think we will have most of the basics covered as far as doors are concerned, at least for now. Really exotic stuff will be up to the user to add into a framed opening (which I can provide).
                                          The door opening algorithm was a bit more challenging than everything encountered thus far but after a couple of hours tinkering it finally came together.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.8.4b - 02.03.2021
                                            • Added bifold (2 panel - solid) doors to the door module.
                                            http://design.medeek.com/resources/wallplugin/images/BF2.gif
                                            There are four possibilities for a 2 panel bifold door:
                                            LH OUT, LH IN, RH OUT, RH IN
                                            Whereas there is only two possibilities for a 4 panel bifold door: OUT or IN
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 78
                                            • 79
                                            • 50 / 79
