    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      An example of the CVS output loaded into Excel:
      https://aws1.discourse-cdn.com/sketchup/optimized/3X/b/e/be6f5247d992edee9cbb5a51eb9ed97acd4711c9_2_690x281.jpeg
      Notice that have switched the order of some of the parameters to a more logical order.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.7.8 - 01.03.2021
        • Added the Shearwall Schedule tool to the SW toolbar.
        http://design.medeek.com/resources/images/wall_sw_su_menu_active.jpg
        design.medeek.com
        • medeekM
          medeek
          First look at shearwall blocking:
          https://aws1.discourse-cdn.com/sketchup/original/3X/1/7/17f54ca6638901684f67308b114974863260975c.jpeg
          Note that in this example the blocking has been rotated 90 degrees. The rotation parameter allow for zero or 90 deg. rotation. Also note that any number of rows of blocks can be specified. In this case I had a 12' wall so I went with blocking at 4' and 8' (48,96).
          Each shearwall panel can have its own blocking which is independent from other shearwalls and is also independent of any general wall blocking.
          design.medeek.com
          • medeekM
            medeek
            Version 1.7.9 - 01.05.2021
            • Enabled blocking within the shearwall module.
            http://design.medeek.com/resources/wallplugin/images/wall_su454_800.jpg
            The blocking module algorithm for shearwalls was a bit more of hassle than I had hoped but after about 16 hours of scratching my head I managed to cobble it together. I'm fairly happy and confident with the results but I am sure there will be a few cases where it may need further refinement. The true debugging process really only starts now as I hand it over to the customer to use in real design situations.
            I've beaten the Shearwall "horse" for about a week now (Dec. 27th - Jan. 5th), I do have more engineering work that can be done but I think I will probably give it a rest for a while and move on to other hot items within the Truss plugin.
            If you have additional items that you would like to see added to this module please feel free to send me an email. I am much more likely to address follow up items when the programming is still fresh on my mind. A month from now it will take more effort to dig back into the shearwall module and add or improve existing features.
            design.medeek.com
            • medeekM
              medeek
              Version 1.7.9b - 01.05.2021
              • Added the following Simpson Strong-Tie holdowns to the shearwall module: HTT4, HTT5, HDQ8.
              http://design.medeek.com/resources/wallplugin/images/wall_su455_800.jpg
              Added per customer request.
              design.medeek.com
              • medeekM
                medeek
                Version 1.7.9c - 01.09.2021
                • Added the following Simpson Strong-Tie holdowns to the shearwall module: HHDQ11, HHDQ14.
                http://design.medeek.com/resources/wallplugin/images/wall_su456_800.jpg
                Another customer request.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.8.0 - 01.16.2021
                  • Added a "Remove Cladding Lines" option within the global settings.
                  http://design.medeek.com/resources/wallplugin/images/wall_su457_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    I've been meaning to add the sliding glass door type for a while but it always seems to get pushed back due to some other priority. So tonight I hammered out the final details and I will work on adding it as an additional door type.
                    I am using Andersen's 100 series (no flange) sliding glass door as the template. This should provide a fairly universal option for a sliding glass door. More exotic options can always be inserted by the user.
                    Initially I will disable sidelites and transoms for this door type however I will probably add those options in at a later date as they are requested.
                    My quick and dirty diagram outlining the dimensions for this door type:
                    https://aws1.discourse-cdn.com/sketchup/optimized/3X/c/e/cea119c40efc2c6f710ed79ae66a427e94205560_2_386x500.jpeg
                    design.medeek.com
                    • medeekM
                      medeek
                      First look at a sliding glass door:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/5/2/522d8c5c8c6d0c293b65a3172ad80db25b4515af.gif
                      Note that sliding glass doors are quite a bit different from regular swing doors, obviously they slide when opened (not rotate). However, there are also other parameters in the draw and edit menu that are not applicable.
                      The SLD can be specified as a left or right hand door.
                      I have not yet enabled sidelites or transoms for this door type. Additionally, only rectangular door geometry is allowed for this door type.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.8.1 - 01.18.2021
                        • Added sliding glass doors to the door module.
                        http://design.medeek.com/resources/wallplugin/images/wall_su458_800.jpg
                        http://design.medeek.com/resources/wallplugin/images/wall_su459_800.jpg
                        This item has been on the todo list for far too long. I'm excited to finally get it out the door, no pun intended.
                        View model here:
                        3D Warehouse
                        (3dwarehouse.sketchup.com)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.8.1b - 01.19.2021
                          • Added an "Animation" parameter to the General tab of the Global Settings.
                          • Enabled "animated" opening and closing of sliding glass doors.
                          http://design.medeek.com/resources/wallplugin/images/wall_su460_800.jpg
                          https://aws1.discourse-cdn.com/sketchup/original/3X/7/0/706eeaf4523499586f125b8e0e19b44bb08e0c5b.gif
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.8.1c - 01.20.2021
                            • Enabled "animated" opening and closing of single and double man doors.
                            • Enabled "animated" opening and closing of garage doors.
                            https://aws1.discourse-cdn.com/sketchup/original/3X/6/e/6e1fe89dabe5b006e85d8c11c49f02ef90c3b857.gif
                            https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/81d3a1a430666e5ced03c7bab0be11f1364c5c8f.gif
                            design.medeek.com
                            • medeekM
                              medeek
                              Tutorial 18 - Gable Walls (18:05 min.)
                              design.medeek.com
                              • medeekM
                                medeek
                                I will work on adding in a second sheathing layer and organizing the draw and edit menus a bit better:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/9/9/990b325c62b4ea95550bd8f28ce44a962c3ba9c9.jpeg
                                https://aws1.discourse-cdn.com/sketchup/original/3X/4/a/4ac12942ad422aa7b9dc8954349d34714150d7c5.jpeg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  First look at an exterior wall with the second layer of sheathing material installed. In this case I have chosen foam insulation as the material:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/2/3/23e4bb05750b5882a22d31233c45c40fc78b77e1.jpeg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Either layer can be any of the typical sheathing materials as well as custom materials from the Material Library.
                                    You can use Zip Sheathing on Layer 2 and insulation on Layer 1 as shown:
                                    https://aws1.discourse-cdn.com/sketchup/optimized/3X/3/4/3469e57538be0133d5964ff97bdf28895eede197_2_656x500.jpeg
                                    *Cladding layer turned off for visibility.
                                    ** Each sheathing layer is set to "LAP" at the corners.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      A couple more possible permutations:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/3/a/3a9fe6adb59c0464bdc9eb2ee4f87df16c9149e4.jpeg
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/c/8/c8856adeb6ba43ee82e855cc15364c6b7d84db4b.jpeg
                                      If you turn off layer 1 of the sheathing the 2nd layer will be installed as if the first layer existed which allows one to introduce an air gap (equal to the thickness of layer 1) between the sheathing and framing.
                                      The second example shows an air gap between the framing and sheathing and an air gap between the sheathing and cladding (via the cladding air gap parameter).
                                      Now I just need to do a whole ton of error checking to make sure all of the other routines for placing doors, windows, trim, quoins, and annotations all work seamlessly when this second layer of sheathing is invoked. It will be another 2-3 days of tedious checking and testing, at a minimum.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.8.2 - 01.26.2021
                                        • Enabled a second layer of sheathing for exterior rectangular walls.
                                        • Added four additional parameters to the Sheathing tab of the Global Settings.
                                        !!! CAUTION !!!
                                        Upgrading from all previous versions of the wall plugin to this version (1.8.2) will require that all rectangular wall presets be deleted and recreated. Please do not upgrade to this latest version until you understand the implications of this upgrade. Also note that the 2nd layer of sheathing has not been implemented for gable, shed or hip wall types, only for rectangular walls.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          As I was wrapping things up today with the new release (Version 1.8.2) I got yet another email requesting steel studs be incorporated into the plugin.
                                          With a bit of clever manipulations of some basic materials applied to certain faces you can create a fairly realistic looking steel stud (also one face is hidden):
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/813cb19032b5147f251f57a0c3ce45250fa2613e.jpeg
                                          View model here:
                                          3D Warehouse
                                          The problem I see with this is that the stud lengths are really not the correct lengths that the steel studs would be. The other major issue is that the around openings the configuration of steel studs with steel headers is a bit more complex than a standard wood framed wall.
                                          So barring major changes to the code the best I can probably do right now is a "cosmetic" steel framed wall. To do this properly would require entirely new algorithms for bottom and top channels, steel headers and the proper configuration of the king stud to header connections.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.8.2b - 01.27.2021
                                            • Enabled a second layer of sheathing for exterior gable walls.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su472_800.jpg
                                            I only have the hip and shed walls left to update.
                                            !!! CAUTION !!!
                                            Installing this update will require that you delete and recreate any GABLE wall presets that you have previously configured. This update will not affect any rectangular, shed or hip wall presets.
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 80
                                            • 81
                                            • 50 / 81
