    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      The casement style window is very similar (identical) to the picture style window in geometry. I guess I probably should add an option for multi-picture windows.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        ajmwd
        Thanks. I think I should clarify my statement... I was stating that Andersen shows a different glass size for Picture and Casement at the same window width. However, after reviewing their size chart documents, it appears that was just a perception of mine. Andersen size charts show both Picture and Casement windows have the SAME unobstructed glass size of...
        Width = window width βˆ’ 6.250".
        Height = window height βˆ’ 6.250".
        So the Triple Casement will be totally fine at representing Triple Picture. Thanks for the information and clarification. πŸ˜„
        • medeekM
          medeek
          I wouldn't exactly call this a schedule as much as a CSV or spread sheet with all of the shearwall data contained within it. Regardless here is a first look at the Shearwall Schedule tool (preview menu):
          https://aws1.discourse-cdn.com/sketchup/original/3X/0/f/0fb7e0842ea61f46c58c353c594b5346c8585d0d.jpeg
          Note that the preview (or HTML menu) only shows limited information. The CSV output is much more comprehensive, listing all of the parameters for the shearwall (ie. holdowns, anchor bolts, clips, blocking etc...)
          I still have not ironed out all of the details I want to show or present within this schedule tool so additional feedback will be key as to how this evolves. I will probably dig into my original shearwall calculator and figure out how to best incorporate some engineering into this tool. I think it would be useful for the tool to calculate the shear capacity of the SW given its dimensions, sheathing and nail patterns. I also think additional parameter(s) for the actual applied shear load (wind and seismic) might be useful as well, I will need to give this some more thought.
          Note that the tool is smart enough to detect if there are windows or doors within the bounds of a shearwall panel and correctly labels it with a "PERF" designation, which signifies it is a perforated shearwall.
          design.medeek.com
            ajmwd
            @medeek said:
            Wow, interesting video put out just yesterday:
            Wow, this is a bit of a crossover for me. I am VERY familiar with Matt Petrowsky from his EXTENSIVE set of FileMaker database development videos on FileMakerMagazine.com. Very interesting to see that he now also has an interest in SketchUp and particularly Medeek. Pretty cool. πŸ˜„
            • medeekM
              medeek
              An example of the CVS output loaded into Excel:
              https://aws1.discourse-cdn.com/sketchup/optimized/3X/b/e/be6f5247d992edee9cbb5a51eb9ed97acd4711c9_2_690x281.jpeg
              Notice that have switched the order of some of the parameters to a more logical order.
              design.medeek.com
              • medeekM
                medeek
                Version 1.7.8 - 01.03.2021
                • Added the Shearwall Schedule tool to the SW toolbar.
                http://design.medeek.com/resources/images/wall_sw_su_menu_active.jpg
                design.medeek.com
                • medeekM
                  medeek
                  First look at shearwall blocking:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/1/7/17f54ca6638901684f67308b114974863260975c.jpeg
                  Note that in this example the blocking has been rotated 90 degrees. The rotation parameter allow for zero or 90 deg. rotation. Also note that any number of rows of blocks can be specified. In this case I had a 12' wall so I went with blocking at 4' and 8' (48,96).
                  Each shearwall panel can have its own blocking which is independent from other shearwalls and is also independent of any general wall blocking.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.7.9 - 01.05.2021
                    • Enabled blocking within the shearwall module.
                    http://design.medeek.com/resources/wallplugin/images/wall_su454_800.jpg
                    The blocking module algorithm for shearwalls was a bit more of hassle than I had hoped but after about 16 hours of scratching my head I managed to cobble it together. I'm fairly happy and confident with the results but I am sure there will be a few cases where it may need further refinement. The true debugging process really only starts now as I hand it over to the customer to use in real design situations.
                    I've beaten the Shearwall "horse" for about a week now (Dec. 27th - Jan. 5th), I do have more engineering work that can be done but I think I will probably give it a rest for a while and move on to other hot items within the Truss plugin.
                    If you have additional items that you would like to see added to this module please feel free to send me an email. I am much more likely to address follow up items when the programming is still fresh on my mind. A month from now it will take more effort to dig back into the shearwall module and add or improve existing features.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.7.9b - 01.05.2021
                      • Added the following Simpson Strong-Tie holdowns to the shearwall module: HTT4, HTT5, HDQ8.
                      http://design.medeek.com/resources/wallplugin/images/wall_su455_800.jpg
                      Added per customer request.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.7.9c - 01.09.2021
                        • Added the following Simpson Strong-Tie holdowns to the shearwall module: HHDQ11, HHDQ14.
                        http://design.medeek.com/resources/wallplugin/images/wall_su456_800.jpg
                        Another customer request.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.8.0 - 01.16.2021
                          • Added a "Remove Cladding Lines" option within the global settings.
                          http://design.medeek.com/resources/wallplugin/images/wall_su457_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            I've been meaning to add the sliding glass door type for a while but it always seems to get pushed back due to some other priority. So tonight I hammered out the final details and I will work on adding it as an additional door type.
                            I am using Andersen's 100 series (no flange) sliding glass door as the template. This should provide a fairly universal option for a sliding glass door. More exotic options can always be inserted by the user.
                            Initially I will disable sidelites and transoms for this door type however I will probably add those options in at a later date as they are requested.
                            My quick and dirty diagram outlining the dimensions for this door type:
                            https://aws1.discourse-cdn.com/sketchup/optimized/3X/c/e/cea119c40efc2c6f710ed79ae66a427e94205560_2_386x500.jpeg
                            design.medeek.com
                            • medeekM
                              medeek
                              First look at a sliding glass door:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/5/2/522d8c5c8c6d0c293b65a3172ad80db25b4515af.gif
                              Note that sliding glass doors are quite a bit different from regular swing doors, obviously they slide when opened (not rotate). However, there are also other parameters in the draw and edit menu that are not applicable.
                              The SLD can be specified as a left or right hand door.
                              I have not yet enabled sidelites or transoms for this door type. Additionally, only rectangular door geometry is allowed for this door type.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.8.1 - 01.18.2021
                                • Added sliding glass doors to the door module.
                                http://design.medeek.com/resources/wallplugin/images/wall_su458_800.jpg
                                http://design.medeek.com/resources/wallplugin/images/wall_su459_800.jpg
                                This item has been on the todo list for far too long. I'm excited to finally get it out the door, no pun intended.
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.8.1b - 01.19.2021
                                  • Added an "Animation" parameter to the General tab of the Global Settings.
                                  • Enabled "animated" opening and closing of sliding glass doors.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su460_800.jpg
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/7/0/706eeaf4523499586f125b8e0e19b44bb08e0c5b.gif
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.8.1c - 01.20.2021
                                    • Enabled "animated" opening and closing of single and double man doors.
                                    • Enabled "animated" opening and closing of garage doors.
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/6/e/6e1fe89dabe5b006e85d8c11c49f02ef90c3b857.gif
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/8/1/81d3a1a430666e5ced03c7bab0be11f1364c5c8f.gif
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 18 - Gable Walls (18:05 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I will work on adding in a second sheathing layer and organizing the draw and edit menus a bit better:
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/9/9/990b325c62b4ea95550bd8f28ce44a962c3ba9c9.jpeg
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/4/a/4ac12942ad422aa7b9dc8954349d34714150d7c5.jpeg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          First look at an exterior wall with the second layer of sheathing material installed. In this case I have chosen foam insulation as the material:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/2/3/23e4bb05750b5882a22d31233c45c40fc78b77e1.jpeg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Either layer can be any of the typical sheathing materials as well as custom materials from the Material Library.
                                            You can use Zip Sheathing on Layer 2 and insulation on Layer 1 as shown:
                                            https://aws1.discourse-cdn.com/sketchup/optimized/3X/3/4/3469e57538be0133d5964ff97bdf28895eede197_2_656x500.jpeg
                                            *Cladding layer turned off for visibility.
                                            ** Each sheathing layer is set to "LAP" at the corners.
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 80
                                            • 81
                                            • 50 / 81
