    Texture - Bigger and Smaller?
    11 Posts 5 Posters 3.9k Views 5 Watching
      djh
      How come, when one stretches an object, the size of the texture also stretches? Officially, the width and height of the texture remain the same (Materials/Edit/Texture), yet the texture gets bigger or smaller.
        It depends upon how or when you apply the texture to the face. See my new reply below. Maybe Scale isn't the right tool for the resizing operation you're doing, though. Maybe Move or Push/Pull is more appropriate.
        • HornOxxH Offline
          HornOxx
          ...even though I have no difficulties with textures, thanks for this textures-options hint Dave - however I can't get this to work either. The texture scales only if the geometry is grouped. If I then double-click in the geometry to select this face concerned, I get the option you described, but in my case this does nothing - so I always have to use "explode" to make the texture go back to itยดs correct scaling.
          never trust a skinny cook
            Actually it depends upon if you apply the texture before or after making the component/group. It's a bit odd in the way it works.
            When you apply a material it is placed relative to the local origin. If you are texturing ungrouped geometry the texture will then be placed relative to the model origin. If you group the geometry first, then open the group for editing, the texture is applied relative to the group's origin. Here's a comparison.
            Material applied to ungrouped geometry.
            Click the picture
            Material applied to a face in a component.
            Click the picture
            Scaling of the material depends upon what it's linked to. Model axes or group/component axes.
            Click the picture
            • BoxB Offline
              You might find Tig's Descaler useful
              https://sketchucation.com/pluginstore?pln=TIG_Descaler
              • HornOxxH Offline
                HornOxx
                @ Dave: finally understood it ๐Ÿ˜„ and a well-done comparison. Thank you!
                @ Box: thank you for this really and again helpful tip! ๐Ÿ‘
                greetings and both, come well into the new year !!! โ˜€
                • BoxB Offline
                  Cheers Hornie and happy new year from 2021 as it is now here. ๐Ÿ˜ฒ
                  • HornOxxH Offline
                    HornOxx
                    ๐Ÿ‘ ๐Ÿ˜„
                    how is it ?!!? - I still have to wait 9 hours ! ๐Ÿ˜ฎ
                      HNY to all.
                      • pbacotP Offline
                        We have to wait 15 hours. How is it? Is it better over there?
                        Happy New Year!
                        • BoxB Offline
                          @hornoxx said:
                          how is it ?!!?
                          It's unbelievable, one second after midnight the pandemic disappeared, world hunger was vanquished, climate change was reversed and unicorns stopped all rainbow activity. I then checked the forum and finding no questions realised I was dreaming.
