    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • Gus RG
      Gus R
      OK, thanks.
      @medeek said:
      This should be moved to the Truss Plugin thread but correct the hip sets are not yet editable. Common trusses and other truss types are see details here:
      404 - File or directory not found.
      (design.medeek.com)
      Enter a Ctrl-F and then search for the term "edit". This will show you which assemblies have had the edit function enabled.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • medeekM
        medeek
        I have some questions about double wall construction lately.
        I don't have a specific double wall algorithm however it is possible to create double wall structures with openings using the Wall plugin in its current state, see model below for an example:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        P.S. Note how the window ext. trim and installation is enabled on the exterior wall and then the interior casing is enabled on the interior wall. I then adjusted the casing extension depth in the edit menu of the interior wall so that it extends to meet the window in the exterior wall. No manual editing and everything is still parametric.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Version 1.7.6 - 12.04.2020
          • Added a wall justification hotkey/option (Tab key) to the rectangular draw wall tool: Front, Center, Back.
          http://design.medeek.com/resources/wallplugin/images/wall_su440_800.jpg
          Note, that when the wall justification is set to "Center" or "Back" the draw tool switches from polyline mode to simple line mode, this is by design.
          design.medeek.com
          • medeekM
            medeek
            Version 1.7.6b - 12.05.2020
            • Added a wall justification hotkey/option (Tab key) to the gable, shed and hip draw wall tools: Front, Center, Back.
            • Enabled the left and right arrow keys for each of the draw wall tools in order to constrain the tool to the X or Y axis.
            http://design.medeek.com/resources/wallplugin/images/wall_su441_800.jpg
            The behavior of the draw wall tool is now similar to the native SketchUp line/edge tool.
            The right and left arrow keys will constrain the wall to the X and/or Y axis. Additionally the Ctrl key will toggle the wall to the 45 deg. and 135 deg. directions. You will notice that when the constraint is active the primary line will indicate either Red, Green, Blue (45 deg) or Purple (135 deg) and the line thickness will increase from two to three.
            design.medeek.com
            • medeekM
              medeek
              Lately I've had quite a few people asking me where they can find the video tutorials for the plugin. They are listed on the plugin web page but I guess they tend to get lost in all the content. Here is the direct link to that section:
              (design.medeek.com)
              Here is also the listing for each video:
              The following video tutorials are currently available on YouTube:
              1. Introduction - The Vision (20:58 min.)
              2. Tutorial 1 - Extension Overview (21:58 min.)
              3. Tutorial 2 - Drawing Walls (19:37 min.)
              4. Tutorial 3 - Beams and Columns (15:31 min.)
              5. Tutorial 4 - Wall Presets (8:04 min.)
              6. Tutorial 5 - Multi-Story Construction (19:58 min.)
              7. Tutorial 6 - Custom Material Library (16:11 min.)
              8. Tutorial 7 - Stairs (23:19 min.)
              9. Tutorial 8 - Gable Wall Workaround (17:25 min.)
              10. Tutorial 9 - Split Wall Tool (6:36 min.)
              11. Tutorial 10 - Posts (14:24 min.)
              12. Tutorial 11 - Split Wall Cladding (6:49 min.)
              13. Tutorial 12 - Blocking (12:42 min.)
              14. Tutorial 13 - Stretch Wall Tool (7:41 min.)
              15. Tutorial 14 - Join Wall Tool (5:54 min.)
              16. Tutorial 15 - Quoins (8:34 min.)
              17. Tutorial 16 - Garage Doors (19:17 min.)
              18. Tutorial 17 - Tag/Layer Groups (13:41 min.)
              Note, that the Gable Wall Workaround (Tutorial 😎 is now obsolete, and gable walls can now be created automatically with the plugin. At some point I should probably indicate this tutorial is deprecated.
              design.medeek.com
              • medeekM
                medeek
                Haven't look at the Shearwall Module in some time and I think it would be important to have it at least able to insert shearwall panels into the wall panels even if the engineering portion is not yet complete.
                After some thought and reviewing my AWC literature and my own Shearwall Calculator (Spreadsheet), here are my preliminary list of parameters for a shearwall panel (there can be multiple panels within a given wall).
                Basic Options:
                Name: Initially set by auto-increment value but can be modified by user.
                Start Location:
                End Location:
                Length: Determined by start and end location
                Description: Custom comments or notes by user
                Left Post:
                Left SW Post: 2x4, 2x6, (2) 2x6, 4x6, 6x6 etc...
                Quantity: 1,2,3,4
                Species: DF, HF, SP, SPF
                Left Holdown: YES/NO
                Holdown Type:
                Holdown Vert. Offset: in/mm
                Holdown AB:
                Threaded Rod Length: in/mm
                Strap Placement:
                Right Post:
                Right SW Post: 2x4, 2x6, (2) 2x6, 4x6, 6x6 etc...
                Quantity: 1,2,3,4
                Right Holdown: YES/NO
                Holdown Type:
                Holdown AB:
                Strap Placement:
                Sheathing Exterior:
                Ext. Sheathing Material: Ply, OSB, Gypsum, NONE
                Sheathing Thickness: 0.4375"
                Sheathing Fastener: 8d Common, 6d Common, 10d Common, 8d Galv Casing, 10d Galv Casing
                Field O/C Spacing: 6", 12"
                Edge O/C Spacing: 2", 3", 4", 6"
                Sheathing Interior:
                Int. Sheathing Material: Ply, OSB, Gypsum, NONE
                Sole Plate Fasteners:
                Sole Plt. Fasteners: YES/NO
                Fastener Size: 16d,SDS25412
                Fastener O/C Spacing: in/mm
                Anchor Bolts (Sill Plate Fasteners):
                Anchor Bolts: YES/NO
                Anchor Bolt Length: 10,12,14
                Anchor Bolt Dia: 1/2", 5/8"
                Washer: 2x2,3x3
                Bolt O/C Spacing: in/mm
                Edge Distance: in/mm
                Vertical Offset (default is zero)
                Blocking:
                Install Blocking: YES/NO
                Blocking Size: Single 2X, Single 3X, Double 2X
                Heights: 48|96|144 (allow the user to specify the exact height of each blocking line - in/mm)
                Top Plate Clips:
                Framing Clips: YES/NO
                Clip Type: A35, A34,LTP4, LTP5
                Cllip O/C Spacing: in/mm
                ** Let me know if you think I am missing anything.
                design.medeek.com
                • medeekM
                  medeek
                  First look at some shearwall panels (notice the absence of the shearwall posts/studs and holdowns, that is coming next) and the shearwall edit menu:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/5/a/5abd22e3480d3f21b87f2aac8437fbd61f592b87.jpeg
                  I had to take a little break from the programming over the holidays but in a space of a few hours I've mostly got the basic code for the shearwall module put together. Now I just need to sort out a few of the details.
                  I've also decided to make the shearwall panel sheathing with variable opacity since they are primarily visual in their representation of the actual shearwall sheathing. The color and opacity will be customizable within the global settings (Materials tab).
                  Initially there will be three shearwall sheathing materials (OSB, Plywood and Gypsum). Each material type will have its own unique color and opacity, all of which can be customized. This will allow the user to visually determine the shearwall sheathing material very quickly within the model.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.7.7 - 12.28.2020
                    • Enabled Draw, Edit, Move and Delete shearwall tools for all rectangular walls.
                    • Added four additional parameters to the Materials tab of the Global Settings pertaining to shearwalls.
                    http://design.medeek.com/resources/wallplugin/images/wall_su443_800.jpg
                    http://design.medeek.com/resources/wallplugin/images/wall_su444_800.jpg
                    Note, that the shearwall tools will only work with rectangular walls currently. I will enable them for gable, shed and hip walls but that may be a few more days since it gets a bit more complicated.
                    Also note that the four items within the shearwall module are currently not active yet and are still in development (probably a couple more days):
                    Sole Plate Fasteners, Anchor Bolts (Sill Plate Fasteners, SW Blocking, Top Plate Clips
                    View model here:
                    3D Warehouse
                    As this module is completely brand new I expect there will be a few bugs and items that need to be addressed or corrected moving forward. Your beta testing of this new feature and any feedback is highly appreciated.
                    design.medeek.com
                    • pbacotP
                      Impressive! Do you end up with a list of shear walls and identification by type and length?
                      • medeekM
                        medeek
                        That would be the next step.
                        It would be nice if there was a function which created a Shearwall schedule, like I make on my own structural sheets.
                        design.medeek.com
                        • medeekM
                          medeek
                          Working on the shearwall (panel) anchor bolts and sole plate fasteners.
                          First look at some anchor bolts associated with a shear wall:
                          https://aws1.discourse-cdn.com/sketchup/original/3X/f/3/f30e60bd116a04602cc53e23d7904d1dae1fb28b.jpeg
                          When a shearwall rests directly on a slab-on-grade then the anchor bolts are typically connected directly to the sole plate of the shearwall, however when the wall rests on a floor as shown then the anchor bolts will anchor the sill plate below the wall and threaded rods with coupler nuts are utilized to extend the holdown bolts up to the HDU holdowns. In this situation the engineer will also typically call out the size and spacing of fasteners that connect the sole plate of the shearwall to the rim joist below it.
                          To facilitate various wall/floor configurations the vertical and horizontal offset parameters for shearwall anchor bolts are made available for each shearwall, and can be adjusted independently.
                          P.S.
                          Looking at this image it immediately jumps out at me that a critical component within this shearwall assembly is missing. Note that I am not showing fasteners, they are too small to model for the most part. Let's see if anyone can pick it out.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.7.7b - 12.28.2020
                            • Enabled anchor bolts within the shearwall module.
                            • Enabled sole plate fasteners within the shearwall module.
                            • Enabled top plate clips within the shearwall module.
                            http://design.medeek.com/resources/wallplugin/images/wall_su446_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su447_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su448_800.jpg
                            All that is left is the specialized blocking for shearwalls.
                            design.medeek.com
                            • medeekM
                              medeek
                              I've seen both ways of handling stacked shearwall panels, however the strap method would make more sense from an economic standpoint:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/3/5/35940ec6ad50fbde3f147a4a5e261f3640b664f4.jpeg
                              https://aws1.discourse-cdn.com/sketchup/original/3X/9/0/903ab00c8c1ee58b46a194826563a16c0c163fec.jpeg
                              The main point here is that you have either option at your disposal with the new shearwall module.
                              Notice the inclusion of the top plate clips on the lower shearwall and the 16d Common fasteners in the sole plate of the upper shearwall. Both of these items are optional however if that degree of detail is required or desired it is also readily available to the designer or engineer.
                              See model here:
                              3D Warehouse
                              P.S.
                              Some of you may be scratching your head looking at all of this hardware that goes into a wall especially at a shear panel... I know, Simpson Strong-Tie isn't a multi-million dollar company for nothing. A lot of old time contractors really dislike us engineers.
                              Bottom line, when the wind blows really hard or you just happen to be lucky enough to be in a major earthquake, these construction methods will prevent your house from toppling over and potentially killing you.
                              Engineers like myself are entrusted with making sure the built environment around you is safe and secure.
                              design.medeek.com
                              • medeekM
                                medeek
                                Wow, interesting video put out just yesterday:
                                design.medeek.com
                                  ajmwd
                                  @medeek said:
                                  Version 1.5.6 - 07.16.2020
                                  • Updated the gable wall module to allow for zero wall height shed walls.
                                  • Added triple single hung windows to the window module.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su396_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images/wall_su398_800.jpg
                                  Thanks! I just made great use of BOTH of these new features and they worked beautifully. πŸ˜„
                                  Q: if I wanted to add triple 'picture' (fixed) windows, is that something I could do by adding to the Medeek plugin library folder?
                                  • medeekM
                                    medeek
                                    The casement window option is probably what you are looking for:
                                    http://design.medeek.com/resources/images/wall_su178_800.jpg
                                    design.medeek.com
                                      ajmwd
                                      @medeek said:
                                      The Triple Casement window option is probably what you are looking for...
                                      Thanks for the quick response. I didn't think of using the Triple Casement option because we would not actually be ordering casement windows (this is for a set of windows that are very high on the wall and completely inaccessible to operating). However, it does the trick in terms of getting the look. Thanks for the tip!
                                      PS. We are going with Andersen 100 Series. For some reason it appears that the picture window frame is significantly larger than the hung sash frame, for some reason? The Triple Casement match the hung frame size, which will be totally fine for our purposes. Thanks for the tip!
                                      • medeekM
                                        medeek
                                        The casement style window is very similar (identical) to the picture style window in geometry. I guess I probably should add an option for multi-picture windows.
                                        design.medeek.com
                                          ajmwd
                                          Thanks. I think I should clarify my statement... I was stating that Andersen shows a different glass size for Picture and Casement at the same window width. However, after reviewing their size chart documents, it appears that was just a perception of mine. Andersen size charts show both Picture and Casement windows have the SAME unobstructed glass size of...
                                          Width = window width βˆ’ 6.250".
                                          Height = window height βˆ’ 6.250".
                                          So the Triple Casement will be totally fine at representing Triple Picture. Thanks for the information and clarification. πŸ˜„
                                          • medeekM
                                            medeek
                                            I wouldn't exactly call this a schedule as much as a CSV or spread sheet with all of the shearwall data contained within it. Regardless here is a first look at the Shearwall Schedule tool (preview menu):
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/0/f/0fb7e0842ea61f46c58c353c594b5346c8585d0d.jpeg
                                            Note that the preview (or HTML menu) only shows limited information. The CSV output is much more comprehensive, listing all of the parameters for the shearwall (ie. holdowns, anchor bolts, clips, blocking etc...)
                                            I still have not ironed out all of the details I want to show or present within this schedule tool so additional feedback will be key as to how this evolves. I will probably dig into my original shearwall calculator and figure out how to best incorporate some engineering into this tool. I think it would be useful for the tool to calculate the shear capacity of the SW given its dimensions, sheathing and nail patterns. I also think additional parameter(s) for the actual applied shear load (wind and seismic) might be useful as well, I will need to give this some more thought.
                                            Note that the tool is smart enough to detect if there are windows or doors within the bounds of a shearwall panel and correctly labels it with a "PERF" designation, which signifies it is a perforated shearwall.
                                            design.medeek.com
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 80
                                            • 81
                                            • 49 / 81
