    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      cleatus269
      I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
      Please advise.... thanks
        manoamo
        I really want to use your tools but I can't install Liebefredo6 .. 🤣
        Whenever I install Liebefredo6, this message pops up
        Error Loading File Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
        c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
        c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
        C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
        Please help...
        Thank you so much
          manoamo
          c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
          c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
          c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
          C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
          I'm having an issue installing and loading LibFred6... please help
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
            LibFredo6 11.3a is dedicated to
            • Bug fixing
            • Support of VRay 5 in Animator
            • Some cosmetic adjustments
            • Compatibility SU2021
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
              LibFredo6 11.3b contains small adjustments over v11.3a
                roxcore
                Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
                Greetings, Simon
                • fredo6F Offline
                  Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
                  Can you also confirm the version of VRay you use. Thanks.
                    roxcore
                    Hello Fredo! Thank you for answering!! This is what te ruby console showed when opening Animator and starting the generation of the movie:
                    RENDERING INIT
                    Status natural = {}
                    Status thea = :not_supported
                    Status ambient_occlusion = :not_supported
                    Status sketchFX = :not_supported
                    Status twilight = :not_supported
                    VRAY4 Init
                    Status vray4 = nil
                    Status vray = :not_supported
                    :beg_time => 0
                    :end_time => 90.5
                    :frame_rate => 25
                    :speed_factor => 1.0
                    :reversed_play => nil
                    :transparent => false
                    :dimX => 1920
                    :dimY => 1080
                    :dim_mode => "custom"
                    :filter => {
                    } (:filter)
                    :root_dir => "C:/Users/Gebruiker/Desktop/PROJECTEN/CARPENTIER/7. MONTAGEFILM HOUTEN WAND PERGOLA/Animator Videos"
                    :movie_dir => "BASIS ANIMATOR 4 - 23-Nov-2020 15-23-52"
                    :movie_name => "Film 1"
                    :date_modified => 1606130042.267186
                    :break_aspect_ratio => true
                    :movie_formats => {
                    :mp4 => true
                    :mov => false
                    :img_seq => true
                    } (:movie_formats)
                    :rendering_method => :vray4
                    MOVIE PX = 1920 PY = 1080 transpa = false
                    FORMATTED===========================
                    VRAY Movie frame 1
                    Animation time = 0.00s
                    AFTER launching Rendering and Timer: status = true
                    VRAY Status check - status = 6
                    VRay rendering not finished yet elapsed = 1.99s
                    Error: #<NoMethodError: undefined method state' for nil:NilClass> c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:445:in vray_status_check'
                    c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:553:in `block in vray4_status_check'
                    INTERRUPT true
                    VRAY STOP timer =
                    VRAY STOP timer =
                    My Version of Vray is: V-Ray for SketchUp 4.20.02
                    Greetings
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v11.4a - 23 Nov 20
                      LibFredo6 11.4a fixes a problem introduced with v11.3a in the support of VRay 4.2 for Animator
                        roxcore
                        Everything works fine with the update!! Thank you so much!! Greetz
                          manoamo
                          I'm having a " invalid byte sequence in UTF-8 error "
                          I watched your installation video 4 times, Searched about this error for days.
                          I found out that this might be a encoding problem, but I have no idea how to solve this problem.
                          please help .. Below is error log(?) when I restart SU after Libfredo6 installation.
                          c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                          c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                          c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                          C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                          • fredo6F Offline
                            @manoamo said:
                            I'm having a " invalid byte sequence in UTF-8 error " .
                            It's definitely related to your Windows user name not in ascii.
                            Difficult to fix as there are so many situations.
                            If you agree, we could try to troubleshoot together the problem (I would send you some small lines of Ruby to test).
                            In the Ruby console, can you type (just copy / paste the statement and Enter)
                            ENV["LOCALAPPDATA"].encoding.inspect
                            Then tell me what you see as a response
                              manoamo
                              Thank you so much for your kind help! Much appreciated!!
                              #Encoding:CP949
                              This is what I got !
                              • fredo6F Offline
                                #Encoding:CP949
                                Could you now execute the following commands in the Ruby console, one after the other
                                a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
                                a.encoding.inspect
                                  manoamo
                                  #Encoding:CP949
                                  C:\Users\￈ᆱ﾿↓ᄎ￳\AppData\Local
                                  a.encoding.inspect
                                  #Encoding:UTF-8
                                  This is what I got
                                  • fredo6F Offline
                                    #Encoding:CP949
                                    a.encoding.inspect
                                    #Encoding:UTF-8
                                    This is what I got
                                    Then, can you try the following commands
                                    a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\\/, "/")
                                    a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\\", "/")
                                    and then this command
                                    LibFredo6.get_dir_from_ENV "LOCALAPPDATA"
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v11.4d - 27 Nov 20
                                      LibFredo6 11.4d fixes two issues for Animator (VRay5 rendering of apparation and rotation with variable speed)
                                        manoamo
                                        #Encoding:CP949
                                        a.encoding.inspect
                                        #Encoding:UTF-8
                                        a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\/, "/")
                                        <main>:in gsub' <main>:in <main>'
                                        SketchUp:1:in `eval'
                                        a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\", "/")
                                        C:/Users/￈ᆱ﾿↓ᄎ￳/AppData/Local
                                        Error: #<NameError: uninitialized constant LibFredo6>
                                        <main>:in <main>' SketchUp:1:in eval'
                                        I followed every step that you told me!
                                        but still same errors occur 😢
                                        • fredo6F Offline
                                          @manoamo
                                          Thank you. Very useful.
                                          I think this is a bug in the core ruby engine.
                                          I'll see what I can do in order to overcome the problem.
                                          • fredo6F Offline
                                            @manoamo
                                            Could you try
                                            ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\\/, "/")
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 108
                                            • 109
                                            • 26 / 109
