    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 170 Watching
      JamesLeese
      Anton, I am still struggling with created the flag waving. Unlike your example video, my flag breaks into tiny segments with the logo on the flag lost. It reappears when I stop the video creation, then does the same as I continue it. Does not look like a waving flag. I am trying to do a several second video of the flag waving in the breeze. I am version 19 of Sketchup and using your lastest version of Clothworks.
      I can send you the SUP file and a sample video of the problem. I have tried to attach the two files but nothing happens.
      James
        Anton_S
        Hello James,
        There are two things to keep in mind when simulating with texture:
        1. Ensure to apply the texture directly to the faces within the group. It is typical for a user to apply texture to the outer group, which is incorrect.
        2. If intend to visual texture changes, while simulation is running, and not just after simulation stops, ensure Update Textures in Simulation tab of the UI is checked. You can also disable Draw with OpenGL API to actually visualize an actual flag group changing rather than a temporary geometry.
        I attached a link to the flag model, I just created for ClothWorks. Upon downloading, you can press play to see texture changing in effect: flag_with_texture.skp
        When you download the file, ensure that Update Textures is checked and Draw with Open GL API is unchecked. You can disable these options if you only care about seeing the texture changes after simulation ends (this improves simulation performance).
        Also, when simualting a flag, ensure that Self-Collide is unchecked. Flag geometry overlaps can be mostly eliminated by adding the bending stiffness, as used by the model above. Self-collision is currently unstable (I have this on the to-do list, which I will focus upon after updating a few of my other extensions).
        Thanks,
        Anton
        • C
          cativoivo
          Clothworks is a wonderful plugin, but it appears not to work any more with SketchUp 2020.
          At least I am not able to activate it.
          Any help would be much appreciated. 😞
            @cativoivo said:
            ...but it appears not to work any more with SketchUp 2020.
            It actually works fine in SketchUp 2020. The first thing I would check is that you have installed SketchUp correctly. On Windows that requires right clicking on the downloaded installer and selecting Run as administrator from the context menu. If you didn't do that or you don't remember, find the installer or download the latest one from sketchup.com/download/all.
            Do you have the Sketchucation Tools installed? Did you get the license file?
            This was done in SU2020 today.
            • L
              lomaer
              It's very nice plugin.Thank you very much!
                Atilla_Ahmediye
                Hello Anton thanx for this cool plugin. I would like to buy the plugin but in Turkey paypal is banned from goverment. Is there any other way I can send you money and you can give me the license?
                  Anton_S
                  Because PayPal doesn't support sales in Turkey, we are currently limited with where we can sell a licence.
                  Please send an email to clothworks@sketchucation.com for an alternative.
                  Thanks,
                  Anton
                  • K
                    kagealita
                    Hi Anton,
                    I bought this plugin with my personal ID in hurry, but it was actually for my company and I need to transfer it over to my work ID (DU_CAD). Please let me know how to go about it. Thank you.
                    • Y
                      Yai_ya
                      Hello!
                      I have installed ClothWorks v1.7.2 in SketchUp 2021. Unfortunately it doesn't work. An error pops up
                        Mateshev
                        Добрый вечер! Являюсь обладателем лицензии, после обновления SketchUp приложение не работает. Когда появиться поддержка SketchUp 2021?
                          Ahmed0007
                          not working in SketchUp 2021 😕
                            I'm sure Anton will get it sorted out and issue an update. 2021 hasn't been out that long so it might take him a few days.
                              Clothworks uses the SCF licensing system.
                              This has been updated with the SketchUcation Toolset v4.0.0 to suit the v2021 changes.
                              To use licensed tools like this you will need to install the newest version of the SketchUcation Toolset and restart SketchUp.
                                sonjac1978
                                I just installed a new version of SU and my clothworks is not working - it's not showing up in my tools?
                                  Ahmed0007
                                  I have the latest version of ClothWorks and SketchUcationTools_v4.0.0 installed but ClothWorks still not appearing.
                                    Anton_S
                                    Hello everyone,
                                    ClothWorks is not compatible with SU2021 yet. Update is in progress.
                                    Thanks,
                                    Anton
                                      Mariotalluto
                                      This plugin is really impressive ! Thank you
                                      2 Questions for you :
                                      -First : ❗ ❗ After a few try of this plug on sketch2018, Sketchup Crashed on Startup everytime. I had to uninstall clothworks to be able to use sketchup again. What's wrong ?
                                      -Second : i'm trying to do a thick bed sheet (exactly like this https://ak1.ostkcdn.com/wp-content/uploads/2019/01/11620191-how-to-buy-bed-sheets-facebook.jpg)
                                      But i don't know how to make a right thikness with a good selfcolission . I tried to simulate a plan and then apply a thickness with the plugin 'shell' but the result isn't good
                                      Any idea ?
                                      • W
                                        Winston1
                                        Does anyone know when the update will be ready for SU 2021? I would really love to have this extension! 😄🙂
                                        Thank you
                                        Jay
                                          Thank you
                                          Jay
                                          A couple of posts up:
                                          @anton_s said:
                                          Hello everyone,
                                          Thanks,
                                          Anton
                                          As I told you in the other forum, only Anton will know when it'll be available.
                                            Anton_S
                                            Hello everyone,
                                            ClothWorks is updated: https://sketchucation.com/plugin/2053-clothworks
                                            Happy holidays!
                                            Best regards,
                                            Anton
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 36
                                            • 37
                                            • 25 / 37
