    Reducing Rendering Times and Grainy Render
    renderpluginsextensions
    3 Posts 3 Posters 7.2k Views 3 Watching
    • B
      bcoppard
      Hey all thanks for taking the time to read this,
      I've been using V-ray for around 6 months now, but am battling with producing a crisp clean render which is frustrating! The final render looks almost identical to how it looked 2 hours before.
      I produced the render attached in 3 hours 50 minsand yet it is still grainy! I've uploaded my rendering settings below. The final file size is 8.59MB.
      I removed everything from the model that wasn't necessary and purged the model before rendering.
      The PC I'm using it a Lenovo ideapad 700 core i7, with 16GB RAM.
      Any tips to smooth out the render or speed up the rendering time would be much appreciated. Thanks! πŸ‘
      Render Settings
      Final Render
      • GD3DesignG
        GD3Design
        Try this:
        Under 'Render' Tab, turn off 'Progressive'...(this will switch to bucket mode). (more efficient)
        Under 'Render Parameters', 'Quality', lower 'Noise Limit' to betweend .008 & .005. (generally, .01 is high for final renders. I start out at .008 for final renders and adjust from there if needed.
        Lower 'Min Subdivs' to 1, 'Max Subdivs' to 16 or 24. ( you can raise max subdivs if needed, but this will probably be good and save a lot of render time.)
        Under 'Optimizations' turn off 'adaptive lights' (or something similar sounding)
        Change 'Primary Rays' to Irradiance Map and crank up subdivs to 100ish.
        As for time, sorry but you are rendering on a i7 laptop... If you want quicker renders..it may be time to put together a Ryzen build. Best of luck!
          rv1974
          your main problem is cr@ppy PC- get something decent.
          But now, in your situation only one thing could help you- aggressive vray denoising.
          If you got lots of transparent materials in vegetation- switch transparency type to 'clip'.
          Keep noise threshold at .01 or .02 (preferably). Lowering it to .005 is nonsense- you'll render forever.
