    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      I didn't specify any language.
      In v2019 it lists EN, but in v2020 it auto lists EN/FR/ES [or DE if I don't recall right !]
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v11.1a - 26 Aug 20
        LibFredo6 11.1a fixes an issue where a unsigned 'shadow' extension top_libFredo6 appears in the Extension Manager.
        • I Offline
          iaincsthorp
          MacBook Pro (15-inch, 2018)
          OS X Catalina 10.15.4[/quote]
          Did you restart Sketchup after installation? A: Yes
          Do you still have the problem?[/quote] A: Yes
          Here's today's error message
          Error Loading File Fredo6_!LibFredo6.rb
          Error: #<LoadError: dlopen(/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
          Referenced from: /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
          Reason: image not found - /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
          /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
          /users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in load_binary' /users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in startup'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Error Loading File Fredo6_FredoCorner.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in <top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
          /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:52:in module:Fredo6'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:28:in <top (required)>' Error Loading File Fredo6_FredoSpline.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
          /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:50:in module:Fredo6'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
          /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
          /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
          • I Offline
            iaincsthorp
            Here is what I see in Extension Manager: (better now - earlier today the LibFredo extension installed as 'Unsigned'
            https://www.dropbox.com/s/jibuoymuco6wn3n/Screen%20Shot%202020-08-27%20at%201.13.09%20PM.png?dl=0
            Thanks for your help!
            • fredo6F Offline
              Iain,
              Does LibFredo (and my other plugins) still load and work despite of that?
              I cannot reproduce the problem on my Mac (Catalina and MBP too). So, I need to investigate why you get the problem.
              • fredo6F Offline
                Iain
                One thing to check is whether the binary file has been successfully copied.
                Could you do the following in SU2019
                1. Open the RubyConsole
                2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
                3. The console should display the result, something like
                4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
                5. If you open the directory in the finder, could you check if there is
                  • a subfolder: binaries
                  • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
                If there is no file, then we have the explanation. This might be a problem of security settings.
                If there is a file, then this is another problem.
                • I Offline
                  iaincsthorp
                  @fredo6 said:
                  Iain,
                  No, unfortunately not. No Fredo toolbars are showing up.
                  • fredo6F Offline
                    Did you reboot your Mac?
                      dr1416
                      hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
                      the precedent version goes whiteout any problem.
                      the error message after install and restart sketchup are the follow:
                      Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
                      Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
                      Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
                      /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
                      /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in load_binary' /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in startup'
                      /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader'
                      /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                        I am merging this into the main thread - where Fredo is more likely to see it !
                          dr1416
                          thanks , sorry I don't see an other post exit.
                            dr1416
                            for fredo6,
                            i ave look your message but system say I'm not able to reply at PM
                              dr1416
                              last update I have manual cancelled any files of fredo lib and reinstall,
                              now go
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
                                LibFredo6 11.1c includes various bug fixes.
                                • jujuJ Offline
                                  juju
                                  It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
                                  • Y Offline
                                    yhjeong
                                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                    c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                    c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                    c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                    C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                    i experienced load errors.
                                    Plz tell me how to fix it
                                      @yhjeong
                                      Fredo will reply in detail, but it looks like your Korean user-name [μ •μ˜ν˜Έ] is causing the issue.
                                      Ruby expects any text-strings to be UTF-8 encoded.
                                      In earlier Ruby versions non-ASCII characters always caused problems.
                                      In the newer versions of SketchUp there is text-encoding possibilities.
                                      I know Fredo uses these latest methods.
                                      But somehow your Korean user-name is almost certainly causing the problem...
                                        Arkitekto1994
                                        Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
                                          Why are the files .RBZ.SKP ??
                                          A downloaded .RBZ file from the PluginStore should be saved with that file-type.
                                          How did it get changed ?
                                          I suspect your web-browser settings for downloaded file-types are FUBAR...
                                          Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
                                          However, you need to fix your download options...
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
                                            LibFredo6 11.2a includes technical adjustments for some dialogs.
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 109
                                            • 110
                                            • 99 / 110
