    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @tig said:
      V2020 Win10 - the newest LibFredo was just installed and now all of the Fredo extensions show up with French text, not the usual English !?
      The Tools > Fredo Tools > Traduction [aka Translation] is set to EN, but FR is showing...
      That's not new actually. Always been like this...
      Default language (i.e. 'none') happens to be my English, whereas EN states for real English, for which I don't provide a translation (and would happily let an English contributor provides a good translation).
      If you specify EN + FR, then you'll get mostly French, because LibFredo6 looks at language in order and find nothing for EN and something for French.
      I'll do something to avoid confusion.
        I didn't specify any language.
        In v2019 it lists EN, but in v2020 it auto lists EN/FR/ES [or DE if I don't recall right !]
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v11.1a - 26 Aug 20
          LibFredo6 11.1a fixes an issue where a unsigned 'shadow' extension top_libFredo6 appears in the Extension Manager.
          • I Offline
            iaincsthorp
            MacBook Pro (15-inch, 2018)
            OS X Catalina 10.15.4[/quote]
            Did you restart Sketchup after installation? A: Yes
            Do you still have the problem?[/quote] A: Yes
            Here's today's error message
            Error Loading File Fredo6_!LibFredo6.rb
            Error: #<LoadError: dlopen(/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
            Referenced from: /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
            Reason: image not found - /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
            /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
            /users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in load_binary' /users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in startup'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Error Loading File Fredo6_FredoCorner.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in <top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
            /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:52:in module:Fredo6'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:28:in <top (required)>' Error Loading File Fredo6_FredoSpline.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
            /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:50:in module:Fredo6'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in -'
            /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
            /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
            • I Offline
              iaincsthorp
              Here is what I see in Extension Manager: (better now - earlier today the LibFredo extension installed as 'Unsigned'
              https://www.dropbox.com/s/jibuoymuco6wn3n/Screen%20Shot%202020-08-27%20at%201.13.09%20PM.png?dl=0
              Thanks for your help!
              • fredo6F Offline
                Iain,
                Does LibFredo (and my other plugins) still load and work despite of that?
                I cannot reproduce the problem on my Mac (Catalina and MBP too). So, I need to investigate why you get the problem.
                • fredo6F Offline
                  Iain
                  One thing to check is whether the binary file has been successfully copied.
                  Could you do the following in SU2019
                  1. Open the RubyConsole
                  2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
                  3. The console should display the result, something like
                  4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
                  5. If you open the directory in the finder, could you check if there is
                    • a subfolder: binaries
                    • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
                  If there is no file, then we have the explanation. This might be a problem of security settings.
                  If there is a file, then this is another problem.
                  • I Offline
                    iaincsthorp
                    @fredo6 said:
                    Iain,
                    No, unfortunately not. No Fredo toolbars are showing up.
                    • fredo6F Offline
                      Did you reboot your Mac?
                        dr1416
                        hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
                        the precedent version goes whiteout any problem.
                        the error message after install and restart sketchup are the follow:
                        Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
                        Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
                        Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
                        /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
                        /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in load_binary' /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in startup'
                        /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader'
                        /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                          I am merging this into the main thread - where Fredo is more likely to see it !
                            dr1416
                            thanks , sorry I don't see an other post exit.
                              dr1416
                              for fredo6,
                              i ave look your message but system say I'm not able to reply at PM
                                dr1416
                                last update I have manual cancelled any files of fredo lib and reinstall,
                                now go
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
                                  LibFredo6 11.1c includes various bug fixes.
                                  • jujuJ Offline
                                    juju
                                    It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
                                    • Y Offline
                                      yhjeong
                                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                      c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                      c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                      c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                      C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                      i experienced load errors.
                                      Plz tell me how to fix it
                                        @yhjeong
                                        Fredo will reply in detail, but it looks like your Korean user-name [μ •μ˜ν˜Έ] is causing the issue.
                                        Ruby expects any text-strings to be UTF-8 encoded.
                                        In earlier Ruby versions non-ASCII characters always caused problems.
                                        In the newer versions of SketchUp there is text-encoding possibilities.
                                        I know Fredo uses these latest methods.
                                        But somehow your Korean user-name is almost certainly causing the problem...
                                          Arkitekto1994
                                          Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
                                            Why are the files .RBZ.SKP ??
                                            A downloaded .RBZ file from the PluginStore should be saved with that file-type.
                                            How did it get changed ?
                                            I suspect your web-browser settings for downloaded file-types are FUBAR...
                                            Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
                                            However, you need to fix your download options...
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 106 / 109
