    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.5.6 - 02.11.2020
      • Added an option for column base hardware for all column footings.
      • Added the following Simpson column bases to the built-in library: CB66, CBSQ66
      http://design.medeek.com/resources/trussplugin/images/truss_su646_800.jpg
      http://design.medeek.com/resources/trussplugin/images/truss_su645_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've only added two (low poly) column bases thus far, obviously there are many more (just open a Simpson's catalog). If you have a specific part you would like to see added to the built-in library please let me know.
        Similar to the electrical plugin, the user can simply drop their column/post base SketchUp components into the library sub-folder of the plugin to use them with the column footing tool.
        The vertical offset parameter was specifically added for cast in place bolt groups so the depth of embedment can easily be adjusted as needed.
        As seen in the screenshots the hardware is always centered on the footing with the rotation parameter allowing for any degree of rotation.
        This update was per a customer request.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.5.6b - 02.16.2020
          • Added the following Simpson column bases to the built-in library: CBSQ44, CBSQ46, CBSQ86, CBSQ88
          View model here:
          3D Warehouse
          design.medeek.com
          • medeekM Offline
            medeek
            I've had a number of requests recently for an air gap for the interior of the wall (air gap between the framing and gypsum).
            It seems this air gap is typically for furring strips or possibly a foam insulation layer.
            I don't think it will be much of an effort to add this additional feature but I just want to gather further feedback and see if there is enough interest in taking the time to include an extra interior air gap parameter.
            Please feel free to comment or send me comments directly to nathan@medeek.com.
            design.medeek.com
            • pbacotP Offline
              I haven't heard of anyone using that. My first thought is that we don't want air passage in the insulation layer. Perhaps they are putting a vapor barrier over the studs.
              • medeekM Offline
                medeek
                Version 1.5.7 - 03.04.2020
                • Updated the polyline stemwall draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
                • Updated the strip footing draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
                I've never been really happy with using the down arrow as the termination key for the polyline stemwall and strip footing tools, it was always a placeholder until I could figure out how to use the Enter key instead. I've now enabled the plugin so that the Enter/Return key can be used. I have not disabled the down arrow key so actually either can be used at this time but eventually I will remove the down arrow key so that only the enter key will terminate point selection for the two draw tools.
                design.medeek.com
                • medeekM Offline
                  medeek
                  I’m utilizing key code 36 for MacOS, however I need to verify that this is actually working for everyone as it should. If you are using the Foundation plugin on a Mac please download this latest version and let me know if the Enter key will now allow you to terminate a polyline stemwall.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    After some further testing I think I will switch from the Enter key to the End key to terminate point selection. The problem with using the Enter key is that it conflicts with the manual entry of a segment length.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.5.7b - 03.05.2020
                      • Updated the polyline stemwall draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
                      • Updated the strip footing draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
                      For now the point selection termination will be either the down arrow or the "End" key. Using the "Enter" key causes a conflict when the user is manual entering a dimension for a segment length (key in the dimension and then click enter). Until I can figure out how to resolve this conflict this will be the key assignment for terminating both polyline stemwall and strip footings.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.5.7c - 03.05.2020
                        • Added the "Enter" key method to the strip footing and polyline stemwall draw tools for point selection termination.
                        After a couple of tries I think I've finally got it right now. One should be able to use the Enter/Return key to terminate point selection as well as still use the down arrow (for users who are in the habit of using the down arrow now). I apologize on the back and forth on this fix, sometimes things just don't go as smoothly as planned.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.5.8 - 04.27.2020
                          • Added a Global Reset button in the General tab of the Global Settings.
                          • Plugin files switched from .rbs to .rbe encryption.
                          http://design.medeek.com/resources/trussplugin/images/truss_su690_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.5.9 - 05.15.2020
                            • Fixed a bug when the Auto Assign Materials parameter was turned off.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.6.0 - 05.28.2020
                              • Added a footing concrete layer in the Global Settings under the "Layers" tab.
                              • Fixed a bug for metric templates with the strip footing tool and the polyline stemwall tool.
                              https://design.medeek.com/resources/foundationplugin/images/foundation_su66_800.jpg
                              Note, that if you want the footing concrete layer to remain the same as the rest of the foundation (ie. stemwall) you can always assign it to the same layer name: "fnd_conc"
                              Also note, that any and all of these layer names are user configurable, the names shown are just default names I have assigned, the user can utilized their own naming convention that suites their workflow.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                After giving this suggestion some additional thought:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/f/d/fdd7d73095b533bf57d74a1ef859a2e0c99f0def.jpeg
                                I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
                                The two parameters will be:
                                Ftg. Bar Development: None, Hook, Full Ext., Full Int.
                                Ftg. Offset: 0.0 in (default)
                                Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.6.1 - 08.31.2020
                                  • Added a footing offset parameter to polyline stemwalls.
                                  • Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
                                  http://design.medeek.com/resources/foundationplugin/images/foundation_su67_800.jpg
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.6.2 - 10.09.2020
                                    • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                                    http://design.medeek.com/resources/foundationplugin/images/foundation_su68_800.jpg
                                    design.medeek.com
                                    • jujuJ Offline
                                      juju
                                      your website isn't reflecting the new version yet
                                      • medeekM Offline
                                        medeek
                                        It should be showing version 1.6.2 now.
                                        design.medeek.com
                                        • jujuJ Offline
                                          juju
                                          not yet, and I did press "F5" so the page would load fresh
                                          • medeekM Offline
                                            medeek
                                            Try it now.
                                            design.medeek.com
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
