    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      I've had a number of requests recently for an air gap for the interior of the wall (air gap between the framing and gypsum).
      It seems this air gap is typically for furring strips or possibly a foam insulation layer.
      I don't think it will be much of an effort to add this additional feature but I just want to gather further feedback and see if there is enough interest in taking the time to include an extra interior air gap parameter.
      Please feel free to comment or send me comments directly to nathan@medeek.com.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • pbacotP
        I haven't heard of anyone using that. My first thought is that we don't want air passage in the insulation layer. Perhaps they are putting a vapor barrier over the studs.
        • medeekM
          medeek
          Version 1.5.7 - 03.04.2020
          • Updated the polyline stemwall draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
          • Updated the strip footing draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
          I've never been really happy with using the down arrow as the termination key for the polyline stemwall and strip footing tools, it was always a placeholder until I could figure out how to use the Enter key instead. I've now enabled the plugin so that the Enter/Return key can be used. I have not disabled the down arrow key so actually either can be used at this time but eventually I will remove the down arrow key so that only the enter key will terminate point selection for the two draw tools.
          design.medeek.com
          • medeekM
            medeek
            I’m utilizing key code 36 for MacOS, however I need to verify that this is actually working for everyone as it should. If you are using the Foundation plugin on a Mac please download this latest version and let me know if the Enter key will now allow you to terminate a polyline stemwall.
            design.medeek.com
            • medeekM
              medeek
              After some further testing I think I will switch from the Enter key to the End key to terminate point selection. The problem with using the Enter key is that it conflicts with the manual entry of a segment length.
              design.medeek.com
              • medeekM
                medeek
                Version 1.5.7b - 03.05.2020
                • Updated the polyline stemwall draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
                • Updated the strip footing draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
                For now the point selection termination will be either the down arrow or the "End" key. Using the "Enter" key causes a conflict when the user is manual entering a dimension for a segment length (key in the dimension and then click enter). Until I can figure out how to resolve this conflict this will be the key assignment for terminating both polyline stemwall and strip footings.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.5.7c - 03.05.2020
                  • Added the "Enter" key method to the strip footing and polyline stemwall draw tools for point selection termination.
                  After a couple of tries I think I've finally got it right now. One should be able to use the Enter/Return key to terminate point selection as well as still use the down arrow (for users who are in the habit of using the down arrow now). I apologize on the back and forth on this fix, sometimes things just don't go as smoothly as planned.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.5.8 - 04.27.2020
                    • Added a Global Reset button in the General tab of the Global Settings.
                    • Plugin files switched from .rbs to .rbe encryption.
                    http://design.medeek.com/resources/trussplugin/images/truss_su690_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.5.9 - 05.15.2020
                      • Fixed a bug when the Auto Assign Materials parameter was turned off.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.6.0 - 05.28.2020
                        • Added a footing concrete layer in the Global Settings under the "Layers" tab.
                        • Fixed a bug for metric templates with the strip footing tool and the polyline stemwall tool.
                        https://design.medeek.com/resources/foundationplugin/images/foundation_su66_800.jpg
                        Note, that if you want the footing concrete layer to remain the same as the rest of the foundation (ie. stemwall) you can always assign it to the same layer name: "fnd_conc"
                        Also note, that any and all of these layer names are user configurable, the names shown are just default names I have assigned, the user can utilized their own naming convention that suites their workflow.
                        design.medeek.com
                        • medeekM
                          medeek
                          After giving this suggestion some additional thought:
                          https://aws1.discourse-cdn.com/sketchup/original/3X/f/d/fdd7d73095b533bf57d74a1ef859a2e0c99f0def.jpeg
                          I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
                          The two parameters will be:
                          Ftg. Bar Development: None, Hook, Full Ext., Full Int.
                          Ftg. Offset: 0.0 in (default)
                          Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.6.1 - 08.31.2020
                            • Added a footing offset parameter to polyline stemwalls.
                            • Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
                            http://design.medeek.com/resources/foundationplugin/images/foundation_su67_800.jpg
                            View model here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.6.2 - 10.09.2020
                              • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                              http://design.medeek.com/resources/foundationplugin/images/foundation_su68_800.jpg
                              design.medeek.com
                              • jujuJ
                                juju
                                your website isn't reflecting the new version yet
                                • medeekM
                                  medeek
                                  It should be showing version 1.6.2 now.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    not yet, and I did press "F5" so the page would load fresh
                                    • medeekM
                                      medeek
                                      Try it now.
                                      design.medeek.com
                                      • jujuJ
                                        juju
                                        @medeek said:
                                        Try it now.
                                        working now 👍
                                        • medeekM
                                          medeek
                                          Version 1.6.3 - 10.22.2020
                                          • Fixed a bug in the strip footing "Outline" edit menu.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.6.4 - 01.11.2021
                                            • Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su69_800.jpg
                                            Post base hardware added per customer request.
                                            design.medeek.com
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
