    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 76.9k Views 24 Watching
      It is compatible with all SketchUp versions from v8 upwards.
      As far as I know all of my Plugins are...
      If I get a report of an incompatibility, then I fix it; but usually I have anticipated the updates needed...
      As was said, if a Plugin is v2014 compatible it will almost certainly be v2015 friendly too.
      In the post where I said it was v2014 compatible, it was prior to the release of v2015...
        @krisidious said:
        Didn't try...
        Why wouldn't you try it? you could have answered your own question.
        • KrisidiousK Offline
          Krisidious
          Because I have like 4 plugins that do this... I was just wondering because it seemed rather clean and direct.
          And thanks TIG, I've been shying away from things that don't say 2015 compatible. And very nice of you to update EVERYTHING... I can't say we could ever expect that of you, you have so many and you update other people's plugs too.
          By: Kristoff Rand
          • robintR Offline
            robint
            Tig thanx 10^6
            brilliant little tool, am using on GE to get a contour map, much less fiddly than making 100 intersecting planes method
            The contour lines are a little jagged so corners need to be softened. Whats the best way to do this? Tigweld, use Bezier?
            Come to think of it I haven't come across a tool that softens a 2d jagged line easily (like you can in adobe illustrator for example, any suggestions
            ps Ive been player with simplfy contour and convert to polyline/fspline etc, you can only do one line at a time, its all a bit hit and miss - and with 50 odd contours this will be massively time consuming
            with ca 1000+ extensions out there looking for attention, its all bewildering
            Any suggestions
            Cheers
            Robin
            As one door closes another one slams in your face
            • Y Offline
              Yashar11
              Hi TIG, when i install using extention manager it tells me that the version is unsigned?
              I am new to sketch up and using it to create contours on my farm plans, but I am not very computer savvy....please help
              thanks
              Scott
                Many older extensions and plugins report as 'unsigned' in the Extension-Manager dialogs in newer versions of SketchUp.
                This is not actually a problem if you set its Loading-policy to Unrestricted, then unsigned ones will still load and work.
                You should only get RBZ files from trusted sources, like SketchUcation's PluginStore, the Extension-Warehouse etc. If you do that, then the overly draconian loading-policies can be sidestepped.
                When SketchUp had the [not so bright] idea of 'signing' RBZ files, they failed to appreciate the extensive work needed by authors to process the hundreds of files that already existed [let alone any new ones!]. Many older RBZ files have simply not been processed yet, and probably never will - it doesn't mean there's anything wrong with them...
                Using signed RBZ files offers little real comfort to users anyway, since any authors can get their files signed, and there are no significant checks on the contents at all. The EWH ones are checked for good coding methods etc, but many authors, such and myself and Fredo, eschew publishing on the EWH, and prefer to use the nicer/kinder SketchUcation PluginStore, which actually predates the EWH anyway !
                  JavadQaitouri
                  Hey,I installed the file as an extension but it is unsigned, I can't use it, any tips?
                    Its status as Unsigned doesn't mean you can't use it. If you have the loading policy set so it loads, it will work just fine.
                    Which version of SketchUp are you actually using? Your profile shows 2020 Free/Make but there is no such version.
                      JavadQaitouri
                      I use 2020 can,t open it when it is unsigned.
                        Yes. It can be opened when unsigned if you set the loading policy to Approve Unidentified Extensions or Unrestricted in the Extension Manager.
                        This extension works just fine in SketchUp 2020.
                        Please update your profile.
                        • 4 / 4
