    Plugin that matches file name and definition name of comp?
    13 Posts 5 Posters 2.7k Views 5 Watching
      LEGOsketcher
      Hi all,
      We use specific work flow in e.g. fixture design where use an existing component as base for a new one > make unique, change it, rename the component definition in the Entity Info > save as new component. SketchUp suggests the filename of the original component NOT the current new definition name (even after renaming it as described) has led to a couple of mistakes overwriting the old files in our database.
      Discussed this issue in the beta tester board but apparently there is a good reason why definition names and file names don't match. I didn't think make unique- change - save as is such an uncommon workflow but what do I know. I thought it was a bug.
      They suggest a plugin could match it - is there anything out there? Otherwise we have to copy paste the name manually every time...
      • jujuJ Offline
        juju
        @dezmo said:
        It is not 100% clear if you want to use the component definition name or the name from the dynamic component attribute...
        Therefore I made both 😄
        This is a quick and dirty plugin: USE YOUR OWN RISK!
        After installing the extension you will get 2 new context menu item (right click on the component):
        • "Save as: DC name"
        • "Save as: Def name"
          Will be grayed out if not applicable.
        I hope this is what you want and it will works for you!
        Why not rather load this to the PluginStore and link it here?
          dezmo
          Because I don't want to make it widely public yet before someone else tested ... 😳
          Man can do everything. Only a matter of time and money.
          • TIGT Online
            Remember that it's possible to make a component with a name that cannot be used in a file name, so the saved SKP cannot always have the component's name.
            Some characters might be allowed in a component-name, but are not applicable in the saved-SKP's name, or even when they are acceptable they are best avoided.
            e.g. #{}<>:/?$+%!`'"&*=@|;,. and even the lowly <space>
              dezmo
              Thanks @TIG.
              As I mentioned this is a quick and dirty plugin. I spent ~half an hour on it... This is one of the reason if not in PluginStore yet.
              Sure, there is plenty of room for improvement, here and there.
              I hope @LEGOsketcher will give some feedback if he like it or not...
              Beside that I generally agree to check for special characters, in this case you will get a system warning during file saving "The file name is not valid." at least in Windows, like this:
              • Dav_IDD Offline
                Dav_ID
                Hi Everyone !
                thanks for your plugin Dezmo, it's cool.
                Just to tell you that I've tested it with SU17 Make and SU2020 Pro and that it works for me. 👍
                But ...
                just a (stupid?) question about
                "Save as: DC name"
                as it's always grayed for me ... when is it applicable ?
                Thanks again
                  dezmo
                  @dav_id said:
                  Hi Everyone !
                  "Save as: DC name"
                  Thanks again
                  DC: Dynamic Component
                  That one will be available only if you have Dynamic Component and you set the name in Component Attribute window. (like a lover left corner show in the first post screenshot).
                  More: https://help.sketchup.com/en/sketchup/making-dynamic-component
                  • Dav_IDD Offline
                    Dav_ID
                    @dezmo said:
                    @dav_id said:
                    Hi Everyone !
                    "Save as: DC name"
                    Thanks again
                    oups ... sorry, of course ... i just tried to do this with simple Components 😳
                    Thanks ... i'll try again with a DC
                    UPDATE :
                    It's ok for me with SU17 Make and SU2020 Pro
                      dezmo
                      That's great. Thanks for the feedback! 😄
                        dezmo
                        Despite that I did not receive any feedback from the original requester yet, there is a refined version:
                        Dezmo_save_as_name_Beta_2020_0824_1405.rbz
                        After installation You need to restart SU if the previous version was there.
                        History:
                        #Beta_2020_0819_1526: Initial version of Dezmo Save as name (see in above post)
                        This version:
                        #Beta_2020_0824_1405:
                        • Added instance name possibility
                        • The context menu will contain up to 3 sub-menus (including the current names)
                        • The context menu will disappear if not relevant (instead of graying out)
                          ? Known issue: -You can not select the SU file version to save to (You can't save to older version)
                          ! Known benefit: + You can even save a group now.
                          I intend to put it in the PluginStore later ... after some feedback and if I have more time to do so.
                          dezmo
                          Note: Scroll down for new release in a later post of mine!
                          Dezmo_save_as_name.rbz
                          • Dav_IDD Offline
                            Dav_ID
                            Oups ... sorry
                            I had not seen that ... but actually I have the same problem
                            Best regards
                              dezmo
                              Unlike Model#save or Model#save_copy, unfortunately the Ruby API does not allow me to give a second parameter - version - for Definition.#save_as.
                              And UI.savepanel have it's limitation too...
                              ...Therefore I got stuck here for now with "versionig". I need more time to figure out workaround, if any.
