    Objects not showing in animation
    renderpluginsextensions
    5 Posts 2 Posters 5.4k Views 2 Watching
      GenomeJeff
      I created a simple animation where letters pop out from behind a wall. The whole video is about 16 seconds long so I'm not trying anything crazy here.
      I have the latest version of animator, FFMPEG, and I use VRAY (latest version) to render.
      However, when I render the animation the letters are not showing up. If I render a single image then I can see the letters.
      Any suggestions?
      • ntxdaveN Offline
        ntxdave
        What happens if you generate the video but do not render with VRAY (just use Animator by itself)?
        Press F1...thank me later
          GenomeJeff
          Hey Dave, thanks for trying to help here. I just rendered it using the natural option instead of VRAY and the letters animate and play fine as a mov, AVI, or mp4 file.
          For whatever reason VRAY is not rendering each new frame as it animates. It just renders the objects based on the first frame even though it will move.
          Camera movements however do work so it will render in vray and show it as a fly through or pan, etc.
          • ntxdaveN Offline
            ntxdave
            I think if you look on this forum and the Sketchup forum you can/will find that others have had a similar problem with VRAY but I did not look at the resolution since I do not use VRAY.
              GenomeJeff
              You are 100% right, I did not look hard enough. Recent update to the Library fixes this issue. Thank you!
              https://sketchucation.com/forums/viewtopic.php?f=401&t=68154&p=662293&hilit=vray#p662293
