    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.7m Views 28 Watching
    • medeekM Offline
      medeek
      Version 1.5.6 - 07.16.2020
      • Updated the gable wall module to allow for zero wall height shed walls.
      • Added triple single hung windows to the window module.
      http://design.medeek.com/resources/wallplugin/images/wall_su396_800.jpg
      http://design.medeek.com/resources/wallplugin/images/wall_su398_800.jpg
      View model here:
      https://3dwarehouse.sketchup.com/model/5d1c193e-2547-4ad3-ae31-25e2762a32e7/Triple-Single-Hung-Window
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've been chiseling away at these plugins now for almost 5 years, granted I only started working full time on them since April 2018, but I do think they have evolved significantly even at that.
        With that being said there is still much to do. Additional plugins (Floor, Interiors, Decks, Project, Engineering, RC, etc...) are needed to fully flesh out the building and all of its potential elements. At some point the engineering and estimating pieces also need to become a reality, this will take everything to a new level. Sadly I am still working on the design/architectural elements, but if all goes well I should have most of it wrapped up in a few more months and then begin the engineering and estimating pieces. I also want the ability to export elevations and sections quickly into Scenes and then they can be easily moved into Layout, I've got some good ideas on that. A DXF export utility for floor plans etc... would also be nice, there is so much one can do with the API, it is mind boggling.
        Every day I get emails from customers and potential customers requesting various features or new plugins, obviously there is a demand for this sort of thing, my email inbox bears this out. Unfortunately, I am so over taxed just trying to knock out the things on my existing todo lists that many of these great ideas go by the wayside (some do eventually make it on to my lists).
        For a concise summary of the recent updates:
        404 - File or directory not found.
        (design.medeek.com)
        As they say though, the squeaky wheel gets the grease, if I get enough demand for a certain feature it tends to move it up the list. Please keep the feedback rolling in, it only makes the plugins better.
        design.medeek.com
        • medeekM Offline
          medeek
          So I'm looking at the hip wall again because I've had some further interest in it.
          However, I'm trying to figure out the best way to frame the top plates, which variant is preferred:
          Version 1:
          https://aws1.discourse-cdn.com/sketchup/original/3X/8/0/8095b5ae3a863d53ab6f4271c52e820d19349972.jpeg
          Version 2:
          https://aws1.discourse-cdn.com/sketchup/original/3X/9/c/9cb3cd193a0c6c3cf2e5628310d774c78f337baa.jpeg
          design.medeek.com
          • medeekM Offline
            medeek
            First look at a hip wall with blocking:
            https://aws1.discourse-cdn.com/sketchup/original/3X/4/7/47b4c1ddad85569fa6d8dbd8cbaba7194d4436bb.jpeg
            design.medeek.com
            • medeekM Offline
              medeek
              Hip wall with insulation and blocking:
              https://aws1.discourse-cdn.com/sketchup/original/3X/b/3/b34d6ce94640253a9e0e736429c649435f3d2cca.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                Hip wall with windows and doors:
                https://aws1.discourse-cdn.com/sketchup/original/3X/d/2/d203abcbd624483162ebd79ede61d7fdfb456235.jpeg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.5.7 - 07.21.2020
                  • Enabled the gable wall tool with the ability to draw and edit hip walls.
                  http://design.medeek.com/resources/wallplugin/images/wall_su406_800.jpg
                  View model here:
                  https://3dwarehouse.sketchup.com/model/8707c88c-0874-4c47-8563-f4e4326da53f/Hip-Wall-2
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.5.7b - 07.22.2020
                    • Updated the gable wall module to allow for zero wall height hip walls.
                    • Fixed a bug with the trimming of Simpson Strong-Tie wood shear walls (WSW).
                    http://design.medeek.com/resources/wallplugin/images/wall_su407_800.jpg
                    http://design.medeek.com/resources/wallplugin/images/wall_su405_800.jpg
                    http://design.medeek.com/resources/wallplugin/images/wall_su404_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Off the beaten path a bit today, had a discussion about engineering and the plugins, so it got me thinking about the engineering module and beams and headers. Some ideas on representing loads on beams below:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/3/2/32dc3b1a35eff37321a7f1362e722987200faa62.jpeg
                      Not sure I like how the distributed loads are represented with a transparent PNG, it might be better to simply draw two connected arrows which represent the extent of the distributed load (start and end points along the length of the beam).
                      The colors represent different load types (ie. Dead, Live, Snow).
                      The magnitude will be represented by the height of the arrows and size of the arrow heads.
                      The loading diagrams will be placed on their own specific layer so they can easily be toggled on an off.
                      Initially I think it would be best to stick with just rectangular distributed loads, trapezoidal and triangular loads complicate things considerably. Notice how the loading is placed on the beam such that coincident loads are offset in the Y axis so they can be better visualized and not Z-fight each other.
                      This would be a significant upgrade to the plugins, allow the user to quickly calculate and check a beam or header, similar to doing a check in Weyerhauser's Forte or any other comparable engineering application.
                      The output would be something similar to my Beam Calculator here:
                      https://design.medeek.com/resources/beam/beam_calculator.pl
                      However the output probably should be less verbose and more compact, similar to the one page output of Forte.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.5.7c - 07.23.2020
                        • Fixed a bug with certain wall sheathing materials as applied to gable, hip and shed walls.
                        http://design.medeek.com/resources/wallplugin/images/wall_su410_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.5.8 - 08.01.2020
                          • Fixed a bug with all wall assemblies when auto-assigment of materials is turned off in the global settings.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.5.8b - 08.02.2020
                            • Added a semi-transparent polygon fill to the draw wall tool wireframe.
                            • Added an option for vertical ZIP Systems© 7/16" and 1/2" wall sheathing materials.
                            http://design.medeek.com/resources/wallplugin/images/wall_su412_800.jpg
                            View model here:
                            https://3dwarehouse.sketchup.com/model/752a6027-fd47-42da-88e7-245eed5a5691/Zip-System-Wall-Sheathing-Vert
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.5.9 - 08.18.2020
                              • Added the "Basic Options" parameters to the Wall tab of the Global Settings.
                              http://design.medeek.com/resources/wallplugin/images/wall_su413_800.jpg
                              I'm not sure why these parameters never got added to the global settings a long time ago but I guess better late than never.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.5.9b - 08.18.2020
                                • Fixed a bug with gypsum when applied to the end condition for interior shed walls.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.5.9c - 08.19.2020
                                  • Fixed a floating point rounding error in the blocking and cavity insulation modules for all walls.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su414_800.jpg
                                  No bells and whistles tonight. Sometimes it's just about putting out the fires.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.6.0 - 08.23.2020
                                    • Enabled variable king stud and trimmer stud widths for garage doors (non-portal frame).
                                    http://design.medeek.com/resources/wallplugin/images/wall_su415_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.6.0b - 08.23.2020
                                      • Added the ability to create, load and delete garage door presets within the Edit and Draw (HTML) Menus.
                                      • Fixed a bug with reading in presets from the door and window edit menus.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su416_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.6.1 - 08.26.2020
                                        • All gable wall types (gable, hip, shed) now include the option to enter in the wall slope as a pitch or angle.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su417_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          For completeness I think it would be a good idea to add the option for arched garage doors and dutch corners. The algorithms for arched doors already exist within the man door module and the geometry of dutch corners is very simple. Give me a couple of days and I will knock this one out.
                                          https://i.pinimg.com/originals/99/3c/3b/993c3b99ce7a89ff86fde61a4de63a36.jpg
                                          https://greyswoodworks.com/wp-content/uploads/2018/02/24_-X-24_-Classic-Main-Picture.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.6.2 - 09.01.2020
                                            • Added three additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su419_800.jpg
                                            design.medeek.com
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 79
                                            • 80
                                            • 46 / 80
