    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.7m Views 28 Watching
    • medeekM Offline
      medeek
      First look at a left and right shed wall:
      https://aws1.discourse-cdn.com/sketchup/original/3X/0/4/047be3a26bd07f66d87c520c3e5b79c00b014865.jpeg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.5.5 - 07.14.2020
        • Enabled the gable wall tool with the ability to draw and edit shed walls.
        http://design.medeek.com/resources/wallplugin/images/wall_su392_800.jpg
        http://design.medeek.com/resources/wallplugin/images/wall_su393_800.jpg
        http://design.medeek.com/resources/wallplugin/images/wall_su394_800.jpg
        http://design.medeek.com/resources/wallplugin/images/wall_su395_800.jpg
        View model here:
        https://3dwarehouse.sketchup.com/model/126f5080-0ecc-4edf-96b4-6599d4412dcd/Shed-Walls
        design.medeek.com
        • medeekM Offline
          medeek
          Updated todo list (as of July 14, 2020):
          1.) Making the Window, Door and Garage Door modules work with generic walls, not just Medeek walls.
          2.) Shear Wall module which will ultimately integrate with the engineering plugin.
          3.) Presets for Garage Doors
          4.) Move the Estimating module to the new Medeek Project extension, and further develop this module as it relates to the wall plugin.
          5.) Start work on the integrated  Medeek Engineering  extension, start with window and door headers for vertical loads.
          6.) Additional door and window types as requested (eg. bi-fold closet doors, sliding glass doors, pocket doors, double and triple single hung windows).
          7.) Spend some time on the new tabs in the global settings, currently showing an Under Construction sign.
          8.) Stair module permutations: U, L, T etc…
          9.) Further “idiot” proofing of the plugins: (zero value, nil values, checking for impossible geometry, etc…)
          10.) Wall Justification
          11.) Interior trim added to Medeek Interior extension.
          12.) Resume development of the Medeek Floor extension.
          The list has gotten a lot shorter in the last couple of months. I'm excited to finally have a working shed and gable wall type, there is still a lot more work to be done with many more gable variants, but I will attack those as specific requests are made for each type.
          I feel it is time to move back to the complex roof module but before I do I may look at the new number one on this list.
          design.medeek.com
          • medeekM Offline
            medeek
            While I am still fresh with gable walls (and the code for this module) I am contemplating getting the hip variant done as well:
            https://aws1.discourse-cdn.com/sketchup/original/3X/8/0/8095b5ae3a863d53ab6f4271c52e820d19349972.jpeg
            I've already got two votes in favor of it (myself and Larry Belk) however I want to put this out to everyone else and find out if it is of any interest, would you use this gable wall type?
            It will probably take me about 3 or 4 days to make it happen or I can move on to other items in the list.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.5.6 - 07.16.2020
              • Updated the gable wall module to allow for zero wall height shed walls.
              • Added triple single hung windows to the window module.
              http://design.medeek.com/resources/wallplugin/images/wall_su396_800.jpg
              http://design.medeek.com/resources/wallplugin/images/wall_su398_800.jpg
              View model here:
              https://3dwarehouse.sketchup.com/model/5d1c193e-2547-4ad3-ae31-25e2762a32e7/Triple-Single-Hung-Window
              design.medeek.com
              • medeekM Offline
                medeek
                I've been chiseling away at these plugins now for almost 5 years, granted I only started working full time on them since April 2018, but I do think they have evolved significantly even at that.
                With that being said there is still much to do. Additional plugins (Floor, Interiors, Decks, Project, Engineering, RC, etc...) are needed to fully flesh out the building and all of its potential elements. At some point the engineering and estimating pieces also need to become a reality, this will take everything to a new level. Sadly I am still working on the design/architectural elements, but if all goes well I should have most of it wrapped up in a few more months and then begin the engineering and estimating pieces. I also want the ability to export elevations and sections quickly into Scenes and then they can be easily moved into Layout, I've got some good ideas on that. A DXF export utility for floor plans etc... would also be nice, there is so much one can do with the API, it is mind boggling.
                Every day I get emails from customers and potential customers requesting various features or new plugins, obviously there is a demand for this sort of thing, my email inbox bears this out. Unfortunately, I am so over taxed just trying to knock out the things on my existing todo lists that many of these great ideas go by the wayside (some do eventually make it on to my lists).
                For a concise summary of the recent updates:
                404 - File or directory not found.
                (design.medeek.com)
                As they say though, the squeaky wheel gets the grease, if I get enough demand for a certain feature it tends to move it up the list. Please keep the feedback rolling in, it only makes the plugins better.
                design.medeek.com
                • medeekM Offline
                  medeek
                  So I'm looking at the hip wall again because I've had some further interest in it.
                  However, I'm trying to figure out the best way to frame the top plates, which variant is preferred:
                  Version 1:
                  Version 2:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/9/c/9cb3cd193a0c6c3cf2e5628310d774c78f337baa.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at a hip wall with blocking:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/4/7/47b4c1ddad85569fa6d8dbd8cbaba7194d4436bb.jpeg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Hip wall with insulation and blocking:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/b/3/b34d6ce94640253a9e0e736429c649435f3d2cca.jpeg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Hip wall with windows and doors:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/d/2/d203abcbd624483162ebd79ede61d7fdfb456235.jpeg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.5.7 - 07.21.2020
                          • Enabled the gable wall tool with the ability to draw and edit hip walls.
                          http://design.medeek.com/resources/wallplugin/images/wall_su406_800.jpg
                          View model here:
                          https://3dwarehouse.sketchup.com/model/8707c88c-0874-4c47-8563-f4e4326da53f/Hip-Wall-2
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.5.7b - 07.22.2020
                            • Updated the gable wall module to allow for zero wall height hip walls.
                            • Fixed a bug with the trimming of Simpson Strong-Tie wood shear walls (WSW).
                            http://design.medeek.com/resources/wallplugin/images/wall_su407_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su405_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su404_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Off the beaten path a bit today, had a discussion about engineering and the plugins, so it got me thinking about the engineering module and beams and headers. Some ideas on representing loads on beams below:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/3/2/32dc3b1a35eff37321a7f1362e722987200faa62.jpeg
                              Not sure I like how the distributed loads are represented with a transparent PNG, it might be better to simply draw two connected arrows which represent the extent of the distributed load (start and end points along the length of the beam).
                              The colors represent different load types (ie. Dead, Live, Snow).
                              The magnitude will be represented by the height of the arrows and size of the arrow heads.
                              The loading diagrams will be placed on their own specific layer so they can easily be toggled on an off.
                              Initially I think it would be best to stick with just rectangular distributed loads, trapezoidal and triangular loads complicate things considerably. Notice how the loading is placed on the beam such that coincident loads are offset in the Y axis so they can be better visualized and not Z-fight each other.
                              This would be a significant upgrade to the plugins, allow the user to quickly calculate and check a beam or header, similar to doing a check in Weyerhauser's Forte or any other comparable engineering application.
                              The output would be something similar to my Beam Calculator here:
                              https://design.medeek.com/resources/beam/beam_calculator.pl
                              However the output probably should be less verbose and more compact, similar to the one page output of Forte.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.5.7c - 07.23.2020
                                • Fixed a bug with certain wall sheathing materials as applied to gable, hip and shed walls.
                                http://design.medeek.com/resources/wallplugin/images/wall_su410_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.5.8 - 08.01.2020
                                  • Fixed a bug with all wall assemblies when auto-assigment of materials is turned off in the global settings.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.5.8b - 08.02.2020
                                    • Added a semi-transparent polygon fill to the draw wall tool wireframe.
                                    • Added an option for vertical ZIP Systems© 7/16" and 1/2" wall sheathing materials.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su412_800.jpg
                                    View model here:
                                    https://3dwarehouse.sketchup.com/model/752a6027-fd47-42da-88e7-245eed5a5691/Zip-System-Wall-Sheathing-Vert
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.5.9 - 08.18.2020
                                      • Added the "Basic Options" parameters to the Wall tab of the Global Settings.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su413_800.jpg
                                      I'm not sure why these parameters never got added to the global settings a long time ago but I guess better late than never.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.5.9b - 08.18.2020
                                        • Fixed a bug with gypsum when applied to the end condition for interior shed walls.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.5.9c - 08.19.2020
                                          • Fixed a floating point rounding error in the blocking and cavity insulation modules for all walls.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su414_800.jpg
                                          No bells and whistles tonight. Sometimes it's just about putting out the fires.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.6.0 - 08.23.2020
                                            • Enabled variable king stud and trimmer stud widths for garage doors (non-portal frame).
                                            http://design.medeek.com/resources/wallplugin/images/wall_su415_800.jpg
                                            design.medeek.com
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 79
                                            • 80
                                            • 46 / 80
