    Heating & hot water upgrade
    19 Posts 8 Posters 3.9k Views 8 Watching
    • HornOxxH
      HornOxx
      πŸ‘ πŸ‘ an unusually pragmatic work, impressively nice and so accurately done and presented!
      never trust a skinny cook
        shawb
        Thank you HornOxx! I just hope that my soldering and pipe bending skills will stand up as well.
          Nicely done, very impressive. πŸ‘Š
            shawb
            Thank you Mike. As ever, a big thank you to Fredo6 for his invaluable Plugins. In this instance the FredoTools collection (Colour by altitude, Curvishear & Thrupaint) and Joint Push Pull (Thickener). All other modelling was done with native SU tools.
            • Bryan KB
              Top notch modeling!
                shawb
                Thank you Bryan. Another view with the hot water cylinder insulation thickened to something like it should be and a cylinder stat fitted.
                • jo-keJ
                  jo-ke
                  Wow, what a cool and detailed model!
                  http://www.zz7.de
                    shawb
                    Very kind of you to say so jo-ke and indeed all who have commented. This model was definitely a case of form following function but it's where Sketchup is invaluable in getting through the many design iterations.
                      db11
                      Very nice job.
                      As you say, SU is invaluable for working through a design like this β€” and once you're done on the computer, you have the rare opportunity to buy all of your required plumbing parts in a single go! (anyone who has ever done any plumbing will get this πŸ˜„
                        shawb
                        Absolutely, apart from the bit that you 'forgot to order/broke/spoiled/can't find' that you desperately need to get the system working at 11 pm on a Saturday night! (Couldn't see a smillie to show 'head in hands exasperation' or 'I wish I had never started this'!) However, it is always a golden opportunity to buy those nice, indispensable, tools that are essential to get the project done.
                          rspierenburg
                          Look really interesting and details. Would be nice to see a real-life comparison when its all done. Good work!
                            shawb
                            Thank you rspierenburg. I will try and remember to take pics of the work - when I will get started is anybody's guess though! I have a feeling that now travel restrictions are being relaxed we will be having a backlog of visitors to stay. I have, however, continued to tweak the design and, as before, that is much easier to do in Sketchup. Initially I was trying to minimize the number of 90 deg elbows and use large radius bends to improve water flow. That would of entailed purchasing a pipe bender but on reflection the circulating pump I have works fine on the present set-up. So, spend the money on a decent blow torch instead and the elbows are not expensive!
                              shawb
                              So, I got started on the upgrade and although there is still work to do here is the result. Plenty of changes along the way of course but I am pleased with the result - no leaks and it works which is always a bonus. Had to buy the pipe bender after all to save the knees.
                              • tuna1957T
                                tuna1957
                                Fantastic modeling and great to see the model come to life. πŸ‘
                                • jo-keJ
                                  jo-ke
                                  Wow. Good work
                                  http://www.zz7.de
                                    shawb
                                    Thank you gentlemen! I also used Layout to produce schematics for this project and other parts of the house. I have always found that drawing out complex systems makes it easier for me to understand them. My soldering has improved a bit as well!
                                    • HornOxxH
                                      HornOxx
                                      Prima! I don't know anything about any of this wire stuff! - the more I am impressed by this contribution πŸ‘ πŸ˜„ Respect!
                                        shawb
                                        You're very kind HornOxx. I'm certainly no plumber or electrician but Sketchup has been invaluable in helping me to get things done and, indeed, understand why I was doing it! A slimmed down version of the Layout file I used is attached.
                                        SU Layout 2015 version.layout
