    Heating & hot water upgrade
    19 Posts 8 Posters 3.8k Views 8 Watching
      shawb
      Thank you Bryan. Another view with the hot water cylinder insulation thickened to something like it should be and a cylinder stat fitted.
      • jo-keJ Offline
        jo-ke
        Wow, what a cool and detailed model!
        http://www.zz7.de
          shawb
          Very kind of you to say so jo-ke and indeed all who have commented. This model was definitely a case of form following function but it's where Sketchup is invaluable in getting through the many design iterations.
            db11
            Very nice job.
            As you say, SU is invaluable for working through a design like this β€” and once you're done on the computer, you have the rare opportunity to buy all of your required plumbing parts in a single go! (anyone who has ever done any plumbing will get this πŸ˜„
              shawb
              Absolutely, apart from the bit that you 'forgot to order/broke/spoiled/can't find' that you desperately need to get the system working at 11 pm on a Saturday night! (Couldn't see a smillie to show 'head in hands exasperation' or 'I wish I had never started this'!) However, it is always a golden opportunity to buy those nice, indispensable, tools that are essential to get the project done.
                rspierenburg
                Look really interesting and details. Would be nice to see a real-life comparison when its all done. Good work!
                  shawb
                  Thank you rspierenburg. I will try and remember to take pics of the work - when I will get started is anybody's guess though! I have a feeling that now travel restrictions are being relaxed we will be having a backlog of visitors to stay. I have, however, continued to tweak the design and, as before, that is much easier to do in Sketchup. Initially I was trying to minimize the number of 90 deg elbows and use large radius bends to improve water flow. That would of entailed purchasing a pipe bender but on reflection the circulating pump I have works fine on the present set-up. So, spend the money on a decent blow torch instead and the elbows are not expensive!
                    shawb
                    So, I got started on the upgrade and although there is still work to do here is the result. Plenty of changes along the way of course but I am pleased with the result - no leaks and it works which is always a bonus. Had to buy the pipe bender after all to save the knees.
                    • tuna1957T Offline
                      tuna1957
                      Fantastic modeling and great to see the model come to life. πŸ‘
                      • jo-keJ Offline
                        jo-ke
                        Wow. Good work
                        http://www.zz7.de
                          shawb
                          Thank you gentlemen! I also used Layout to produce schematics for this project and other parts of the house. I have always found that drawing out complex systems makes it easier for me to understand them. My soldering has improved a bit as well!
                          • HornOxxH Offline
                            HornOxx
                            Prima! I don't know anything about any of this wire stuff! - the more I am impressed by this contribution πŸ‘ πŸ˜„ Respect!
                            never trust a skinny cook
                              shawb
                              You're very kind HornOxx. I'm certainly no plumber or electrician but Sketchup has been invaluable in helping me to get things done and, indeed, understand why I was doing it! A slimmed down version of the Layout file I used is attached.
                              SU Layout 2015 version.layout
