    [Plugin][EVAL] TIG-CutNfill
    96 Posts 32 Posters 92.4k Views 32 Watching
      paulofukuta
      Hi!
      Is it possible to export the data (csv file) to Microsoft Excel?
        No CSV direct export.
        You need to edit the text-object, select-all and copy, then paste into a new text file, which you then save with the .csv suffix.
        Edit its text to be comma-separated rows and columns as desired.
        It's then usable in Excel - although the amount of data in each text-object is so small a simple copy/paste directly into a spreadsheet will probably be faster !
          Mikadoodledoo
          Hi TIG,
          I have just purchased your plugin to calculate areas on a new project I have. The issue I am having is that after the plugin did its calculation (1.5hrs) it shows only the cut volume and nothing for the fill.
          After the calaculation it showed that the fill was not a solid??...
          Any idea how to find the fill volume?
          Many thanks.
            Without seeing the SKP it's hard to say, but it must be complex to take so long processing !
            As you will see in earlier posts, it is possible to create two solid volumes which will not create a solid result [and therefore no volume is possible] - this applies to the Solid-Tools too, which are also used by the API, and thereby this tool...
            This issue results when the two forms have very slight differences in some parts, and the result of the subtraction process would produce new edges where their start/end points are within 1/1000" - because of this SketchUp then assumes that these points are coincident and the edge is not created, then the associated face is not supported either - then there's no enclosed volume to report...
            SketchUp's built-in tolerance is 1/1000" and cannot be sidestepped...
            This issue occurs in an processing that uses intersection etc that might result in tiny geometry.
            The normal fix in processes like 3d-printing is to work at say 1000x bigger, but in your case that's probably no practicable.
            Since CutNfill is aimed at 'ground-working', then modeling to fractions of an inch, or having unnecessarily convoluted 3d surfaces are ill-advised, and this is where the tiny geometry problems can arise...
              skugee
              I purchased a license for CutNfill on the 15th of April and haven't yet received it. Can you send the license please?
                I've got our IT guy onto it...
                Watch your PMs / emails [including spam]...
                  Gábor
                  @skugee said:
                  I purchased a license for CutNfill...
                  I re-sent the download link to both of your email addresses today. Please let us know if you received it.
                    skugee
                    I've installed the licensed V3.0
                    I'm using SketchUp 2020
                    Couldn't get it to work so thought I'd try a simple shape, but still no joy?
                    restarted a few times, renamed group EXTG, but nothing seems to work.
                    anything else I can try?
                    CutNfill Error
                      Can you attach the simple SKP if the following steps don't solve things...
                      From the 'Entity Info' I can't see a group named EXTG ?
                      However since you've selected two groups no Instance name will be displayed.
                      The error message tells you one of the two groups needs to be named EXTG - that is NOT the Tag [Layer] name, it's the group-name [now recast as Instance-name]...
                      Select just the 'existing' group and in Entity Info give it the Instance name of EXTG.
                      There is a Tag named 'EXTG', and the two selected groups have different tags, but none of this is important to this tool's functionality.
                      I usually name the two groups EXTG and PROP - but only the 'existing' one needs the name... this is so the tool can work out which is which in the processing...
                      I'd also recommend leaving the two groups with their Tag set to Untagged [or Layer=Layer0 <= v2019]
                        bjammin502
                        Ok I must be an idiot. I have installed the Cut N Fill plug-in by TIG and have followed the instructions and have the existing group titled “EXTG” but it keeps telling me one of the groups needs to be titled “EXTG”…it is, it won’t do anything else. I have tried exploading and regrouping and nothing seems to work. What am I doing wrong? Is there anyway to get help from TIG?
                        Note: I bought the plug-in so not operating under a trial
                          As I said over at SketchUp.com...
                          You need to select two overlaid groups.
                          The existing group must always be named 'EXTG', the proposed group can be named anything else you like - I use 'PROP'osed.
                          Note it must be two 'groups'... NOT component instances or their definitions.
                          Also the two groups must be 'solids' - otherwise the SketchUp 'solid-tools' can't work...
                          Entity Info and the Outliner will show a selected group/properties and its name etc...
                          Please post with screen shots of your model, Entity Info etc...
                          I’m sure it will be a straightforward fix...
                            bjammin502
                            @TIG
                            Thanks for the reply, sorry got busy on other stuff. I think I know what the issue may be BUT I don't know how to fix. The error message kept saying one of the groups has to be named EXTG which you can tell from the attached images that one of them is named correctly. What I think the issue is when you look at the entity info for the proposed you will notice it doesn't report a volume. I used the skirt tool which hopefully you can also see in the attached image. So if this is the issue then the error message is throwing me off. Now if that is the issue then I don't know how to fix.
                            One thing worth mentioning is maybe I broke the surface when I made one edit. I created a surface from proposed contours and then used the skirt tool to turn the surface into a volume. These proposed contours did not properly account for the basement dig out so I attempted to delete some triangles and add in some triangles to account for the basement dig out (which is why it looks funky in the middle of the proposed surface. Now, I did this down and dirty as a test to get this cut and fill to work. I had planned to go back and do a better job once I got this thing to work. So, perhaps I broke the volume when I edited the surface. If that is the case, then how do you recommend getting a volume surface that represents your finished grade PLUS a basement dig out. Hopefully this makes sense.......but to be honest I am stabbing marbles with a fork.
                            thank you
                              You haven't quite started on the right foot...
                              Your EXTG & PROP groups must both be shown as 'solid' in Entity Info [with a volume] - otherwise SketchUp itself can do 'subtraction' etc...
                              Also they must both have the same 'footprints' from their 'skirts' - otherwise the resultant cut/fill volumes will be skewed by the differences...
                              So your 'PROP' group cannot have a different bottom 'footprint' compared to the 'EXTG' group.
                              They must also be exactly overlaid for the process to have a chance of working out the differences.
                              If you have accidentally made something into 'non-solid', then you need to use a tool like Solid-Inspector to find out what's gone wrong - sometimes it can fix things, but other times you need to do a manual repair... My SolidSolver is another extension to consider...
                              Remember that a 'solid' must consist of only edges and faces, and every edge must support just 2 faces - no more, no less.
                              This means the surface cannot have any 'holes', 'flaps' or 'shelves', and no internal partition faces etc, where some edges will have 3 or more faces...
                              Use View > Hidden Geometry > ON, to see all of the 'smoothed' edges in the surface - this will aid you when you try to heal holes and need to over-draw an edge etc...
                              • U Offline
                                unearthed
                                Was this plugin ever available for SU version 8? Or is it a post 8 application only?
                                Growplan - People ∩ Plants ∩ Place
                                windows 7 64b, 4GB RAM, SU 8.0.16846
                                Gimp, QGIS, Vectorworks 12, Bricscad 11
                                  I do have an old version [v2.0] which is compatible with v8.
                                  However, it's not as good as the newer version which are incompatible with v8.
                                  I could PM you an EVAL [10 uses] version RBZ if you want it.
                                  There is a v8 licensed version RBZ too, but for that I need proof of you buying it...
                                  • U Offline
                                    unearthed
                                    That'd be great TIG, I've DM'ed you my personal email in case it can't be sent on here.
                                    cheers, Nigel
                                      I've PM'd you the old EVAL RBZ...
                                        Here's the EVAL version v4.0
                                        https://sketchucation.com/pluginstore?pln=TIG-CutNfill
                                        Following feedback...
                                        Reconfigured & re-signed for newer versions.
                                        Options added for results 'colors', layers/tags, +/-ve clarified etc.
                                        A licensed version is now available for purchase/download from the SketchUcation Shop.
                                        If you already have a licensed version, then downloading and installing the EVAL version will update your installation to v4.0... and your existing license will still work...
                                          daleclancy
                                          Hi all trying to cut and fill this split level into a site any one help as to why its not working, novice sketchup here the tool looks amazing once I get it going it will be invaluable for calcs!
                                          trialing.skp
                                            Your groups are not 'solids', therefore it's impossible to subtract one from the other.
                                            Add a 'skirt' to the 'EXTG' group.
                                            It needs to report as 'solid' in Entity Info...
                                            SolidInspector² can report and perhaps fix issues if it's not solid.
                                            When it is solid make a copy of that group, move it off to the side.
                                            Name the copy 'Proposed'
                                            Now add the changes to the terrain...
                                            Relocate the two groups over each other, using the lower parts of their skirts to ensure snapping...
                                            Now you can select both of them and then CutNfill should calculate the differences...
                                            Note that your model as presented contains several reversed faces - you should only see the off-white front-faces, never the blue back-faces.
                                            Whilst reversed faces in themselves should not adversely affect 'solid' operations, they are poor practice, and later on they can mess up 3d-printing and many rendering apps...
                                            • 4 / 5
