    Vray Animation of Scenes
    14 Posts 4 Posters 3.4k Views 4 Watching
    • fredo6F
      You can insert cameras taken from scenes
      • B
        blueman2
        Thanks Fredo,
        I was able to get the scenes in the time line and adjust the duration but unable to see the transition between the two scenes as a slow smooth camera movement as you can see when you are in sketchup and click from scene one to scene 2. I think I'm still missing something.
        • fredo6F
          @blueman2 said:
          Thanks Fredo,
          Just put the all durations to 0, so that you have a succession of small diamond in the timeline.
          If you configure a positive duration, the camera will keep the scene view for the specified duration.
          • B
            blueman2
            @fredo6 said:
            @blueman2 said:
            Thanks Fredo,
            That took care of it. Thank you.
              alaindesrosiers
              Does anyone know why fredo animator doesn't work with V-Ray 4.2
              • fredo6F
                It was a problem with VRay.
                It's now fixed. Just install LibFredo6 v10.9a, just released.
                  Does this mean you had to make an accommodation for the faulty Vray?
                  • fredo6F
                    Not faulty. VRay Next introduced a new way to track the movement of objects for optimization, whereas Animator handles the movement of objects in its own way (also for optimization).
                    The VRay Sketchup team gave me a workaround to resolve the issue.
                    • fredo6F
                      @blueman2
                      Difficult to tell without seeing the model.
                      Could you post it or PM it to me so that I can have a look.
                      • B
                        blueman2
                        I'm still having an issue and wondering if this comment about Vray has something to do with it. I am able to get the scenes loaded in Animator and they show the camera transitions perfectly. However, when I go to make a movie, the result of a vray rendered movie shows the wrong camera position or angle as you can see in these images that show it during the beginning of the scene transition and after the transition.
                        This is the position before transition
                        During the scene transition the camera jumps to what should be the proper transition here:
                        However, when I animate as "Natural", outside of Vray, it is correct
                        I installed LibFredo6 v10.9a to see if that was the problem but it did not correct it. The normal scene transition in Sketchup is fine. I can see now change in camera angle. I'm not sure where the problem is?
                        • B
                          blueman2
                          @fredo6 said:
                          @blueman2
                          Thanks Fredo! I will PM you
