    Drive thru burger time!
    38 Posts 6 Posters 14.8k Views 6 Watching
    • Bryan KB Offline
      What a struggle!
      More refinement.
      • Bryan KB Offline
        A little more. Now it's shaping up.
        • Bryan KB Offline
          Shaping up much better.
          • Bryan KB Offline
            More fiddling. Enough for now. I'm happy with the exterior. Time to start on the cockpit.
            • ntxdaveN Offline
              ntxdave
              Getting more interesting all the time Bryan. πŸ‘
              Press F1...thank me later
                SF car! β˜€
                A car Sketchup Master! πŸ˜‰
                • Bryan KB Offline
                  Thanks Dave!
                  Thanks pilou!
                  There will be more refinement of the exterior, but the overall shape and proportions are done.
                  • Bryan KB Offline
                    Still fiddling. I also need to refine the windshield.
                    • tuna1957T Offline
                      tuna1957
                      Great progress Bryan πŸ‘
                      • Bryan KB Offline
                        Thanks tuna!
                          I agree, I like where it's going.
                          • Bryan KB Offline
                            Oh yeah. Now the windshield looks better!
                            • Bryan KB Offline
                              Thanks Mike.
                              Updates.
                              Notes: I keep having all kinds of problems with components and groups not lining up after using Curviloft to create skins. Just weird off axes and flat plane lines which forces me to have to remake the object several times before I can duplicate and flip component halves to form complete shapes.
                              What a pain. What should only take only 20-30 minutes takes an hour or more. And the misalignment of groups is so tiny I have to zoom into the limit to even see and fix them.
                              • Bryan KB Offline
                                Little by little.
                                • Bryan KB Offline
                                  More updates.
                                    To simplify things a bit when I use this method is to divide the vahicle into three parts, left, right and centre. When I have both side where I want to go I take the bonnet half and create one set of arcs which I then curviloft as one piece which eliminates the rather obvious bum cheek effect I always got. I can demonstrate what I mean because pictures are simpler but waiting for a render to complete first. Intersect is flaky as ever so any holes need to be done by hand but can be done as short arcs and then flipped to create the full opening.
                                    • Bryan KB Offline
                                      Good advice Mike. I also use a variation of that.
                                      I think my problem is I am moving too fast and my PC cannot keep up and I am also inadvertently slightly moving objects and elements without realizing it.
                                      I also have the problem of "snapping" seeing background points that mess up the alignments.
                                      Still what used to take me weeks and months I can now do in days. I just need to be more patient when modeling.
                                      • Bryan KB Offline
                                        Update.
                                        I'm going to take a few days off from this and study it for a while.
                                        While I like it overall, there is still something about it that I'm not quite sure of...
                                        • Bryan KB Offline
                                          Damn. Preliminary renders look... bad. Raylectron does not like the geometry. It seems it will not render all the surface as smooth and is putting vertical lines on the middle of the side pods.
                                          This is the first time I've ever seen that.
                                          • ntxdaveN Offline
                                            ntxdave
                                            Based on your comments and my interest in being able to draw things at this level (I do not have your talent but would like to try to learn), but since I am retired I do not have the money for a bunch of plugins, I would to know what tools you use for drawing this kind of stuff. Do you use tools like SubD or Artisan or do you tools like Curviloft?
                                            If you fo not use a bunch of "paid for" plugins, how Doyle accomplish the things you do? Cuould/would you share how you do the neat stuff you do?
