[Plugin][$] FredoSpline - v2.6a - 01 Apr 24
@fredo6 said:
The issue was signaled during the Beta testing but was not fixed in the release (among other issues and bugs).
I'd love to see those reports, was it opened discussion?
Well I tested the latest FredoSpline in v2023 unfortunately almost everything is broken (in context): Edit, Swap etc. This is the worst SU release ever since v2 . Tons of crashes on start and during all sorts of procedures. Will have to get back to v2022 till they'd sort it out
I'm not having any crashes of SU2023 at all. It's been very stable for me.
Hi Fredo..
i just updated the libfredo and fredo spline now and since then i am unable to open the quick launchers of Fredo spline, joint push pull, fredo scale and the check fredo6 plugins for update menu. attaching the error in the rubby console below.Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class> c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;213;in `invoke_quick_launcher' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;268;in `launch' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;250;in `action__mapping' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;120;in `launch_action' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;133;in `block in startup' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1469;in `command_invoke' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1449;in `block (2 levels) in build_config_commands' c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
they published a new build - Swap Curves and Sandbox's Drape (not yours, I know) still don't work in context.
Will have to skip this version too -
hello. I'm a Korean user who uses Fredo's products usefully.
A little while ago, I purchased a license for 'fredo spline' and pressed the 'Download' button,
but the result is a white screen with only the text below./pluginrepo/rbz/
/var/www/html/pluginrepo/rbz/FredoSpline.rbz
File does not exist. Make sure you specified correct file name.If anybody know a solution, please send 'e-mail' to help. Thank you.
email address jhjncorp@naver.com
Question
I paid for a license, however my plugin keeps telling me it doesnt work due to the fact that i have not the latest version of it. I keep on installing v 2.5 over and over but it keeps sending me the same message. It used to work perfectly in an older version. I cannot seem to fix the issue.
Any thoughts or people experiencing the same issue?
Do you have the current version of LibFredo6 installed? Also the current version of the Sketchucation ExtensionStore? Both of those are required. Share a screen shot of the error message you're getting.
Are you still using SketchUp 2015 Pro as indicated in your forum profile?
Fredo, is it possible to implement a general weight setting in "convert curves" and "edit curves" commands please?
I get used to create all sorts of fredo curves out of faces or chains of straight edges and really miss this general setting. It also counter-effective to change the weight one-by-one in edit -
I get used to create all sorts of splines out of faces of chains of straight edges and really miss this general option. It also counter-effective to change the weight one-by-one in editI think you can select several control points and chenge the weight in one action.
Thats news to me. so how do I change the weight globally?
Also, in case of polycorner arc editing.. I really miss ability to choose (with crossing window and\or by single picks) several vertices and change their radius at once. So again mass editing is really welcomed.
my humble request: window selection - most obvious and basic functionality. currently the process of vertex selection is not bearable.
Yet another idea: in edit, ability to assign different types of vertices in given spline(s) : arc, bezier, simple corner.
NEW RELEASE: FredoSpline v2.6a - 01 Apr 24
Requirements
- LibFredo6: v14.3b
- Sketchucation PluginStore: v4.4.0
- Sketchup version: SU2017 and above
FredoSpline 2.6a is a maintenance release for:
- Future compatibility
Home Page of FredoSpline for information and Download.
I own a bundle bu I do not have bezier curves. HOw can I add this plugin to the bundle?
Thank you
Best,
Nenad
