    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 797.2k Views 143 Watching
    • sketchartist023S Offline
      sketchartist023
      The resolution is also very acceptable considering the width of this model test is only 4 inches πŸ˜›
      I will read how to change resolution in case I need those smaller ones that you mentioned too. Hopefully, for 3d printing purposes, it will be useful to keep πŸ˜„ Thank you much for your help!
      dims and resolution
        sketchartist023
        Wish me luck lolz πŸ˜› And yes, this was all done by hand so far. Wish could use the js align tool but I have to learn it first πŸ˜›
        Progress is progress!
        20 iso layers 16180mm z diff
        • fredo6F Offline
          I think your model would benefit from a higher resolution, as the terrain is basically flat with some very local deeps.
          Also, you can always generate the terrain with its new isocontours (which would be clean), and then
          • extract the group with these isocontours
          • use them to regenerate a new terrain, possibly with another resolution.
            sketchartist023
            That is great info thank you πŸ˜„ Whqat would I likely have to do to generate new isocontours? Do you refer to within the same plugin? I can see howthat would benefit for both generation and time of generation without errors so I'd like to try that method for sure because my SU crashed with this last test. Likely a maxed memory usage idk but new isos would be ideal I agree with this resolution need. Thank you very much again for everything πŸ˜„
            EDIT: The new iso's might also rid the use of artificial contours I would imagine too, to that would be less work for my end if it works out well with generation πŸ˜„ In other words, I wouldnt have to manually erase them one by one after alignments πŸ˜›
            • fredo6F Offline
              What would I likely have to do to generate new isocontours? Do you refer to within the same plugin?
              When you generate the geometry, you have the option to generate the iso-contours for the terrain. These iso-contours are those corresponding to the generated terrain and thus may differ from the original ones. They are created as a subgroup of the terrain group.
                LTiNaTOwpole
                I have very accurate site contours for a large, hilly site. The contours were drawn by a civil engineer and show the proposed conditions, including many vertical retaining walls. I have used TopoShaper to generate terrain from the contours, but it (like the default SketchUp version) doesn't seem to be able to handle vertical faces. See views below of contours and Toposhaper results:
                View 1 - contours
                View 1 - results
                View 2 - Contours
                View 2 - results
                Clearly a lot of detail is being lost here. Does anyone have any suggestions for how to handle this accurately?
                @Fredo6: Thanks for your work creating this.
                • fredo6F Offline
                  This is a limitation of Toposhaper. Vertical faces should be created after the 'natural' terrain has been generated. Vertical faces usually correspond to excavations, road borders, etc.. and should be created along with these objects.
                    LTiNaTOwpole
                    Understood, thanks.
                    I'm curious whether there is another program out there that can create accurate models with vertically stacked contours.
                    • Didier BurD Offline
                      Didier Bur
                      MeshLab http://www.meshlab.net/
                      DB
                        gbelcik
                        Hello,
                        First off, your plugin is remarkable! The terrain from point cloud is working fantastic, but I am running into an issue with a crash to desktop on generation of the quad terrain from ISO-Contours. I tested the example files using the same method and it generates fine. I have attached my file, could anyone maybe explain what I am doing wrong?
                        Land Plot.skp
                        • fredo6F Offline
                          I don't have a problem
                          • when generating the triangulated terrain from guide points
                          • when generating the terrain in quadmesh, after extracting the iso-contours from the triangulated terrain
                          I wonder also what is the object mixing guide points and edges on the right (picture below).
                          Can you tell me where it crashes.
                          Gbelcik - Land Plot.skp
                            gbelcik
                            The object is a triangulated point map DXF import.
                            It crashes to desktop approximately 1 second after generating the terrain from ISO contours, I have attached images. I am going to test generation on a different PC today and see if that works.
                            • V Offline
                              VaVa0VaVa
                              Hi thanks a lot for this plug in, I've been looking for something of the sort for a very long time.
                              I have a question, and aware this might not be the right place but maybe you're able to address me to the right topic.
                              I've got the elevation data in a cad file (from a survey), but how do I import it into sketchup so that it recognises it as guide points?
                                Beaver99
                                Fredo, your plugins give sketchup a huge lift and usefulness that without them sketchup would be second rate.
                                many thanks for all your plugins and thank you for offering them free... sketchup should be paying you.! im going to donate to you now,!
                                • pbacotP Offline
                                  Onto another project with the great TopoShaper! You know what I think would be nice (when you work on this again)--if Toposhaper made separate components of the contours and terrain models, and put them on new separate layers. These are things I do every time to be able to work with it thereafter. That's what I think anyway. β˜€
                                  Thank you for the great plugins!
                                  • fredo6F Offline
                                    Contours and terrain are already created in separate groups.
                                    I can however put them of specific layers if it helps.
                                      As they are both made as Groups you can easily select each of those in turn - in the Model or using the Outliner, and then use Entity Info to assign another preferred Layer [Tag] to them...
                                      • pbacotP Offline
                                        Thanks for the suggestion.It should be easy but I spent some time figuring out how to get the parts organized this time.
                                          MTHPumps
                                          Hi, I was successful in generating a terrain with skirt from my 2D contour map, however, I'm trying to export to Sweet Home 3D in DAE, 3DS, or OBJ formats but the only format that is working at all is the DAE format. Even so, the terrain is coming in as 3D contour lines only and no surfaces or skirt. I'd like to place the home I designed on the terrain, but can't seem to figure out how to bring the 3D model into Sweet Home in a useful way. Am I missing something in Toposhaper, Sketchup, or is the DAE file format a limiting factor?
                                          Any thoughts would be appreciated....MTHPumps
                                            TeKnoel
                                            Hi this is still a very valuable plugin and one of the most powerful ways of transforming CAD typographical information into 3d. It would be even more powerful if we could get it to output meshes that were compliant with the new Quad workflow that subdivision surfaces utilizes. I imagine you're familiar with the requirements. would it be a big job to update?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
