    How to make a group of components unique from its copy?
    11 Posts 4 Posters 3.5k Views 4 Watching
      Normally make your copy
      enter the copied group
      select your components
      Make them unique
      But better post an example SKP for avoid missunderstand 😄
      • concept image wanted result
      • W Offline
        Wim_Storme
        Thanks! This helps, the only catch is that you have to do this for every group of components in the model. It looks like you can not do this for the whole model at once..
        Grtz
        • HornOxxH Offline
          HornOxx
          hope that helps
          never trust a skinny cook
          • HornOxxH Offline
            HornOxx
            ... or another approach could be to use the SU´s Component Window or the Ouliner - the right tactics always depends on the task to do 😉
            • W Offline
              Wim_Storme
              Tnx Horn Oxx for the visual aid! it helps.
              Grtz
                Out of curiosity, what is different about the "alternative versions" of the model? There might be a more efficient process.
                • W Offline
                  Wim_Storme
                  Hello Dave,
                  In this case, the alternate version has different textures on the faces
                  Grtz
                    Is this to let a client see different options?
                    One way that I do this sort of thing is this.
                    1. Set up the model with the first materials options. Here I've got a bed in mahogany.
                    2. Copy (CMD-C on Mac) all of the components that will need to show a different material. In my case it's all except the ebony plugs and splines and the slats to support the mattress.
                    3. Assign a layer tag based on the material to the currently visible components. I made a layer tag called 'mahogany' for this example. If you need to you can group the components together and assign the layer to that group instead of to the individual components.
                    4. Turn off the visibility for that layer.
                    5. Paste in place. This puts copies of the component in the same locations as the originals.
                    6. Immediately, while the pasted components are selected, right click on one and choose Make Unique.
                    7. Apply the new materials to the faces in the components.
                    8. Create and assign a a layer tag for the new material. In my case I used cherry.
                    I would make scenes with the different versions visible so it's easy to switch between the different materials.
                    • W Offline
                      Wim_Storme
                      Hello Dave,
                      This is indeed the goal, In this case the “client” is my girlfriend, who can be considered difficult ; )
                      Thanks, in this way i can toggle between textures, I will certainly try this.
                      Grtz
                        Good luck!
                        Although you might not want to tell your "client" it's possible to do, you could use this same basic process to show other differences like various cabinet door styles or arrangements, or hardware or whatever.
