    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 456.8k Views 109 Watching
      Ahmed0007
      @samuel_t said:
      @ahmed0007 said:
      just one little problem is the origin of the imported component placed very far away from geometry
      (~ 13579.78') this make very difficult to place the component.
      To locate "far from origin" component: Open Outliner in SketchUp. Select component. Zoom Selection.
      Thanks 👍
      • E Offline
        Einstein
        Hi, Samuel!
        I have reinstalled MS Visual C++ as you advised and now I can import stuff 😄 Thank you!
        Still a couple of things bother me a bit.
        1. The plugin always asks how big the imported model should be. It doesn't preserve its original size.
        2. I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
          However, the remesher icon is beautiful! 10/10 for it 😄
        3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
          Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one). I'm attaching both OBJ and FBX version of the model.
        Rudolf Chair.rar
          andsgf
          Вот такая ошибка
          smena8m-plus8.skp
          • samuel_tS Offline
            samuel_t
            @andsgf said:
            Вот такая ошибка
            I suppose polygon reduction fails because face count is low at start (387). I can't fix this problem. 😕
              Ahmed0007
              @samuel_t said:
              @andsgf said:
              Вот такая ошибка
              it's working after running cleanup extension on it.
              • samuel_tS Offline
                samuel_t
                1.1.1 version:
                • Copies only necessary files to temp dir.
                • Shows model face count during import.
                Download latest Universal Importer plugin from SketchUcation PluginStore.
                • jujuJ Offline
                  juju
                  @samuel_t said:
                  1.1.1 version:
                  I'm getting this message when trying to download:
                  "Sorry this plugin is not published at the moment. Probably under editing by the author. Please check later."
                  • samuel_tS Offline
                    samuel_t
                    @juju said:
                    @samuel_t said:
                    1.1.1 version:
                    Please check now. It should be fine.
                    • samuel_tS Offline
                      samuel_t
                      @tig said:
                      It makes a folder 'Universal Importer/tmp' inside the main C:/ProgramData/ hidden-folder - not sure why ?
                      What's wrong with the user's Temp folder ?
                      User's temp folder can contain special chars which are not supported by program used by this plugin.
                      @tig said:
                      Permission muddles and other issues are almost inevitable !
                      Famous plugins like Artisan and Skatter are using C:\ProgramData. This isn't a problem.
                      @tig said:
                      The importer then copies a seemingly random selection of files and subfolders into 'tmp' !
                      It seems like these are from the same location as the file selected to import ?
                      Currently about 17Gb !
                      Textures can be associated to model. So I've no choice but to copy whole folder.
                      Since 1.1.1 version of plugin, only necessary files are copied to temporary folder.
                      @tig said:
                      There's no auto-cleanup on completion, and so the 'tmp' folder will grow with each run of the importer !
                      No. Plugin temporary folder is recycled on each new import. There's no risk to saturate disk.
                      • jujuJ Offline
                        juju
                        @samuel_t said:
                        @juju said:
                        @samuel_t said:
                        1.1.1 version:
                        Still can't download, not published.
                        • samuel_tS Offline
                          samuel_t
                          @juju said:
                          @samuel_t said:
                          @juju said:
                          @samuel_t said:
                          1.1.1 version:
                          Yet it's published. Try following routines: Clear your browser cache. Reboot your Internet router.
                          • kenK Offline
                            ken
                            I still have the problem I have for some time.
                            • samuel_tS Offline
                              samuel_t
                              Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
                              • samuel_tS Offline
                                samuel_t
                                1.1.2 version fixes loading of some OBJ files.
                                • samuel_tS Offline
                                  samuel_t
                                  @ehc2000 said:
                                  Mac OS X 10.11.6 , SU 18.0.16976
                                  I think program used by this plugin (Assimp) is not compatible with MacOS X El Capitan (10.11). 😕
                                  Plugin works for sure on macOS High Sierra (10.13) and potentially with macOS versions > 10.13.
                                  @ehc2000 said:
                                  Tried a very simple, small .stl file (750kb) and got:
                                  *Universal Importer Error: No space left on device - write
                                  /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/fileutils.rb:1393:in `copy_stream'
                                  Universal Importer Version: 1.0.9*
                                  Indeed, my HD is very full, but at the time of my import attempt, it had ca. 4GB free space, no other programs were running, aside from Chrome.
                                  Does it need to make use of more than 4GB of temp space to import a file with only 7,500 vertices and 15,000 faces?
                                  Don't select a model that is stored at root of /Users/$user/Desktop or /Users/$user/Downloads.
                                  Since v1.1.1 of plugin, only necessary files are copied to temp directory: model and textures. Period.
                                  @ehc2000 said:
                                  • If I press Cancel after “Model Height” (i like this feature, by the way), it still (attempts) to opens the file... is that because it is then opening the file at whatever size it’s been set to previously? or is it supposed to cancel the import?
                                  It's too late. Import process can't be aborted at this stage.
                                  @ehc2000 said:
                                  • I can’t double click a file name and have it import it (like if I were pressing "Open") (wheras I can when with the normal import dialog with other images and 3D models already supported by SU). it’s a minor thing, but double-clicking a file in any OSX UI opens it (or at least many do), so it's pretty ingrained in my workflow. 😉
                                  I can't fix this problem. It seems related to SketchUp API.
                                  • kenK Offline
                                    ken
                                    Well re-installing Microsoft Visual C++ library with stl files. Thanks for the help.
                                    • samuel_tS Offline
                                      samuel_t
                                      1.1.3 version allows you, during import, to reassign textures which are not referenced nor embedded in model.
                                      • samuel_tS Offline
                                        samuel_t
                                        @einstein said:
                                        Hi, Samuel!
                                        Hi Einstein! 😉
                                        Scaling feature doesn't work for all formats. 😕
                                        @einstein said:
                                        1. I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
                                        I tried to make it work with selection only but I don't know why it was VERY slow. So I gave up this idea...
                                        @einstein said:
                                        1. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                                        I inspected attached model. Indeed, it doesn't reference any texture. In this case: you have to remap textures in a external software before importing model in SketchUp. Since v1.1.3, it's no more an issue.
                                        • samuel_tS Offline
                                          samuel_t
                                          Einstein, your issue has been fixed with 1.1.3 version of plugin. 😉
                                          Rudolf Chair
                                            sibawal
                                            hi samuel thanks a lot for this amazing plugin
                                            but sadly it seems not workin with me for some reason
                                            i try use the plugin for importing an .blend .obj and .dae but none of them work
                                            and i got some error ( i attach the image error)
                                            if u not busy please help me and once again thanks a lot
                                            im using mac os high siera , sketchup 2019, and blender 2.81a
                                            dae and obj file
                                            blend file
                                            blend / obj with 1.1.3
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
