    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 456.3k Views 109 Watching
    • samuel_tS Offline
      samuel_t
      @khai said:
      for a future time, any chance of supporting grouping of imported meshes?
      Chances are low since mesh hierarchy is lost during conversion. 😕
        Khai
        oh. not good.. since if you import a mesh in sections rather than in a hierachy, the way that SU places it in scene - you manually placing it instead of just in position - makes lining it all up again a nightmare if you've got large sets...
        hmm no matter.... I can work round it...
        • samuel_tS Offline
          samuel_t
          1.0.9 version:
          • Supports up to 1000 embedded textures.
          • Shows face count before/after reduction.
          Download latest Universal Importer plugin from SketchUcation PluginStore.
          • E Offline
            ehc2000
            Really excited about this plugin!
            Mac OS X 10.11.6 , SU 18.0.16976
            It’s not working for me. Trying some simple .obj files (ca. 9mb) and get this message (after I get the "Do you want to reduce polygon count?" and "Model Height" Dialogs:
            Tried some .ply files of the same object, same message.
            Tried a very simple, small .stl file (750kb) and got:
            *Universal Importer Error: No space left on device - write
            /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/fileutils.rb:1393:in `copy_stream'
            Universal Importer Version: 1.0.9*
            Indeed, my HD is very full, but at the time of my import attempt, it had ca. 4GB free space, no other programs were running, aside from Chrome.
            Does it need to make use of more than 4GB of temp space to import a file with only 7,500 vertices and 15,000 faces?
            As a last attempt before I write here, I made a super simple 2m cube and 2m sphere in C4D and exported as OBJ (274 verts 540 faces) and I still got the error as the above screenshot. I also tried this with a simple 2x2m plane. No luck.
            Something I'm missing?
            a few other notes/questions:
            • If I press Cancel after “Model Height” (i like this feature, by the way), it still (attempts) to opens the file... is that because it is then opening the file at whatever size it’s been set to previously? or is it supposed to cancel the import?
            • I can’t double click a file name and have it import it (like if I were pressing "Open") (wheras I can when with the normal import dialog with other images and 3D models already supported by SU). it’s a minor thing, but double-clicking a file in any OSX UI opens it (or at least many do), so it's pretty ingrained in my workflow. 😉
            anyway, thoughts on the error messages?
            Thanks!!
            • OxerO Offline
              Oxer
              Spanish Language for v1.0.9
              es.zip
              REQUEST: Can you investigate the missing texts in the importing popup windows on macos? I think for users it's very useful to see the text to understand what have to do.
              • samuel_tS Offline
                samuel_t
                [attachment=0:8aivyaaf]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:8aivyaaf]
                Thanks for translation, Oxer. 😉
                I can't fix this problem because:
                "[On a Mac] UI.openpanel ignores the title argument. There isn’t even a place in the dialog for a title to appear. It also doesn’t support wildcard patterns for the filename and there is no place for a selection list to appear anyway. In fact, the filename argument appears to have no effect at all; it isn’t pre-selected and the user can choose anything."
                Source: https://forums.sketchup.com/t/good-default-directory-for-ui-savepanel/40307/6
                • samuel_tS Offline
                  samuel_t
                  @oxer said:
                  Thanks for the aclaration.
                  Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to selec model format, see the image.
                  [attachment=0:1sjaildi]<!-- ia0 -->Texts in window.jpg<!-- ia0 -->[/attachment:1sjaildi]
                  I'm Thea4SU beta tester and I can ask to Tomasz (TheaSU developer) if it's possible implement that in Universal Importer.
                  Good idea!
                  • samuel_tS Offline
                    samuel_t
                    1.1.0 version:
                    • Fixes "big copy" issue again.
                    • Shows face count before reduction.
                    • Updates translations.
                    • OxerO Offline
                      Oxer
                      Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to select model format, see the image.
                        Ahmed0007
                        @ahmed0007 said:
                        Error 😕
                        .glb 7.9mb
                        Model is here : https://www.dropbox.com/s/bte329pn42gs5px/80005e0d-0006-f600-b63f-84710c7967bb.zip?dl=0
                        this issue has been fixed in this version 😮 🎉
                        just one little problem is the origin of the imported component placed very far away from geometry
                        (~ 13579.78') this make very difficult to place the component.
                        Thanks for this fix 😄
                          • samuel_tS Offline
                            samuel_t
                            To locate "far from origin" component: Open Outliner in SketchUp. Select component. Zoom Selection.
                              Ahmed0007
                              Thanks 👍
                              • E Offline
                                Einstein
                                Hi, Samuel!
                                I have reinstalled MS Visual C++ as you advised and now I can import stuff 😄 Thank you!
                                Still a couple of things bother me a bit.
                                1. The plugin always asks how big the imported model should be. It doesn't preserve its original size.
                                2. I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
                                  However, the remesher icon is beautiful! 10/10 for it 😄
                                3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                                  Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one). I'm attaching both OBJ and FBX version of the model.
                                Rudolf Chair.rar
                                  andsgf
                                  Вот такая ошибка
                                  smena8m-plus8.skp
                                  • samuel_tS Offline
                                    samuel_t
                                    @andsgf said:
                                    Вот такая ошибка
                                    I suppose polygon reduction fails because face count is low at start (387). I can't fix this problem. 😕
                                      Ahmed0007
                                      @samuel_t said:
                                      @andsgf said:
                                      Вот такая ошибка
                                      it's working after running cleanup extension on it.
                                      • samuel_tS Offline
                                        samuel_t
                                        1.1.1 version:
                                        • Copies only necessary files to temp dir.
                                        • Shows model face count during import.
                                        • jujuJ Offline
                                          juju
                                          @samuel_t said:
                                          1.1.1 version:
                                          I'm getting this message when trying to download:
                                          "Sorry this plugin is not published at the moment. Probably under editing by the author. Please check later."
                                          • samuel_tS Offline
                                            samuel_t
                                            @juju said:
                                            @samuel_t said:
                                            1.1.1 version:
                                            Please check now. It should be fine.
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
