    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    441 Posts 106 Posters 432.3k Views 106 Watching
      One thing I see that seems adrift is the the user is prompted to choose an optional 'Texture Atlas' - but I think it's asked with a UI.openpanel dialog not a UI.select_directory dialog
      So the desired folder is never passed to the code properly as the selected item is a file, not a folder, and also if the user cancels that step, then somehow the method still runs and then random files & folders get copied over into into 'tmp'...
        Glenn at home
        Huh, so far working as advertised for me. I've only tried a few of the formats so far but they mostly worked for me. Here is a .gltf file I exported from Simlab and used this plugin to bring it into SU. It took a few minutes, like 3 but it came in with good results.
        https://i.ibb.co/BzMWJZG/amon.png
        SketchUp Pro 2024/2025 Dell XPS 8950 i9-12900K 64GB Ram RTX 3080
        • samuel_tS Offline
          samuel_t
          @jimpeter said:
          Error:Following command failed:
          Could you please upload your model to a file hoster or here? This way I could debug it.
          • samuel_tS Offline
            samuel_t
            1.0.4 version:
            • Fixes scaling issues for many formats.
            • Fixes "black screen" bug on Windows.
            • Drops temp folder on SketchUp close.
            Download latest Universal Importer plugin from SketchUcation PluginStore.
            • samuel_tS Offline
              samuel_t
              @ken said:
              I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
              I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
              Thanks for your help.
              Ken
              Did you tried plugin with another model? If yes, does same (assimp stop) problem occurs?
              Install Microsoft Visual C++ library then restart SketchUp. Let me know if problem persists.
              • kenK Offline
                ken
                Well at least with version 4 I am getting an error message, attached below, for a stl and stp file
                • samuel_tS Offline
                  samuel_t
                  Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
                  • kenK Offline
                    ken
                    Will the smallest I can get the file is 5442 KB.
                    Attached is an image of the file another converter. This is a downed oil platform in the Gulf of Mexico.
                    If you can send me an email address, I can use google mail to send the file.
                    • samuel_tS Offline
                      samuel_t
                      OK. I've sent you my email address in private message.
                      • samuel_tS Offline
                        samuel_t
                        1.0.5 version:
                        • Enhances bug reports.
                        • Fixes "big copy" issue.
                        • samuel_tS Offline
                          samuel_t
                          1.0.6 version:
                          • Fixes polygon reduction on models without textures.
                          • Reduces plugin package size. (From 49MB to 41MB.)
                          • E Offline
                            Einstein
                            Hi!
                            I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp 😞
                            By the way, I think it would be cool to also have polygon reduction as standalone tool for meshes that already exist in SketchUp. Because we haven't had a decent free polyreducer in SketchUp so far. It's just a suggestion.
                            Regards,
                            Michał
                              Ahmed0007
                              i import this model with v1.0.1 without any problem but v1.0.6 give me this error why?
                              please help.
                              800085a7-0000-fd00-b63f-84710c7967bb.zip
                              • OxerO Offline
                                Oxer
                                please help.
                                On macOS 10.13.6 & SU2017 the v1.0.6 works fine with your model.
                                • OxerO Offline
                                  Oxer
                                  It's a good idea 👍
                                  • samuel_tS Offline
                                    samuel_t
                                    please help.
                                    In recent versions of plugin there's a mechanism that prevents copy of a too big folder. To fix this issue: Create a sub folder in your Documents then place model and textures inside that sub folder. Re-import.
                                    • samuel_tS Offline
                                      samuel_t
                                      @einstein said:
                                      Hi!
                                      Hi!
                                        Ahmed0007
                                        @samuel_t said:
                                        please help.
                                        Still Same error ?
                                        • samuel_tS Offline
                                          samuel_t
                                          @ahmed0007 said:
                                          @samuel_t said:
                                          please help.
                                          Still Same error ?
                                          What's size of model in MB?
                                            Ahmed0007
                                            @samuel_t said:
                                            @ahmed0007 said:
                                            @samuel_t said:
                                            please help.
                                            Still Same error ?
                                            8 mb
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
