    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
    • samuel_tS
      samuel_t
      @oxer said:
      Hi, I tried to import the same Pinas.obj file with QuadTools plugin and the importing works fine.
      Here the files:
      Hello Oxer,
      I can import "Pinas.obj" on Windows. So it's maybe related to macOS or SU.
      Could you please overwrite your installed "converter.rb" with attached one?
      converter.rb
      Then restart SketchUp. Then try to re-import "Pinas.obj". Thanks for help. πŸ˜‰
      • samuel_tS
        samuel_t
        @Mac Users
        I've fixed again plugin code. I hope this one works on macOS! πŸ˜›
        Please overwrite your installed "converter.rb" with attached one.
        converter.rb
        Then restart SketchUp. Then import a model. Tell me if it works.
        Thank you. πŸ˜‰
        • samuel_tS
          samuel_t
          1.0.3 version fixes critical bugs on macOS and Windows. macOS is now fully supported.
          Download latest Universal Importer plugin from SketchUcation PluginStore.
          • samuel_tS
            samuel_t
            @oxer said:
            Fantastic plugin but I work on mac, is there plan for macos support?
            Problem is I don't have macOS computer. Maybe I could try code it on a virtual machine?
            Since v1.0.3, plugin is compatible with macOS.
            @oxer said:
            Spanish Language File
            Thanks for Spanish translation.
            • samuel_tS
              samuel_t
              1.0.2 version adds:
              • Preliminary macOS support,
              • Spanish translation.
                JimPeter
                [img]1.0.3.png[/img]
                Error:Following command failed:
                  JimPeter
                    JimPeter
                      There seems to be something seriously wrong with the functioning of this version of the Extension.
                      It makes a folder 'Universal Importer/tmp' inside the main C:/ProgramData/ hidden-folder - not sure why ?
                      What's wrong with the user's Temp folder ?
                      This location doesn't seem appropriate ??
                      Permission muddles and other issues are almost inevitable !
                      The importer then copies a seemingly random selection of files and subfolders into 'tmp' !
                      It seems like these are from the same location as the file selected to import ?
                      Currently about 17Gb !
                      If I rename/delete 'tmp', then it's remade with a new random selection when the next import is started.
                      As far as I can see it's copying, rather than moving files, which of course would be far worse !!
                      There's no auto-cleanup on completion, and so the 'tmp' folder will grow with each run of the importer !
                      Which is of course not ideal.
                      Any thoughts on what's happening ??
                        It's a great idea for an extension but so far I haven't been able to get any file type imported into SU2019 with it. Like TIG found, there's a huge TMP folder created in Program Data full of all sorts of files including some SketchUp files that aren't mine and which I've never seen before. I suspect the TMP file is full of stuff from the author's testing. For now I've removed it all and will wait to see if it gets fixed. It would be very useful if it worked.
                        • OxerO
                          Oxer
                          It happens the same on mac, the extension creates a temporal folder inside the user folder:
                          /Users/Username/.UniversalImporter/tmp
                          I told it to samuel_t and he answered me this:
                          Model and associated files are copied to a hidden temporal folder to avoid invalid characters in path.
                          These temp files are automatically deleted at each import.
                          On mac the default temp folder is located here:
                          /private/var/folders/l9/c_qtfqf17257pb9ppdy9tw5m0000gn/T/
                            One thing I see that seems adrift is the the user is prompted to choose an optional 'Texture Atlas' - but I think it's asked with a UI.openpanel dialog not a UI.select_directory dialog
                            So the desired folder is never passed to the code properly as the selected item is a file, not a folder, and also if the user cancels that step, then somehow the method still runs and then random files & folders get copied over into into 'tmp'...
                            • G
                              Glenn at home
                              Huh, so far working as advertised for me. I've only tried a few of the formats so far but they mostly worked for me. Here is a .gltf file I exported from Simlab and used this plugin to bring it into SU. It took a few minutes, like 3 but it came in with good results.
                              https://i.ibb.co/BzMWJZG/amon.png
                              • samuel_tS
                                samuel_t
                                Could you please upload your model to a file hoster or here? This way I could debug it.
                                • samuel_tS
                                  samuel_t
                                  1.0.4 version:
                                  • Fixes scaling issues for many formats.
                                  • Fixes "black screen" bug on Windows.
                                  • Drops temp folder on SketchUp close.
                                  • samuel_tS
                                    samuel_t
                                    @ken said:
                                    I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
                                    I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
                                    Thanks for your help.
                                    Ken
                                    Did you tried plugin with another model? If yes, does same (assimp stop) problem occurs?
                                    Install Microsoft Visual C++ library then restart SketchUp. Let me know if problem persists.
                                    • kenK
                                      ken
                                      Well at least with version 4 I am getting an error message, attached below, for a stl and stp file
                                      • samuel_tS
                                        samuel_t
                                        Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
                                        • kenK
                                          ken
                                          Will the smallest I can get the file is 5442 KB.
                                          Attached is an image of the file another converter. This is a downed oil platform in the Gulf of Mexico.
                                          If you can send me an email address, I can use google mail to send the file.
                                          • samuel_tS
                                            samuel_t
                                            OK. I've sent you my email address in private message.
                                            • 22
                                            • 23
                                            • 3 / 23
