    The parameter is incorrect?
    3 Posts 2 Posters 981 Views 2 Watching
      House 2.jpgHi just opened a file and after about 5 mins when I triy to selecy anything a "the parameter is incorrect" as shown. I have purged and "fix problem" to no avail. Any clues guys I have never seen this before.
        Never seen that before. Is this in 2017 Make? Is it possible an extension is running that is having a problem? Easy way to check is to disable the extensions you have installed and try opening the model again.
          Cheers Dave, will try your sugestion this afternoon, and will report back. However when you mentioned which version I was using I realised I had seen the message before. The model was created in 2018 or 2019 Pro (At work) and that messge had cropped up there as well. I cant remember how it resolved ๐Ÿ˜•
