    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    439 Posts 152 Posters 547.3k Views 150 Watching
    • deaneauD Offline
      deaneau
      Hi Fredo Round Corner have some errors
      this is a corner with 8 segments and 1mm radius
      skp 2019
      https://1drv.ms/u/s!AoU3tpJxqmvto3skG47ckoAVXMeP?e=nu42nx
      skp2013
      https://1drv.ms/u/s!AoU3tpJxqmvto3z6vD80Gvsyv0Vc?e=eIjFlT
      https://i.ibb.co/KXbNynr/2019-08-19-12h11-28.png
      • FrederikF Offline
        Frederik
        Looking at the various errors you've posted recently, I assume that it's more a limitation of SU rather than a bug in the various plugins...
        What usually helps is if you scale the model up - i.e. 10 times so one millimetre becomes one centimetre...
        And once the plugins have made the job for you, you scale it down to the original size...
        The detail you seem to want to accomplish is not something SU is good at...
        Cheers
        Kim Frederik
        • PixeroP Offline
          Pixero
          I usually make it a component then copy the component and scale it up 10-1000 times and make the tiny stuff on that copy. When done I just delete the copy and the original component is done.
          • fredo6F Offline
            NEW RELEASE: FredoCorner v1.7a - 20 Sep 19
            Requirement: LibFredo6 9.1b
            FredoCorner 1.7a extends validity.
            Please note that, in the current version of FredoCorner:
            • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
            • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
            • Terminal corners (that is ending on a single edge) may present issues and bugs
            • No documentation yet, so watch the videos that I will publish.
            Please report issues, questions and any feedback in the present thread
            Home Page of FredoCorner for information and Download.
            Main post of this FredoCorner thread.
              mrkidd
              I am not able to get this to load in SU 2019...error message every time.
                What's the error message?
                Did you install the current version of LibFredo6 which is required by FredoCorner? See Fredo's post immediately before yours.
                • fredo6F Offline
                  NEW RELEASE: FredoCorner v1.7b - 02 Nov 19
                  FredoCorner 1.7b for bug fixing.
                    What was the exact error message? Did you also install the required LibFredo6 files?
                      gmintz1
                      I was excited to use this plugin but after installing and restarting sketchup I got an error message stating there was an error loading, could not find loader file. Help!
                      Yes, I installed the "lib" file.
                      Error message:
                      Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
                      Could not find included file 'Fredo6_FredoCorner/__loader__FredoCorner'
                      • fredo6F Offline
                        NEW RELEASE: FredoCorner v1.7c - 21 Dec 19
                        FredoCorner 1.7c for extenson of validity.
                        • N Offline
                          nlipovac
                          Hi Fredo,
                          I get this message when using bevel (same for Round) when selecting three edges.
                          Is this tool limit so it just can´t do or I am doing something wrong here?
                          Also,
                          Thank You very much for all the plugins you have created and made my work easier doing so.
                          This is that part.
                          Selecting two edges is fine but the third one gets me this message.
                          • fredo6F Offline
                            This seems to be a limitation of FredoCorner. I can reproduce it on my computer.
                            The message is not informative, because, when there is a problem in the geometry, FredoCorner assumes that it could come from an offset which is too large. I know where the error happens, but this seems to be an issue in the heart of the algorithm, which is quite complex for this type of geometry. So I put your model in the stack of models I have already for when I'll dig into FredoCorner deep core to see how to make it more robust.
                            At a first glance, I am scratching my head on what could be the correct result with a selection of only 3 edges at this 6-edge corner, convex / concave.
                            It works fine however if you select the 6 edges.
                              mikedub
                              HI, today I just installed latest FredoCorner 1.7c and the Library 9.5c (Fredo6_!LibFredo6) folder and ruby files in the proper location – User > Library > Application Support > SketchUp > Plugins.
                              The Extension Manager says they are installed and active. And I see it in the Sketchup menu. But (after making a cube and selecting it, to test) when I click on the FredoCorner menu icon, or choose it from the menu, nothing happens. The FredoCorner menu does not come up at all.
                              I tried uninstalling and reinstalling the plugins, quitting and restarting Sketchup a few times. Still nothing.
                              Please help!
                              Cheers,
                              Mike
                              • fredo6F Offline
                                Could you open the Ruby console to see if there are errors displayed.
                                • Mim86M Offline
                                  Mim86
                                  This is fabulous, I have been going nuts trying to fudge fillets on my models. Now I can do it easily. I have added the extension, although it is telling me I need LibFredo6 9.1b. Which I can't find anywhere. Thanks in advance for any help here.
                                  Mim
                                  • fredo6F Offline
                                    @mim86 said:
                                    ...although it is telling me I need LibFredo6 9.1b.
                                    Just take the latest version of LibFredo6, currently v9.5g.
                                    • F Offline
                                      FlygFartyg
                                      Cant open sketchup when this is in the folder. It crashes Sketchup as soon as i start it. When i remove FredoCorner from the extensions folder Sketchup is able to run again. Wierd
                                      • N Offline
                                        nebin asharaf
                                        I Donno why it's showing this comment, its not a group, nor a component...
                                        Any one can help?
                                        • N Offline
                                          nebin asharaf
                                          Yes its done
                                          Its rectified.
                                          "EDGE PROF. FILTER " WAS NOT SELECTED
                                          • fredo6F Offline
                                            NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
                                            FredoCorner 1.7d for extenson of validity.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
