    How can I make a smaller version of a sketchup file ?
    19 Posts 10 Posters 2.9k Views 10 Watching
      Try to make Components of components of components...
        rv1974
        In short: To model effectively
        • L
          Lolajea
          Ok and what do you mean by “model effectively” ? Using groups, components,... ?
          • soloS
            Can you post images or share file so we can help better?
            • BoxB
              Yep as Solo says, we need more info to be able to help.
              I just made a collection of 10,000 spheres and the file size is 2.4 mb so there must be something else going on in your model than there just being lots of the same component.
              • gillesG
                gilles
                Windows / entity info / statistics / purge and fix...
                • L
                  Lolajea
                  Ok thank you for your answers.
                  I've try to purge and fix but it doesn't work for my file.
                  There you can find a link to download on wetransfer, so you can see the file :
                  WeTransfer | Send Large Files Fast
                  The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
                  WeTransfer (wetransfer.com)
                  • T
                    TBoy
                    232 544 instances of Component#2 ?
                      rv1974
                      I've seen lots of f@cked up files. But this one hands down is absolute winner!
                      I'm dying of curiosity how it could be achieved 😮
                      P.S. It reminds me one of buggy plugins of Curic that literally used to create hundreds of thousands copies of component (but I don't think this is the case).
                      P.P.S. It's a cool idea for plugin BTW. Sometimes it's needed to spoil the file.
                      • BoxB
                        I can't look at your file as I'm on limited download but 232000 instances of a component isn't really going to work very well anywhere.
                        BTW means By The Way.
                        Perhaps if you showed an image someone may be able to suggest a better option since you seem to be after a pattern rather than needing geometry.
                        • L
                          Lolajea
                          Yes 232 000 instances of components2#, normal it crashs..
                          • HornOxxH
                            HornOxx
                            ... hmm, I can open this strange file though, but every further handle brings everything to a SkUp-standstill here.
                            So from me just a pragmatic proposal: What I see, however, is so little model content that it might be better to reproduced all that new "clean and tidy" in 3 minutes instead of wasting more time in finding this however caused file bug.
                            never trust a skinny cook
                            • L
                              Lolajea
                              Yes I think so delete every components is the better thing to do.
                              • PixeroP
                                Pixero
                                You should really just use a texture instead of geometry.
                                Also for viewport speed. Turn off profile edges and group all those loose components.
                                I Made a simplified version of your component with fewer edges but the file somehow grew to 54 mb.
                                Here it is anyway.
                                https://we.tl/t-TVAS1YoFOA
                                • HornOxxH
                                  HornOxx
                                  @rv1974 said:
                                  ...my SU freezes on delivering.
                                  😉 same to me - with much less horsepower under the hood 😆
                                    rv1974
                                    Could anybody post a print screen of those 232 544 instances of Component#2 😆 ?
                                    I have OK i9 64gb RAM PC, but my SU freezes on delivering.
                                    Edit: I was too impatient. Eventually I opened it and it looks.. monumental.
                                    https://emojipedia-us.s3.dualstack.us-west-1.amazonaws.com/thumbs/240/microsoft/209/shocked-face-with-exploding-head_1f92f.png
                                    • T
                                      TBoy
                                      Don't try to move, rotate, zoom or pan the model, just delete all instances of component#2 (components window, select all instances > delete) and file will behave normal.
                                      I don't understand what are these components for, and cant check because it is impossible to navigate in model. Try to use texture instead, as i see components are too small for the scale of the object.
                                      If those components are too important for you, you can make a separate drawing with small detail and description.
                                      • kenK
                                        ken
                                        Well, I find that my models increase in size for some reason.
                                        My solution, not elegant, but effective sometimes. Show everything you wish to keep, that is all the geometry you wish to keep. Select everything on the screen, copy, then save the file and open a new file. Now copy into this new file everything you copied, save under a new name, me I add a new version number. Now save this new file. After finishing saving, Do a "save as" to open the area you saved this file at, and check the file size. I find it is usually very much smaller.
                                        Not sophisticated, but works for me.
