    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 23.9k Views 9 Watching
    • samuel_tS Offline
      samuel_t
      The 1.0.2 version adds many parameters:
      • Rotate entities?
      • Entity min size
      • Entity max size
      • Entity density
        Near the perfection! πŸ‘
        What is the process for don't have frame (segments) around the object with the transparent texture/photo ?
        If i erase them (segments) all is erased! (Texture/photo)
        I can mask it but does exist something else ?
        Here the fame was "masked"
        https://i.postimg.cc/43S6CmnQ/maask.jpg
        • PixeroP Offline
          Pixero
          Set SketchUp to show Wireframes.
          Open any group or component.
          Drag to select the edges and right click to hide them.
          Set SketchUp to Shaded with textures.
          The edges are now "gone".
          • pbacotP Offline
            Looks like a good one. I think it's amazing you can make it work with Enscape and all. Thank you!
            • samuel_tS Offline
              samuel_t
              With 1.0.4 version:
              You can create proxies for Enscape. So, a tree becomes a forest in secs.
              Proxies are symbolized by little translucent cubes with a random color:
              REG Plugin Proxies Demo
                @Pixero
                It's that I made with "Masked them" πŸ˜‰
                It's curious because seems to me that was a trick for have only the "material/texture/Photo" but maybe i have dreamed! πŸ˜„
                • samuel_tS Offline
                  samuel_t
                  What's new in 1.0.5 version?
                  • There is a new param: Avoid entity collision. After 5 unsuccessful attempts, collided entity is erased.
                  • Enscape proxies have real dimensions based on real model. This allows a better collision detection.
                  • You can specify, via context menu, a spawn zone for generated objects. It is called "Random Zone":
                  REG Plugin Zone Demo
                  • samuel_tS Offline
                    samuel_t
                    New in v1.0.6: If you've set a Random Zone, distribution algorithm follows possible mesh deformations:
                    REG Plugin Deformations Demo
                    Download latest REG plugin from the SketchUcation PluginStore.
                    • samuel_tS Offline
                      samuel_t
                      1.0.8 version fixes a bug about entity rotation.
                      • samuel_tS Offline
                        samuel_t
                        1.0.9 version includes a library of proxies ready-to-use for Enscape and V-Ray. (It's available on Windows only.)
                        REG Proxy Library
                        REG Plugin Proxy Library Demo
                        • samuel_tS Offline
                          samuel_t
                          1.1.0 version:
                          • Adds a parameter: Entity max. altitude.
                          • Handles complex meshes very quickly:
                            A FlowScape challenger! πŸ˜‰
                            • samuel_tS Offline
                              samuel_t
                              1.1.1 version:
                              • Adds a parameter useful e.g. to hide tree roots: Push entities to down (cm).
                              • Adds four presets to help you discover how parameters work in REG plugin.
                              • samuel_tS Offline
                                samuel_t
                                What's new in 1.1.2 version?
                                • There is a "Preview" button in REG Parameters.
                                • Random Zones can be constituted of triangles.
                                • samuel_tS Offline
                                  samuel_t
                                  With 1.1.3 version:
                                  You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
                                  REG Plugin Star Scattering Map
                                  REG Plugin Star Demo
                                  • samuel_tS Offline
                                    samuel_t
                                    1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
                                    • samuel_tS Offline
                                      samuel_t
                                      @pbacot said:
                                      I think it's amazing you can make it work with Enscape and all. [...]
                                      It also works with V-Ray and potentially other renderers. πŸ˜„ πŸ‘
                                      Just randomize the component-proxy made with V-Ray/other...
                                      (Right click on component-proxy then left click "Randomize...".)
                                      • samuel_tS Offline
                                        samuel_t
                                        1.0.7 version:
                                        • Adds four parameters:
                                          • Entity minimum rotation
                                          • Entity maximum rotation
                                          • Follow face normals?*
                                          • Overwrite entity colors?
                                        • Supports multiple Random Zones.
                                        (*) Thanks to Eneroth3 for its help.
                                        REG Plugin Glue To Faces Demo
                                        • samuel_tS Offline
                                          samuel_t
                                          1.1.5 version adds three parameters:
                                          • When you set selection as Random Zone:
                                            • Entity distribution algorithm
                                          • When you set Random Zone from an image:
                                            • How many vertical (Z axis) layers?
                                            • Space between each Z layer (cm)?
                                          • samuel_tS Offline
                                            samuel_t
                                            1.1.6 version adds two parameters:
                                            • Put entities in group
                                            • Put entities in layer
                                            Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
                                            • 1 / 3
