    [Plugin] Random Entity Generator - v1.2.1 - 29 April 2025
    41 Posts 9 Posters 24.5k Views 9 Watching
    • samuel_tS
      samuel_t
      @pilou said:
      can we have a version where elements are choosen in an existing family ?
      It's possible with 1.0.1 version...Attention, selected entities must be groups:
      • samuel_tS
        samuel_t
        With 1.0.3 version you can:
        • Randomize components
        • Glue entities to ground 🌻
        • samuel_tS
          samuel_t
          What's new in version 1.0.1?
          • Generation process is way faster.
          • Extension is translated in French.
          • You can, via context menu, randomize position and size of selected entities:
          REG Plugin Galaxies Demo
          • samuel_tS
            samuel_t
            The 1.0.2 version adds many parameters:
            • Rotate entities?
            • Entity min size
            • Entity max size
            • Entity density
              Near the perfection! πŸ‘
              What is the process for don't have frame (segments) around the object with the transparent texture/photo ?
              If i erase them (segments) all is erased! (Texture/photo)
              I can mask it but does exist something else ?
              Here the fame was "masked"
              https://i.postimg.cc/43S6CmnQ/maask.jpg
              • PixeroP
                Pixero
                Set SketchUp to show Wireframes.
                Open any group or component.
                Drag to select the edges and right click to hide them.
                Set SketchUp to Shaded with textures.
                The edges are now "gone".
                • pbacotP
                  Looks like a good one. I think it's amazing you can make it work with Enscape and all. Thank you!
                  • samuel_tS
                    samuel_t
                    With 1.0.4 version:
                    You can create proxies for Enscape. So, a tree becomes a forest in secs.
                    Proxies are symbolized by little translucent cubes with a random color:
                    REG Plugin Proxies Demo
                      @Pixero
                      It's that I made with "Masked them" πŸ˜‰
                      It's curious because seems to me that was a trick for have only the "material/texture/Photo" but maybe i have dreamed! πŸ˜„
                      • samuel_tS
                        samuel_t
                        What's new in 1.0.5 version?
                        • There is a new param: Avoid entity collision. After 5 unsuccessful attempts, collided entity is erased.
                        • Enscape proxies have real dimensions based on real model. This allows a better collision detection.
                        • You can specify, via context menu, a spawn zone for generated objects. It is called "Random Zone":
                        REG Plugin Zone Demo
                        • samuel_tS
                          samuel_t
                          New in v1.0.6: If you've set a Random Zone, distribution algorithm follows possible mesh deformations:
                          REG Plugin Deformations Demo
                          Download latest REG plugin from the SketchUcation PluginStore.
                          • samuel_tS
                            samuel_t
                            1.0.8 version fixes a bug about entity rotation.
                            • samuel_tS
                              samuel_t
                              1.0.9 version includes a library of proxies ready-to-use for Enscape and V-Ray. (It's available on Windows only.)
                              REG Proxy Library
                              REG Plugin Proxy Library Demo
                              • samuel_tS
                                samuel_t
                                1.1.0 version:
                                • Adds a parameter: Entity max. altitude.
                                • Handles complex meshes very quickly:
                                  A FlowScape challenger! πŸ˜‰
                                  • samuel_tS
                                    samuel_t
                                    1.1.1 version:
                                    • Adds a parameter useful e.g. to hide tree roots: Push entities to down (cm).
                                    • Adds four presets to help you discover how parameters work in REG plugin.
                                    • samuel_tS
                                      samuel_t
                                      What's new in 1.1.2 version?
                                      • There is a "Preview" button in REG Parameters.
                                      • Random Zones can be constituted of triangles.
                                      • samuel_tS
                                        samuel_t
                                        With 1.1.3 version:
                                        You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
                                        REG Plugin Star Scattering Map
                                        REG Plugin Star Demo
                                        • samuel_tS
                                          samuel_t
                                          1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
                                          • samuel_tS
                                            samuel_t
                                            @pbacot said:
                                            I think it's amazing you can make it work with Enscape and all. [...]
                                            It also works with V-Ray and potentially other renderers. πŸ˜„ πŸ‘
                                            Just randomize the component-proxy made with V-Ray/other...
                                            (Right click on component-proxy then left click "Randomize...".)
                                            • 1 / 3
