    Making threads for bolts and 3D printing.
    15 Posts 6 Posters 32.2k Views 6 Watching
    • O Offline
      Oliveros
      Hey Guys.
      Probably beating a dead horse but I'm trying to make bolts and threads for 3D printing but I can't seem to get it right.
      Any bright minds in here who know how to do it and is willing to tell me the plugin and a step by step on how to do it?
        What kind of threads are you trying to create? Do they need to be a standard profile? That is, are you expecting to be able to put a standard screw into a 3D-printed hole?
        I model threads fairly often. Examples below.
        I use Curve Maker to draw a helix of the right dimensions for the thread; major dia. and pitch; but I work at 1000x scale. Then I draw the correct thread profile and use Eneroth Upright Extruder to extrude the threads and then do what is needed to clean up the results to make a solid component. Solid Inspector 2 and TIG's Solid Solver help a great deal.
        https://live.staticflickr.com/65535/48665758252_8873962c49_m.jpg
        https://live.staticflickr.com/7920/40278668183_ffaa596478_m.jpg
        If the threads are rather small and must be functional, you might find it better to model a pilot hole or cylinder with no threads and use a tap or die to cut threads.
        • O Offline
          Oliveros
          Looks like some cool stuff.
          Yes, I want it to be functional, even if it's arbitrary threads as in, no standard bolt or nut would fit but whatever I print would fit.
          I'm pulling my hair out trying to get it right.
          What plugins do I need, I have Sketchup Pro 2014.
            I listed the extensions I used in my previous post.
            • O Offline
              Oliveros
              I have curve maker and if I draw a profile of the thread and then extrude it, it get's tilted slightly near the end making it so I can't put it on the object properly. It seems the helix won't stay the same size and angle but changes somehow.
                Please go back and read my first reply to you. I didn't say I used Follow Me. I used Eneroth Upright Extruder to extrude the profile.
                • O Offline
                  Oliveros
                  You good sir are correct.
                  I used an upright extruder and by golly, it seemed to work, lots of patching mesh but in the end it went solid.
                  Now i'm printing it so we'll see if it works.
                  Thank you for the assistance.
                  • BoxB Offline
                    https://sketchucation.com/forums/viewtopic.php?f=18&t=68150
                    Added this the the thread I linked to explain your face missing problem.
                    https://i.imgur.com/8c4uCeU.gif
                      Some ideas
                      • O Offline
                        Oliveros
                        Thanks guys.
                        youtube videos don't really work for me, I need the dummed down, step 1, step 2, etc.
                        • O Offline
                          Oliveros
                          Bloody brilliant.
                            I actually use the Dave method Box describes.
                            • O Offline
                              Oliveros
                              Good to know, I'll have to give that a shot next and see what happens.
                                sergey02
                                Кому интересна еще эта тема вот видео на ютуб как рисовать болты гайки резьбы при помощи простого плагина.https://www.youtube.com/watch?v=6iq8FeMczl0
                                • F Offline
                                  frederm81 Newcomers
                                  What a strange thing to do. Probably 100 or more STLs on Thingiverse when one openscad for each external shape would do it if it's written with variables as it should be. In fact one openscad with the shapes commented out and you are where you need to be.
                                  Even then it seems a bit pointless because surely anyone that prints things with any of these 3d printer has done this for themselves at some point.
                                  Still I suppose you have to keep up the thingverse tradition of posting what you did even though no one else can see a use for it.
