    3D Truss Models
    1.5k Posts 31 Posters 933.7k Views 30 Watching
    • medeekM Offline
      medeek
      First look at a soffit on a complex hip roof with asymmetric roof planes:
      https://3dwarehouse.sketchup.com/warehouse/v1.0/publiccontent/5d204ab3-9ff4-4014-9fdc-88c2efa3441f
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Now I just need to complete the special cases situations for half hips, dutch gables and gables. Still quite a bit of work to do with soffits and also some more work on the fascia for the boxed end case (return and triangular pieces).
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        First look at a complex roof with a gable end and soffit and fascia:
        http://design.medeek.com/resources/trussplugin/images/truss_su582_800.jpg
        I'm really trying to wrap up the soffit and fascia and get a new version released however there are a lot of details and possible geometries with the soffit and fascia when you throw gables, dutch gables and half hips into the mix. The interior gables also further complicate the matter with a number permutations that must be specifically accounted for.
        I probably have at least another day of adding in more logic for all of these possibilities, but I am getting close.
        Rather than moving on to the actual framing I think I will spend a little time on roof connections and what I call a "terminal" roof configuration. The terminal roof configuration is similar to the other configurations in that it can only be applied to a roof plane that has corner angles of 90 degrees. I will allow the roof to just end (ie. no gable overhang), this will be useful when creating roofs that are adjacent to walls and other structures.
        On a different note, I will be temporarily removing the "angled" option from the soffit type selection options. This soffit configuration makes the most sense with simple gable roofs but with hip roofs it is a bit of a mess. Until I study this further and make sure that I have a sensible solution I am limiting the soffit types to gable and boxed.
        design.medeek.com
        • medeekM Offline
          medeek
          First look at a half hip with a boxed soffit and fascia:
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.5.8 - 10.24.2019
            • Added soffit & fascia for complex roofs.
            http://design.medeek.com/resources/trussplugin/images/truss_su584_800.jpg
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM Offline
              medeek
              I've been testing out the "gable" soffit configuration and at steeper pitches this is what you get:
              http://design.medeek.com/resources/trussplugin/images/truss_su585_800.jpg
              The proper way to configure this would be:
              http://design.medeek.com/resources/trussplugin/images/truss_su586_800.jpg
              This requires an additional check to see if the rake soffit extends below the eave soffit.
              I've also received requests to have another option to trim the rake fascia so that it is flush with the eave fascia, similar to what I already do with the rake fascia with the "boxed" option.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.5.9 - 10.26.2019
                • Added a trim fascia rake parameter for complex roofs.
                • Resolved the issue with the soffit for the "gable" soffit configuration for complex roofs.
                http://design.medeek.com/resources/trussplugin/images/truss_su587_800.jpg
                Note that the trimming of the fascia rake is enabled automatically when you choose the "boxed" soffit configuration. The "gable" configuration however allows one to trim the ends or leave them untrimmed.
                For low roof pitches the "gable" soffit extends to the corners, at steeper roof pitches the logic checks the geometry and creates the flat section as required.
                design.medeek.com
                • medeekM Offline
                  medeek
                  First look at the "Terminal" roof plane configuration:
                  https://3dwarehouse.sketchup.com/warehouse/v1.0/publiccontent/68fa8165-9d56-4372-bec3-b2f852bf2195
                  3D Warehouse
                  The terminal configuration is utilized when you have a roof plane that abuts a vertical wall as shown. To use this feature the corner angles of the roof plane must be both 90 degrees (same as a dutch gable or half hip).
                  The next feature I will be working on is a roof "connection", or the ability to create secondary/primary roofs, where one roof ties into another roof assembly or solid group or component. This feature should prove a bit challenging but very useful if I am able to make it work as I have envisioned it.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at the "Roof Connection" feature:
                    In this case I am simply connecting to a generic solid which cuts away the section of the roof that is intersecting the solid geometry. When I get to the actual roof framing things may become slightly more complicated (ie. ledgers etc...)
                    View model here:
                    3D Warehouse
                    When a roof is connected to another roof not only will the secondary roof have geometry removed but the primary roof will also need to have geometry modified or removed. This is a real can of worms, but hopefully I can bring order to the ensuing chaos.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Here would be an example of a chimney against the eave of a roof:
                      Note the addition of a cricket (manually created group) next to the chimney.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        First look at two intersecting complex roof assemblies:
                        View model here:
                        3D Warehouse
                        As I've worked my way through the logic of intersecting roof assemblies this evening it has become clear to me that the concept of primary and secondary roofs really does not exist. In actuality intersecting roofs is the more correct terminology. If a roof assembly intersects another roof assembly, each will need to have its geometry modified by the presence of the other assembly's roof primitive. Each assembly will store the other assembly's name in its attribute library (database) as a connecting object.
                        The tricky part of this will be the rafter framing, where a simple boolean subtraction of the opposing roof primitive from the rafters will not work. I will need to ponder on this some more, I think the solution will probably reveal itself but currently I don't see a clear path on this one.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.6.0 - 10.30.2019
                          • Added the terminal roof plane option for complex roofs.
                          • Added the "Complex Roof Connection" tool to the complex roof toolbar.
                          • Enabled Roof Connections for complex roofs: roof assemblies or solid groups.
                          • Added the "Remove Roof Connection" feature to the edit menu for complex roofs.
                          http://design.medeek.com/resources/images/complex_su_menu_active.jpg
                          http://design.medeek.com/resources/trussplugin/images/truss_su591_800.jpg
                          Tomorrow I will put out a tutorial video explaining the terminal roof plane option and the setting up and dismantling of roof/roof and roof/solid connections.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Now that I’ve got the roof connection functionality up and running it is time to turn my attention to the actual roof framing. This is where the real headaches begin.
                            I think I will start with trying to figure out an efficient algorithm for the ridge boards.
                            Most orthogonal roofs are fairly straight forward:
                            If a ridge meets another ridge then it will receive a miter cut to match with that other ridge.
                            If the ridge terminates into two hip rafters then it will be a square cut.
                            The question I have is what to do when the hip terminates into a flying hip and valley?
                            Then of course there are the exceptions caused by half hips, dutch gables, gables and terminals but those can be accounted for.
                            As I’ve previously stated it makes sense to first catolog each edge of the roof primitive and create a hash for easy lookups. The process of elimination should allow me to assemble the catalog relatively easily.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              The new connection tool allows you to do this sort of thing:
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 17: Complex Roof Connections (19:05 min.)
                                View model in tutorial here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  The Medeek Halloween Haunted House:
                                  View model here:
                                  3D Warehouse
                                  Another test of the roof connection feature with chimney and turrets.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    First look at ridge boards with complex roofs:
                                    Things get a little messy when a ridge terminates into more than two hips or flying hips (ie. octagon and hexogon roofs), I will need to add in additional logic to handle these types of situation.
                                    The potential asymmetry of the roof planes also creates some interesting possibilities, however I do think I've solved that topological problem.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.6.1 - 11.07.2019
                                      • Added ridge boards for complex roofs.
                                      The next framing item is hip and valley rafters.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at interior half hips:
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.6.2 - 11.17.2019
                                          • Allowed the option for interior half hips within complex roofs.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su598_800.jpg
                                          The logic for interior half hips proved to be rather complicated. This additional feature affected every aspect of the module so it took me about 7 days to make it happen. However, in the process I think I also made the module more robust and addressed some other minor issues. Eventually I will also need to enable interior dutch gables but right now I'm too exhausted mentally to attempt it. Currently only gables and half hips are able to pile up on each other as shown.
                                          Also note that you can mix things up with interior gables and half hips. For instance you could have a half hip on gable on half hip or any other combination.
                                          Now, let's see if I can make anymore head way on valleys, hips and rafters...
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.6.3 - 12.02.2019
                                            • Fixed multiple bugs in the complex roof module as related to metric templates.
                                            After a bit of a Thanksgiving break I'm back on the complex roof module. There is still a considerable amount of work to do with the framing of the roof, some of the details I am still sorting out, in particular a very efficient rafter framing algorithm. I'm hoping to wrap this all up in the next couple of weeks and then jump over to the new Medeek Floor extension which will replace the floor truss/I-Joist module of the Truss plugin.
                                            The new floor extension will allow for complex floors with the ability to alter the outline of floor similar to the complex roof.
                                            design.medeek.com
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 75
                                            • 76
                                            • 69 / 76
