    Fill moves outside of boundaries
    layout
    4 Posts 2 Posters 6.2k Views 2 Watching
    • pmolsonP
      pmolson
      Hi All,
      I imported a model into layout, chose the scene I want, changed scale to 1/16", adjusted line scale a bit so they dont look so fat. I am confused as to why my fills are moving away from the boundaries.
      I have hybrid selected
      see images
      layout screen shot
      sketchup screen shot
        Still SU/LO 2018? What graphics card?
        I sent you a PM.
        • pmolsonP
          pmolson
          Hi Dave, I am 2019 pro qtx 1080
          sorrry i have not posted for a while and neglected to add the proper up front info.
          I also did not say it is the pdf output that has the fill misplaced. I have since figured out that I must use the built in export feature vs printing to a pdf.
          It worked.
          Thanks Dave
          p
            Ahh.... That's all different then.
            A couple of other questions, then. Have you upgraded to 2019.2? When you installed SketchUp did you right click on the downloaded installed and choose Run as administrator or did you just double click on it to get it to run?
            Maybe update your profile?
