    [Plugin] jf_get_dimensions.rb
    61 Posts 21 Posters 75.2k Views 21 Watching
      ritchey
      This is the best extension ever. Thumbs up thousand times.
      • Y Offline
        yossku
        Thank you very much! Extremely helpful plugin! πŸ˜„
          pipinek
          @dedmin said:
          Here is a new version that displays the dimensions on the status bar
          [attachment=1:2up1m3b2]<!-- ia1 -->Screen.png<!-- ia1 -->[/attachment:2up1m3b2]
          Made by a russian guy called 'newsposting'
          [attachment=0:2up1m3b2]<!-- ia0 -->GetDimensions.rb<!-- ia0 -->[/attachment:2up1m3b2]
          Greetings.
          Alas it does not work with SU 2017 as far as I experience.
          Should it be any equivalent or a version of that plugin for 2017 release?
          Thank t=you in advance
            What do you mean it doesn't work? I've been using Jim's Get Dimensions all along and it works just fine for me.
            In fact, here's an example I made just now with SketchUp 2017.
              Laurenceau
              it doesn't work with 2018 version
              plugin .rb instead of .rbz
                It works just fine in SketchUp 2018.
                You can either install the RB file manually or get the RBZ version here and use Install Extension or better, install the Sketchucation Extension Store tool and use it to automatically install the plugins and extensions host here on Sketchucation.
                • dereiD Offline
                  derei
                  [attachment=0:25dij2zt]<!-- ia0 -->Screenshot - 12_5_2017 , 4_11_42 AM.png<!-- ia0 -->[/attachment:25dij2zt]
                  Can't seem to find the plugin in Extension Store... is still available, or was removed?
                    It seems that Jim has removed most if not all of his plugins.
                      bsfranza
                      hi there together,
                      is there a working version of the plugin? or any alternative? because it seems its still gone from the extension store and sketchucation store πŸ˜•
                      V 1 Reply Last reply Reply Quote 0
                        As I wrote back in April of last year, Jim has withdrawn his extensions and plugins and they aren't available anymore. Get Dimensions was a useful one for me but I've not seen a similar one by any other author.
                          dedmin
                          Here we go:
                          [mod=:1m1nlxa4]Edited to remove the file. It is up to the original author to share their plugins and extensions.[/mod:1m1nlxa4]
                          • I Offline
                            iamblindtoo
                            Any upgrade on this?
                              What sort of upgrade are you wanting for a plugin that has been withdrawn and is not available?
                              • V Offline
                                vasia7777
                                This is "GetDimentions" plugin modified by russian guy which does work well with SU2014Pro on WinXPSP3 with out "Bug repot" window after exiting of SU14.
                                It was founded on YouTube channel "Geometry of Comfort".
                                GetDimentions_by Geometry of Comfort _SU2014.zip
                                Another version (it may matchs for more newer SU) was published here:
                                https://community.sketchucation.com/post/1239480
                                • V Offline
                                  vasia7777 @bsfranza
                                  @bsfranza
                                  @bsfranza said in [Plugin] jf_get_dimensions.rb:
                                  hi there together,
                                  Is this one match you:
                                  • 3 / 4
