    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      Version 1.3.0b - 07.16.2019
      • Added the Slab Depression toolbar and icons.
      • Enabled a 45 deg. miter option for the ends of interior footings.
      • Fixed a bug with the initial positioning transforms for the interior footing draw tool.
      The option for mitering is tucked into the start and end slope option. Now in addition to the Yes/No options you also can have it miter left or right (45 deg only).
      http://design.medeek.com/resources/trussplugin/images/truss_su460_800.jpg
      This is a critical update since the transform bug was a significant issue with Version 1.3.0.
      The slab depression functions/tools are still under construction and currently not functional.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Hmmm, you might be on to something with this.
        I agree that the amount of toolbars has multiplied quite rapidly as I keep adding more features to each plugin, it does take up quite a bit of screen real estate now.
        design.medeek.com
        • jujuJ
          juju
          thanks for the efforts!
          the toolbars for your extensions are becoming rather elaborate and taking up a bit of toolbar / screen space, any chance you could implement a single initiation button/icon instead and have a secondary open when the primary has been triggered, much like Fredo does some of his extensions?
          • medeekM
            medeek
            Version 1.3.1 - 07.19.2019
            • Added slab depressions for rectangular and polygon slab-on-grade foundations.
            • Enabled editing, moving and deleting of slab depressions for all slab-on-grade foundations.
            • When construction callouts and subbase material is enabled, the volume of the subbase material is displayed beneath the foundation label (currently only slab-on-grade foundation assemblies have this feature available).
            http://design.medeek.com/resources/trussplugin/images/truss_su461_800.jpg
            The slab depression tool can also be used to cut thru holes into the slab, as shown.
            Note that additional work still needs to be done to properly modify rebar and mesh for slab depressions. Currently there is no logic in place to modify the perimeter or slab rebar when a slab depression is utilized within a slab-on-grade foundation.
            View model here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM
              medeek
              Tutorial 4 - Slab Depressions for Slab-on-Grade Foundations (9:35 min.):
              View model here:
              3D Warehouse
              design.medeek.com
              • medeekM
                medeek
                Trying to take a day off from the programming but my mind keeps coming back to it and the brick ledge module (for slab-on-grade foundations) I have left unfinished.
                Giving it a bit of thought this afternoon and I've come up with the following parameters:
                • Ledge Width
                • Ledge Height
                • Start Ext.: Defaults to zero
                • End Ext.: Defaults to zero
                Really not much to it, or so it would seem.
                The idea is to be able to create a brick ledge on any specified edge (perimeter) of the foundation rather than around the entire foundation. A lot of modern designs only utilize a brick facade on the front of the house and not on the rear so this ability to be selective with each wall is critical.
                Once I have this feature up and running I think the tools afforded the slab-on-grade type of foundation will allow it to be utilized for most designs however additional work will still need to be done to make the rebar placement correct in a complex design.
                design.medeek.com
                • medeekM
                  medeek
                  First look at brick ledges combined with a slab depression (garage).
                  http://design.medeek.com/resources/trussplugin/images/truss_su462_800.jpg
                  The trickiest part of the brick ledge module was the tool that selects the foundation edge. I have it working stably now but I need to add some additional logic which prevents the user from duplicating a brick ledge along the same foundation edge.
                  I also need to add in some additional logic which offsets the anchor bolts the appropriate amount given the width of the brick ledge.
                  Similar to the slab depressions the brick ledge module makes no accommodations currently for rebar placement. The logic and algorithms for that will take some considerable effort.
                  design.medeek.com
                  • medeekM
                    medeek
                    Here is slight modification where the slab depression is lower than the brick ledge:
                    http://design.medeek.com/resources/trussplugin/images/truss_su463_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.3.2 - 07.22.2019
                      • Added brick ledges for rectangular and polygon slab-on-grade foundations.
                      • Enabled editing, and deleting of brick ledges for all slab-on-grade foundations.
                      • Added an additional layer for hidden geometry into the Layers tab of the Global Settings.
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 5 - Brick Ledges for Slab-on-Grade Foundations (14:11 min.):
                        design.medeek.com
                        • medeekM
                          medeek
                          I am seriously considering adding the ability to slope the slab depression and would actually like to work on it before I move back to the complex roof module.
                          I have a few questions:
                          1.) With a sloping floor do you typically measure the depression from the high side as your reference and then slope it downward? Or do you measure where you want the doors to end up and then slope upwards?
                          2.) What is a typical slope in a garage slab depression? Is a 1/4" per foot typical? On a 24' deep garage this would mean a vertical difference of 6 inches from front to back. This seems like a pretty steep slope.
                          3.) If a depression is sloped then I would assume that the slab thickness in the depressed region would remain a constant thickness and hence the bottom of the slab at this region would also slope?
                          design.medeek.com
                            MtnArch
                            I normally set the top of the depression at 3-1/2" below the main slab (a 2x4 for the form) and 5-1/2" below the main slab at the garage doors (a 2x6 for the form); if the garage is deeper than - say - 24' I would probably slope to a central location and add a drain inlet. Stems higher than 5-1/2" would need to be increased in width for me to be comfortable that they would be stable.
                            Highest Regards,
                            Alan T. Hendry, RA
                            Architect
                            • medeekM
                              medeek
                              Rather than prompt the user for a pitch/percent grade or some other angle I think it would be easier just to have them specify a height differential. So if the primary depth of the depression is 3.5" at the back of the garage and then the user calls out a differential of 2" then the other side of the depression will be 5.5" at the door.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.3.3 - 07.24.2019
                                • Enabled sloping slab depressions for rectangular and polygon slab-on-grade foundations.
                                • Fixed a bug with the slab depression draw tool.
                                http://design.medeek.com/resources/trussplugin/images/truss_su464_800.jpg
                                The sloping of the depression can be either in the X or Y direction, in the future I may allow for other directions. To reverse the slope, the slope differential can be entered in as a negative number in the edit or draw menu.
                                design.medeek.com
                                  MtnArch
                                  Very cool - great implementation!
                                  Highest Regards,
                                  Alan T. Hendry, RA
                                  Architect
                                  • medeekM
                                    medeek
                                    Giving a little thought on how to created stepped foundation the last couple of days as I wrapped up work on the slab-on-grade foundations.
                                    Creating a single (closed-loop) stemwall foundation assembly with steps is proving to be difficult. After giving this some additional analysis it seems that it would be better to break it down into separate (polyline) assemblies, somewhat similar to the Wall plugin.
                                    If I switch to this type of system then creating steps in a foundation is just a matter of adding step "segments". I've identified three basic type of steps in the detail below:
                                    http://design.medeek.com/resources/trussplugin/step_foundation_800.jpg
                                    Note, that there would also be a right and left hand version of each, this comes into play with non-symmetric features such as foam insulation and anchor bolts.
                                    So essentially I need to create a whole new system for stemwall foundations, the current system is not scalable. The three main tools need to be:
                                    1.) Polyline Tool
                                    2.) Step Tool
                                    3.) Interior Footing Tool
                                    The polyline tool will also allow for a single (linear) stemwall or any number of segments.
                                    I also need a opening tool for creating windows and doors in the stemwall/foundation wall.
                                    4.) Opening Tool
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      With the new polyline and step tools (stemwall foundation) you will be able to create a foundation like this:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su466_800.jpg
                                      Each polyline segment will be able to be edited similar to the how you edit the outline of a stemwall or slab-on-grade foundation outline now.
                                      Similar to the wall plugin the drawing direction will be counter clockwise in order to face the exterior of the stemwall to the outside. This becomes important for anchor bolts, insulation, brick ledge, and joist pockets.
                                      Each segment will be an independent assembly (group) that the user can simply move around (laterally and vertically) with the native tools.
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        First look at the new Stemwall toolbar:
                                        http://design.medeek.com/resources/images/foundation_stemwall_su_menu_active.jpg
                                        The three functions/tools are:
                                        • Draw Polyline Stemwall
                                        • Draw Interior Bearing
                                        • Draw Stemwall Step
                                        I've got quite a few icons now for this plugin and I'm still not entirely sold on my choice of icons/images for these toolbars but this is what I have for now. I did try to create some 3D icons but at the resolution available for the toolbars it is very hard to create a legible 3D icon.
                                        With regards to the step tool I also need some more information on how best to handle the footing rebar and the stemwall rebar for a step in the foundation. I've examined a few details online as well as some of my own but additional feedback would be helpful.
                                        design.medeek.com
                                        • pbacotP
                                          Great work!
                                          • medeekM
                                            medeek
                                            Running my conceptual tools through their paces this morning. Here is another example of a fairly complex multi-step stemwall foundation:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su467_800.jpg
                                            Note that the three different types of possible steps are represented in this model.
                                            View model here:
                                            3D Warehouse
                                            Also note that I will be providing for the ability to offset the footing from the end of the stemwall (both positive or negative) so that the user/designer can easily butt up against other foundation walls (ie. create T or cross intersections, corner).
                                            As I was working on this initial model/concept a couple of days ago my teenage son noticed that I spent most of the afternoon constructing the model and then adjusting it. He thought that it was funny that I spent a couple of hours mucking around with the model and actually pointed that out to me. Even though most of my time was spent pondering the model (rather than creating the model), he did have a point; it should only take a designer a few minutes to generate this type of foundation, and it should be relatively easy to do. This is the goal of this new module, quick and effortless.
                                            In the model you will notice that I added cripple/pony walls to bring the floor elevation all to the same height. These walls were generated with the wall plugin in less than 60 secs.
                                            http://design.medeek.com/resources/trussplugin/images/truss_su468_800.jpg
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
